Growling noise in ventilation system
Discussion in '2nd Gen Tundras (2007-2013)' started by dugeezer, Dec 27, 2022.
  1. Dec 27, 2022 at 8:49 AM
    dugeezer
    dugeezer [OP] New Member
    2007 Tundra Limited
    Hi guys! I have a 2007 Tundra Limited with 245K miles on it. In the past two weeks when I turn on the AC or heat, I get a LOUD growling sound no matter the fan setting. The fan works, but the airflow is diminished. It will go away after driving a few minutes, but it sounds like Sasquatch inside the cab. Any suggestions on a fix? Thanks!!
  2. Dec 27, 2022 at 8:54 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Anti-sasquatch spray in the cabin air filter area could do the trick. I hear they HATE peppermint, maybe leave some mints unwrapped in your glovebox?
  3. Dec 27, 2022 at 11:18 AM
    dugeezer
    2007 Tundra Limited
    Peppermints are no problem! I am all out of Anti Sasquatch spray after the dog drank it. I could wear my Sasquatch t-shirt when I'm driving! I'll let you know how it works out!!:yay:
    landphil and MedCityMoto like this.
  4. Dec 27, 2022 at 12:15 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    If I had to throw a guess out there, I would start looking at the heater blower motor. Bearings might be toast... or very unhappy bearings anyway
  5. Dec 27, 2022 at 12:47 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Try pulling the blower motor. About once every year or 2 I get a leaf or something down there that makes a TON of noise. It's like (3) screws under the passenger side footwell.
  6. Dec 27, 2022 at 10:42 PM
    Dank
    Dank New Member
    2010 Black Tundra 4wd
    If no leaves or mice nests clogging things up then it might be the blower. Replaced mine over two years ago with one from eBay. Noise is gone and it works well!
    This is the one I bought:
