Which Sparks Plugs do you recommend?
Discussion in '2.5 Gen Tundras (2014-2021)' started by georgiey22, Dec 25, 2022.
  1. Dec 25, 2022 at 11:03 PM
    georgiey22
    georgiey22 [OP] Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Looking for your Spark Plug recommendations? Rock Auto offers many brands, looking at the NGK Laser Iridium units. What experiences do you have?
    2019 Tundra TRD Sport with the 5.7L.
  2. Dec 25, 2022 at 11:54 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    OEM
    Wallygator, WILLINH and TXBrit like this.
  3. Dec 26, 2022 at 12:22 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Which are Denso for the 3UR.
    So you don’t have to get them at a Toyota dealer, a reputable auto parts supplier can get you the exact same thing.
    Just beware of fake / counterfeit OEM and Denso plugs from Fleabay and that big rainforest company, among others.
    omgboost, chugs, Zebruaj and 9 others like this.
  4. Dec 26, 2022 at 1:19 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I just had mine replaced with OEM. I figured why take chances with anything else. JMO though....
  5. Dec 26, 2022 at 5:31 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    About 50 years ago I learnd from experience to only use the plugs listed by the manufactuer. Have not and will not waver from that rule.
  6. Dec 26, 2022 at 5:47 AM
    centex
    centex New Member
    How many mikes do you have on it that it needs plugs?
    Denso iridium are nice but $$$. Ngk is a solid plug as well.
    chugs, georgiey22[OP] and freerider8 like this.
  7. Dec 26, 2022 at 6:01 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Be wary of throwing tons of money at fancy named spark plug schemes. If your motor isn't tuned for higher compression than stock and you're not running premium fuel, you're not getting any benefits from the laser iridium flux capacitors etc etc... OEM parts will do you nicely if your air intake, exhaust and tuning are still OEM.
    georgiey22[OP], centex and WILLINH like this.
  8. Dec 26, 2022 at 6:10 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    You want OEM from a trusted (ie: Toyota dealer or Denso authorized reseller. Look on the Denso website for a list of them) source.
    In the meantime here's a picture of what you want. The box on the top with the part numbers.
  9. Dec 26, 2022 at 6:42 AM
    pursuit2550
    pursuit2550 New Member
    I would stick to OEM or NGK. If going NGK then cross reference the number. Both Denso or NGK are great plugs. Me personally, I would also stick to reputable parts sources like other have said.
    georgiey22[OP] likes this.
  10. Dec 26, 2022 at 7:45 AM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    Thanks for the information and I also love the quotes at the bottom. Those are so true.
  11. Dec 26, 2022 at 9:52 AM
    JonnyT
    JonnyT New Member
    Jonny
    2015 Tundra SR5 Dc
    For what it is worth, I went with the NGK Ruthenium (NGK 94122). I don't have any evidence of a benefit, but no issues either.
    Coal Dragger and georgiey22[OP] like this.
  12. Dec 26, 2022 at 10:58 AM
    737fixer
    737fixer New Member
    I HATE, again HATE, supporting any dealership cartel but anymore with the utter insanity of fake oil filters and spark plugs from wonderful china please consider buying from a dealership. I understand buying something from crapazon but they are literally selling more fake spark plugs then real. If you see a $12 spark plug selling for $2-$7 then who's fault is it when your truck runs like crap and the more glass then ceramic plug shatters into your cylinder. Even Autozone and the like have been fined for selling fake parts. Buying the welder from Harbor freight that you will use once but saving $1000 is definitely the way to go but saving $25 on eight plugs just isn't worth it.
    WILLINH and freerider8 like this.
  13. Dec 26, 2022 at 2:11 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I changed mine at 70,000 miles, used whatever came as OEM...Denso 3421
  14. Dec 26, 2022 at 3:38 PM
    georgiey22
    Thank you JonnyT. How many miles do you use on these plugs? The Laser Iridium's (4904) are 6.85 each and Ruthenium’s (94122) are 8.59, no big deal in terms of cost difference.
  15. Dec 26, 2022 at 3:39 PM
    georgiey22
    Thank you. Plan to change mine at 60K-70K as well.
  16. Dec 26, 2022 at 3:42 PM
    georgiey22
    Agreed. I stay away from dealers and a ton of fakes out there. I only purchase plugs for my vehicles from RockAuto since they are a respected reseller. Unfortunately there is only 1 Denso in stock, will be buying a NGK Iridium or Ruthenium, likely Iridium.
  17. Dec 26, 2022 at 3:43 PM
    georgiey22
    Thank you, TundraMcGov. Wish Rock Auto had more than 1 unit in stock. :-(
    the Denso site is garabaaage, not finding any reputable retailers to purchase from that have them in stock.
  18. Dec 26, 2022 at 3:47 PM
    georgiey22
    Just about to roll 50K miles. With the cost of goods skyrocketing, want to put 8 units in my tool box and change them sometime in 2023. Called my local dealer, 11.50 per OEM plug.
    The equivalent NGK Laser Iridium is 6.85 per unit. Likely going with these NGK’s, use them in my Lexus ES, Acura TLX and Honda CRV and they are good. Would certainly rather use the Denso/OEM units but price doesn’t make sense.
  19. Dec 26, 2022 at 4:25 PM
    JonnyT
    JonnyT New Member
    Jonny
    2015 Tundra SR5 Dc
    I'm guessing around 2,000 miles or so. A majority of them were towing our camper this past summer.
  20. Dec 26, 2022 at 5:17 PM
    freerider8
    Fairview PA
    My local auto parts store carries the Denso Iridium plugs for 10.99 each and if purchased on line I can save 1.65 a plug. I think I will go that route when I need to change the plugs. Also have a rated for 100,000 mile performance.
    WILLINH and georgiey22[OP] like this.
  21. Dec 26, 2022 at 5:28 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    It really is simple isn't it ? People make it way harder than it has to be.....
    Dooders likes this.
  22. Dec 26, 2022 at 5:29 PM
    georgiey22
    That’s good to know, I’ll call and check my local part stores as well. I’d consider Denso’s at that price as well.
    freerider8[QUOTED] likes this.
  23. Dec 26, 2022 at 5:32 PM
    centex
    centex New Member
    What’s the manual recommend for mileage replacement? I’m a 180 miles away or I’d go look.
  24. Dec 26, 2022 at 5:33 PM
    Roborob70
    Robert
    Pretty surer it's 90k could be wrong though.
  25. Dec 26, 2022 at 5:40 PM
    centex
    centex New Member
    At my current driving rate, there will have been two new administrations in office. I’ll worry about prices then.
  26. Dec 26, 2022 at 5:50 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    We've seen many guys on here replace their plugs at 125,000 miles + with no reported deleterious effects. Someone last month said when he replaced his in his bought-used Tundra it was at 223,000 miles and he was pretty sure it was the first time. He may have even of posted a photo or two.
    I replaced mine at 70,000 miles just cause I come from a life where plugs got replaced at 30,000 miles and so I wanted to have a look. Judging by how they looked they had pleeeeeenty of life left in them. I won't have any problems running this set 100,000 miles.
  27. Dec 26, 2022 at 6:08 PM
    centex
    centex New Member
    I did my old 4Runner for the first time at 225k miles. Other than one being carbon stuck in and having to work it out real slowly, noticed zero difference in how it drove. For the most part, as long as they spark and the gap is fine, there isn’t much to go wrong on a plug. Not saying that’s always the case, just 99.9% of them.
    JPritch and georgiey22[OP] like this.
  28. Dec 26, 2022 at 7:15 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Manual says 120k miles for spark plugs.
  29. Dec 26, 2022 at 8:38 PM
    MedCityMoto
    This tracks regardless if you vote conservatively or liberally, nice.
  30. Dec 26, 2022 at 9:11 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Same here.
