High idle cold starts?
Discussion in '1st Gen Tundras (2000-2006)' started by keenxxx, Nov 5, 2019.
  1. Nov 5, 2019 at 5:45 PM
    keenxxx
    keenxxx [OP] New Member
    2005 Tundra DC w/ 4.7L V8. Cold starts the engine idles @ 1500rpm and as the truck warms drops to 600ish rpm. When I bought the truck I thought it might have a dirty throttle body but a good clean up and the rpm's are the same. Google search mentions this idle strategy as normal but I want to confirm as it is annoying imo.
    Thanks,
    YardBird likes this.
  2. Nov 5, 2019 at 5:53 PM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    My 18 does the exact same along w a slight hesitation upon start up when it’s ridiculously cold out. All normal from what iv heard and seen.
  3. Nov 5, 2019 at 5:53 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Normal, increase idle means hotter temp warming up the engine quicker.
  4. Nov 5, 2019 at 5:55 PM
    daveyjames207
    daveyjames207 New Member
    Dave
    2013 SR5 DC 4x4 5.7 Off Road Nautical Blue Metallic
    All normal. My 2013 also does this, along with oil pressure.
  5. Nov 5, 2019 at 7:04 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Normal engine operation for most engines. Same principal as the choke and fast idle cam on a carbureted engine until it warms up.
    KarmaKannon and Jengel451 like this.
  6. Nov 5, 2019 at 7:17 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    The all do it. (that's what the service writer always says)
    I bought my rig used with 20K miles on the clock ~ it's run at 1,500 RPM on cold start as long as I've owned it.
    I'm not afraid of the idle speed so much as dropping the transmission in gear at that engine speed.
    I typically sit and wait for the idle to hover around 1,000 RPM before putting it in gear ~ and yes, I've always been annoyed by this.
    Aerindel and KarmaKannon like this.
  7. Nov 5, 2019 at 7:25 PM
    keenxxx
    Normal operation for a 40 year old carb'd vehicle. I primarily own and work on domestic passenger & light duty trucks and start up rpm is no more than 1K rpms which doesn't last long. I understand higher rpm's mean faster idle warm ups but I usually start my vehicle and throw it in gear and off I go - "yay" to modern fuel injection.
    Aerindel and Jengel451 like this.
  8. Nov 5, 2019 at 7:35 PM
    keenxxx
    Imo. 1500 rpm's is excessive. Waiting for the rpms to drop is way too much of a throwback to a cold blooded carb'd vehicle. I thought about changing the coolant temp. resistance to trick the ecm into thinking its warmer but not sure once up to temp if the higher reported temp would cause side effects. Would be nice if there were any ECU tuners can modify the Toyota Tundra warm up strategy.
    YardBird[QUOTED] likes this.
  9. Nov 5, 2019 at 7:38 PM
    YardBird
    Jonesy
    2005 RCLB
    I'd gladly sign up for a 'mod' on the cold start idle speed reduction ~ something I find quite annoying as do lots of other folks, too.
  10. Nov 5, 2019 at 7:53 PM
    Good to hear this is sorta normal. I just put in new injectors and reset everything by leaving the battery disconnected over night. I wasn’t sure if it was cleaning the TB or just a normal of the truck
  11. Nov 5, 2019 at 7:55 PM
    keenxxx
    What I might do is record the coolant temp sensor temp @ a few ambient temps and then @ a 1,000rpm from a cold start. I would then have a resistance to work with. Problem with coolant temp sensors they are negative temp coefficient thermistors - as temps increase resistance decreases. Resistance would have to be lowered possibly by running a resistor in parallel.
  12. Nov 5, 2019 at 7:59 PM
    I wonder if anyone running the air injection pump delete sees lower cold start up rpms; isn’t it tricking the computer thru the maf to think it’s above the temp to keep the pumps off? It’s kinda pricey but maybe look that direction for a diy
  13. Nov 5, 2019 at 8:09 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    An engines air/fuel ratio requirement is different when the engine is cold compared to when it is warm, therefore the fast idle. If you tried to bypass the system you find yourself with a bad running engine until it warmed up.
    With fuel injection the fast idle mode is so short (30 seconds to 1.5 minutes) I do not understand why it is an issue. Were you not taught about engine warm up during drivers education and to give yourself a few minutes for it?
  14. Nov 5, 2019 at 8:28 PM
    keenxxx
    I understand cold start warm up strategies but as I mentioned Toyota has a uniquely high idle strategy. I have not timed my Toyota's high idle times but it is more like 2 minutes. I am not suggesting to skew the sensor input to that of a warm engine just enough to lower the rpm's slightly. Might work might not and would be a simple resistor once the math is calculated. My drivers education was 35 years ago and extended warm ups were quite relevant. Honestly I am driving down the street in less than 30 seconds on a summer day.
  15. Nov 6, 2019 at 3:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    different strokes for different folks....this ole fart loves high rpms on cold mornings, crank the ole jallopy, go back in house make coffee and Salsa Red has toasty warm seats and warm heat !
  16. Nov 6, 2019 at 6:28 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Normal. This must be your first Toyota
  17. Nov 7, 2019 at 4:37 AM
    No behemoths allowed!
    Yoder18[QUOTED] and BubbaW like this.
  18. Nov 10, 2019 at 2:52 PM
    Professional Hand Model
    Fred
    Hand Protectors
    The 2002 Tundra V8 4.7 cold starts on cold mornings idles (in Park) around 1100rpm which I believe is normal per the manual specs. Drops to 725 once warm (in Park).
  19. Nov 10, 2019 at 3:57 PM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    Remote start. Enough said.
  20. Nov 10, 2019 at 4:02 PM
    Fred
    Hand Protectors
    Shoo!
    Aerindel likes this.
  21. Dec 24, 2022 at 2:11 PM
    cedenk
    cedenk New Member
    2005 Tundra Crew Cab
    i have a 2005 v8 tundra. doing same thing more or less. on first start of day (not just on cold days, but maybe worse when cold) it revs up to 1500+ rpm for less than a minute or so, drops to about 800 rpm. everyone seems to imply this is ok. but my question is that this didn’t start happening until the last couple of years. it did NOT do this for the first 200k or so miles.
  22. Dec 24, 2022 at 4:05 PM
    My 2006 V8 has 74k miles and has basically always done this as far as I remember. Revs up to 1.2k-1.3k RPM, then settles out around 700.
    I wonder what was wrong with yours the first 200k miles that it didn't?
  23. Dec 24, 2022 at 4:10 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Could be an IAT?
    1500 seems high. Dunno if high idle gets higher if it gets colder.
  24. Dec 24, 2022 at 4:21 PM
    Aerindel
    Aerindel New Member
    Montana
    Cars have been doing this since at least the 60s...my 67 VW has a bi-metalic strip that adujsts the idle speed mechanically for about a 1500 RMP when cold.
    I've never had a car that didn't do this.
    But I've also always lived in cold climates so its always been obvious.
    Be glad it automatically drops idle.
    On my cars all the way up to the 80s, if you didn't go back outside and tap the gas pedal after a while the idle would keep climbing as the car heated up and it would be out their wailing away a 2K after ten minutes or so.
    Used to be my 'job' when I was a kid and my mom was warming up the car....I felt very important running outside and getting to tap the gas pedal to drop it out of high idle.
  25. Dec 24, 2022 at 5:34 PM
    Good to know it just wasn’t my family that experienced this as well.
    We also had the screwdriver in the glove box to open up the carburetor throttle plate to get the car to fire up in case it was having problems.
    Aerindel[QUOTED], dondino and shifty` like this.
  26. Dec 25, 2022 at 5:08 AM
    bfunke
    bfunke Tundra Curmudgeon
    Both my 2018 and 2000 do that. It’s more noticeable on the 2018 because the engine is louder
    KNABORES and abcinv like this.
  27. Dec 25, 2022 at 6:36 AM
    Ditto.
  28. Dec 25, 2022 at 7:22 AM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    The high idle is very usefull in cold weather areas, your truck will warm up much faster, today when I drove the truck it was -6 degrees, I generaly have to warm my truck 5-10 minutes in the winter because I live so close to work.
  29. Dec 25, 2022 at 10:59 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    My 2006 is the same way.
    Struck me as odd at 1st, now I'm used to it.
  30. Dec 25, 2022 at 12:44 PM
    Aerindel
    Aerindel New Member
    Montana
    For what it's worth, it's not even so much about warming up the engine faster, its that cold engines have a hard time maintaining a low idle. Simple laws of physics at work here.
    Weagle and HBTundra like this.
