Lifted truck problems
Discussion in 'Suspension' started by Gfgneo, Nov 4, 2022.
  1. Dec 23, 2022 at 11:50 AM
    Gfgneo
    Gfgneo [OP] New Member
    California
    2021 tundra platinum
    Thanks ill look into that. For now ive just been using gps as well
  2. Dec 23, 2022 at 11:51 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm usually 3-5 mph off. I tend to keep my speedo around 65 if I'm supposed to be at 70.
    Gfgneo[QUOTED][OP] likes this.
  3. Dec 23, 2022 at 3:23 PM
    Gfgneo
    California
    Yea i did the same. Prior to the regear i was off by 5mph when i reached 70 due to the 35" tires.
  4. Dec 23, 2022 at 3:31 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    After re-gearing I was off by at least 10 mph
  5. Dec 24, 2022 at 1:51 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Odd. I was under the impression that our Tundras use wheel speed sensors to generate speedometer numbers. In other words, the speedometer doesn’t change when you regear.
    I went to 34” tires a year ago, and my speedo was obviously off because the tire diameter changed. I went with a RC speedometer calibrator to get it back to accurate, and eventually installed 5.29’s. Speedometer stayed the exact same, but I gained rpm at the same speeds.
    The only thing that doesn’t match is the displayed cruise control speed doesn’t match the speedometer. The RC calibrator doesn’t fix that…. So, if I’m going 65 and turn on cruise control, the CC reads about 60.
  6. Dec 24, 2022 at 2:17 PM
    Gfgneo
    California
    Does using the speefometer count as a tune and thus void the warranty?
  7. Dec 24, 2022 at 3:06 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If that is the case, then why is the calibration software using gear ratio and tire size for speedometer corrections?
  8. Dec 25, 2022 at 11:13 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    That’s a good question, but it may be a case of a somewhat generic software. Many vehicles read speed off the transfer case output shaft, so gear ratios would certainly make a difference. If I remember correctly, I was told to leave my gear ratio set to 4.30 after the gear change. This would explain why some folks see wildly different results after gears and calibrators.
    I’ll see if I can track down the thread where this was explained!
  9. Dec 25, 2022 at 11:21 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Like any warranty concern, they’d have to find a way to prove that the modification created the problem and caused a failure that you’d like covered under warranty.
    I don’t see how a speedometer calibrator could cause any warranty concerns. If the claim is for a part in the drivetrain, suspension, or steering, the larger tires that made a speedometer calibrator worth while would likely be a point of leverage for the dealer to use for claim denial.
    If your radio dies and they claim the calibrator caused it, I’d push back. Those two parts should not cause problems with each other. Same if it were your window switch.
    texasrho83 likes this.
