Wheel and tire question
Discussion in 'Wheels & Tires' started by BulldogDan, Dec 15, 2022.
  1. Dec 15, 2022 at 9:25 PM
    BulldogDan
    BulldogDan [OP] New Member
    Cement…Tundra #9
    My Tundra is a 2018 2Wd SR5 Dbl. Cab, no lift, Sumos in the back. I tow a 6500 lb travel trailer.
    I would like to purchase the SCS Ray 10s, 18”s which have a +25 offset. They are 9” wide wheels. According to BFG and Cooper’s websites I will need to step up to a 285 or 295 tire due to the 9” width of the wheel. The max wheel width for a 275/70/18 is 8”. Will the +25 offset allow me to run the 285/70/18 K02s or the Coopers without some sort of lift at the front end to prevent rubbing on the UCAs…and will I need a body mount chop?
  2. Dec 16, 2022 at 6:20 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    That would be incorrect. 275/70-18s are can be used with wheels 7 or 8 to up to 9.5 wide. Hit tirerack or discount tire websites and look up the tire you want, in the specs it will show what wheels widths will work. I checked BFG in 275/70 and it shows 7 to 9.5 wide wheels.
    275/70, 285/70 both fit stock trucks with stock wheels, no lift or UCA needed. If you change out your wheels to +25 offset, will still work but you will probably need to remove air and mud flaps, or trim them.
  3. Dec 16, 2022 at 7:22 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Yes there are guys on here with 275/70/18’s with SCS wheels and they are fine.
  4. Dec 17, 2022 at 1:34 PM
    brevard828
    brevard828 New Member
    2021 Limited TRD Off Road
    I’m running 275/70r18 on method wheels with a 25 offset. 5100’s middle setting. 0 rub and I tow my camper. Prior to leveling I had those exact tires on the stock wheels. No issues.
  5. Dec 24, 2022 at 7:10 AM
    brigand80
    brigand80 New Member
    Roman
    2017 Limited CM MGM 2WD
    Its Always A Work In Progress...Because Its A Labor of Love!! - aFe Pro Dry Filter + TRD Intake Flow Accelerator + Carbon Filter Delete - nFab Podium Steps - TRD Rear Sway Bar - TRD Pro Grill - Color Matched Hood Bulge, Front Bumper End Caps, Mirror Caps, Door Handles - Nightshade "Limited' Badges & Others De-badged - NSV LED Lightbar - Desert Eagle Offroad Catalytic Skid Plate - Craven Speed Untenna - Diaz Fabrication TEQ Trailer Hitch Cover - Klearz 3rd Brake Light Smoked Lens - Winjet Renegades Smoked Tail Lights - Headlight Revolution GTR Lighting LED Bulbs - Morimoto 4 Banger HXB LED Fog Lights (White) - XD 847 Outbreak 18x9 +12 5x150 - Gorilla Black Spline ET Lugs - AJT TRD Key Fob + Interior Chrome Delete Kit - TRD Shift Knob (Black) - JimmyRigged ToYoda Steering Wheel Emblem Overlay - JRT Tech 12 Front Dash JL Audio Speakers - K&N Cabin Filter - Chalk Bag Mod - Weather Tech Mats - Ceramic Window Tint
    Also, use the to analyze different sizing options
