Opening a sealed-top, broken handle and mech.rod tailgate at the LATCH?
Discussion in '2nd Gen Tundras (2007-2013)' started by hokiruu, Dec 4, 2018.
  1. Dec 4, 2018 at 10:56 PM
    hokiruu
    hokiruu [OP] New Member
    Truckee, CA
    07 Tundra
    Kings, LR UCAs, Coachbuilder shackles, 35x12.5 Ridge Grapplers, Demello front bumper, Comeup Seal 12.5 RS winch, LED ditch and fog lights, some hacked stock parts for clearance
    I have a ridiculously inconvienient and clusterf*cked problem with my tailgate. Sorry it's a bit hard to explain...
    I have a Truckboss snowmobile deck on the bed. It clamps down onto the top of the bed rails, is sealed all around and with legs into the bed floor (to support up to 1000+ lbs of deck and snowmobiles, it is a 7-hour installation to get it ON, there is NO WAY to get it off without opening the tailgate, so please don't ask if I can remove or lift it)... aaand it has my snowmobile on top of it. The ramp that I need to unload the snowmobile is under the deck, in a tray, behind the stuck tailgate.Yes, I know I can find another way to unload it but that is not the point, I need to get the tailgate open, period.
    A few days ago on a trip to Mammoth in the parking lot in 19* weather, the plastic handle on the tailgate snapped off, locking me out of the bed. Tried cutting into the plastic with all the tools I had, to no avail. No professional services could or would help me get into it.
    I went home, and drilled and cut out the plastic valence where the tailgate handle assembly is housed. Using pliers and a screwdriver I was able to rotate the handle/latch push/pull rod assembly and open the tailgate. I had to load up my sled and drive (snowmobile riding and filming commitment), and closed it to do that. Then the actual rod assembly fell off of the bed side end of the tailgate, into the tailgate. To be clear, the handle, center of the tailgate mechanism, is now 100% useless and my battle is entirely with the latches at the ends where the tailgate latches to the bed sides, with no push/pull rods to release them.
    So now the latches at the end of the tailgate sides/bed side latches are closed, around the square "loops", D's, horseshoe latches whatever you want to call them, and I cannot disengage them from the inside of the tailgate anymore. I was able to get the tailgate slightly ajar (like halfway, 1 out of 2 clicks open), but not all the way. There is about a 1/4- a gap between the tailgate and bedsides and I can see the latch and fit tools into it. I spent some time trying to pry the jaws of the latches. One very un-helpful locksmith I took it to said there is no possible way to open those without being inside the bed or tailgate. Before I spend any more time trying, I want to know whether this is even a possibility.
    The last resort would be to drill into and cut open the tailgate skin metal to gain access and reconnect the latch pull rods, destroying the tailgate.
    Before getting that extreme, does anyone have any experience with this, think or know whether it is possible to release the latches from the gap between the bedsides and tailgate?
  2. Dec 4, 2018 at 11:01 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Oh, man. I can visualize exactly what you’re up against. I’m gonna go open my tailgate and see if I have any ideas.
    15whtrd and hokiruu[OP] like this.
  3. Dec 4, 2018 at 11:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Other than trying to "fish" with some sort of thin, J-hooked rod, I got nothing. Good luck, sounds like serious test of patience.
    joonbug, 15whtrd and hokiruu[OP] like this.
  4. Dec 4, 2018 at 11:08 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Wow, I’m sorry. Fresh out of ideas here.. so is the entire handle and mechanism off the tailgate, meaning there is an open hole there? I’m guessing you’ve tried fishing something in there like a coat hanger to reach the latches on the inside?
    hokiruu[OP] likes this.
  5. Dec 4, 2018 at 11:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    After looking at mine, I’d say that this is possible, but it might try your patience. You’ll want a 90degree pick. Something like:
    Working through the gaps between the tailgate and the bedsides, you need get in above the loop attatched to the bedside and push each latch upward. It doesn’t look easy, but I do think it’s possible from the 1/2 latched position you’re in.
    KnuckleHD, 831Tun and hokiruu[OP] like this.
  6. Dec 4, 2018 at 11:16 PM
    hokiruu
    Truckee, CA
    07 Tundra
    Wow, way more replies way faster than I expected, thanks, what a great community. If someone could try to post a pic of their latch on the tailgate side and as it closes around the rectangular "rings" on the bed sides of the tailgate opening, it might help me understand if this is possible and how.
  7. Dec 4, 2018 at 11:16 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Worst case scenario, it might be cheaper to cut the cathes/ D-ring things, than to cut into the tailgate?
    joonbug and hokiruu[OP] like this.
  8. Dec 4, 2018 at 11:17 PM
    hokiruu
    Truckee, CA
    07 Tundra
    Yes, that is exactly what I have been dicking around with for hours, although the pick I have been using is pretty small. I also tried various hex keys but most are too short, and the longer ones too big diameter. Maybe I can get a bigger pick or make a tool in my shop...
    landphil[QUOTED] likes this.
  9. Dec 4, 2018 at 11:18 PM
    hokiruu
    Truckee, CA
    07 Tundra
    Hey you might be onto something here!!!
  10. Dec 4, 2018 at 11:19 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Here’s a poor picture in the dark of the passengers side. My key is pointing to where you need to push upward.
    I’m sure I can take better pictures in the daylight tomorrow if you need.
  11. Dec 4, 2018 at 11:23 PM
    hokiruu
    Truckee, CA
    07 Tundra
    Thanks Phil! You're awesome! I’ll hold on on cutting metal a bit longer. I am all out of beer... that usually helps
  12. Dec 4, 2018 at 11:38 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I took a few more pictures with a light. Not great, but better.
    The piece you need to push upward is beside the little coil spring (its dirty and doesn’t look much like a spring) to the “outboard” end of the spring, right above the larger swinging jaw. Again, these are all the passenger’s side, the driver’s side is the same but mirrored. You’ll need to push upward there as well.
  13. Dec 4, 2018 at 11:47 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I drew an arrow right where you need to push upward with that pick.
    KnuckleHD and hokiruu[OP] like this.
  14. Dec 5, 2018 at 12:10 AM
    hokiruu
    Truckee, CA
    07 Tundra
    One side open...!
    landphil, 831Tun and KnuckleHD like this.
  15. Dec 5, 2018 at 12:51 AM
    hokiruu
    Truckee, CA
    07 Tundra
    Success with a new approach! I feel like an idiot. I should have removed ALL the handle area plastic sooner, but didn’t because I didn’t want to damage the backup camera or lock, or risk drilling to the metal. Eventually after hours of messing with a too-small pick, I decided to say f it and drilled and cut more plastic, ripped it all out, and could now fit my hand comfortably into the hole without many more cuts from plastic, place and shine a headlamp inside the tailgate and with a mirror, see the latch from inside the tailgate, and not actually re-connect the rod, but still pull the latch with it. It still took quite a few tries to get it, but it worked!
    HUGE thanks to you @landphil ! I greatly appreciate your generous time and help.
    Forensics:
    The real culprits for this problem were:
    - Cheap aftermarket plastic handle assembly that came with an aftermarket backup camera (which never worked after the first 3 times)
    - 19 degree weather making cheap plastic brittle (shouldn't be a problem, but it was)
    - Bedliner overspray on the push/pull rods. Apparently enough overspray can get between the cracks on the tailgate and onto the rods, adding texture and friction. It was like this when I bought it.
    If you ever add an aftermarket backup camera, maybe try to use OEM handle assembly even though it costs 4x as much, not the supplied one and if you have or get bedliner, make sure your push/pull rods are still smooth afterward.
    It just might save you a ski/snowboard/snowmobile trip, many hours of frustration, and some money.
  16. Dec 5, 2018 at 4:30 AM
    Dr_Al
    Dr_Al New Member
    Al
    The stock handle on my 07 seams kind of weak so I can only imagine what an aftermarket one would feel like. Before putting it back together I would clean everything up, remove any extra bedliner, and put some grease on it.
  17. Dec 5, 2018 at 4:41 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Broke my handle last year as well. Glad you got it open.
    When I installed the new handle I soaked everything with a heavy silicone lubricant. Latches, rods, plastic, everything. It feels better than new now. I think the problem is there is a lot of resistance on a lot of surfaces and the plastic arms on the back of the handle just can't take it.
  18. Dec 5, 2018 at 4:50 AM
    15whtrd
    15whtrd Mr. Blonde
    I read the story and then saw there was a good ending! Glad you got it open!
    hokiruu[OP] and 831Tun like this.
  19. Dec 5, 2018 at 10:05 AM
    hokiruu
    Truckee, CA
    07 Tundra
    Thanks everyone. I will be replacing the arms entirely, and keeping them lubed.
    831Tun and 15whtrd like this.
  20. Dec 8, 2018 at 9:58 PM
    Walton
    Walton New Member
    Appleton, Wi
    2010 5.7L FFV LTD CrewMax
    Glad you got it open! I just broke my handle in 20 degree weather. Really am tempted to machine one out of aluminum.
  21. Nov 13, 2020 at 6:03 PM
    Dickey
    Dickey New Member
    Katie
    Spring, TX
    2008 tundra dc 2wd and 2011 tundra cm trd 4x4
    How did u get it open? I have the same problem but it’s all the way closed
  22. Nov 13, 2020 at 6:04 PM
    Dickey
    Dickey New Member
    Katie
    Spring, TX
    Bed is full and has a camper shell
  23. Dec 23, 2022 at 5:52 PM
    EnielsA
    EnielsA New Member
    EDMUND
    2019 Toyota tundra 1794 crewmax 4x4
    So I got a 2019 tundra 1794 4x4 with the hard top cover. I am also locked out of bed. Here in Charlotte and we are having first freeze of season but Taking the family to celebrate chriat.as at beach tomorrow and trying to figure out how to open. I got a heat gun and was playing g with heating g up as seems like this happe s I cold weather but where would I heat. Any other suggestions appreciates.
  24. Dec 23, 2022 at 5:54 PM
    EnielsA
    EnielsA New Member
    EDMUND
    Handle hasn't broke I can take it all the way up and feels like just not catching g or something. Help me get this open and functional.
