  1. Dec 22, 2022 at 9:54 AM
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Is that color & finish on your rims stock/OEM? Or did you get a gloss finish put on them? Looks great.
  2. Dec 22, 2022 at 10:00 AM
    Bergy24
    Bergy24 New Member
    Looks like the trail edition wheels which come glossy from factory. Notice the grille surround is color matched but it has the limited insert, that's a clear give away for the trail edition, Unless you have someone like me who swapped the chrome surround from my limited and replaced it with a colored matched surround, and swapped my limited insert. IMG_9608.jpg
  3. Dec 22, 2022 at 10:08 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Your cat eats fancy shit!
  4. Dec 22, 2022 at 11:00 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Just had a random thought - I have bare aluminum cat shields from Valhalla under the truck. Should I be concerned about galvanic corrosion between it and the frame? I'm guessing since the frame's painted the chances are pretty low, but just thought I'd ask you fine folk.
  5. Dec 22, 2022 at 11:05 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    They look like the OEM rims that come on the Trail Edition. They are a dark gray color.
  6. Dec 22, 2022 at 11:06 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    ... "Meow", I guess?
    Tundrastruck91 likes this.
  7. Dec 22, 2022 at 11:28 AM
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
    Not the sexiest of mods, but I installed a VoltSafe magnetic connector for my block heater. A whole lot easier than fighting with the plug in cold weather.
  8. Dec 22, 2022 at 11:47 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I had my truck fluid filmed before mine were put on. Mine are aluminum I don’t see it causing any corrosion.
    HulkSmurf14 likes this.
  9. Dec 22, 2022 at 12:23 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Which one did you go with and can you snap a photo of this awesomeness?
  10. Dec 22, 2022 at 12:24 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I removed my Coachbuilder +2 shackles and cranked up my RAS to the black disc. Back to factory 2" of rake.
  11. Dec 22, 2022 at 1:55 PM
    Anohibian
    Anchorage, AK
    A82D50BC-D8B4-46ED-BB45-ABD01A7A8C11.jpg 6B131CDA-E95C-4EDA-993B-9C998404850F.jpg 9DB4AD18-2112-45B4-9123-41E4502FDF69.jpg
    It just plugs into the standard three prong plug on the stock block heater. They it just attaches with magnets. Keeps you from accidentally breaking anything if you forget to unplug before you drive off.
  12. Dec 22, 2022 at 3:09 PM
    HulkSmurf14
    2014 Tundra Limited
  13. Dec 22, 2022 at 3:48 PM
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Damn., has to look like a UFO rolling through the mountains!!!! Love it! Sorry about the damage..
    Cthulhu[QUOTED] likes this.
  14. Dec 22, 2022 at 5:46 PM
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    35x12.50x20 Trail Grapplers
  15. Dec 22, 2022 at 5:49 PM
    Cthulhu
    Thanks! Hardly ever use them as not to blind anyone, except when drivin’ in the gubmint woods to see them mofo whitetails! Them lights have saved me hittin’ one of them sumbitches at least a dozen times…
  16. Dec 22, 2022 at 6:44 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    That's pretty slick. At what temp do you feel the block heater is needed? I haven't experienced temps too low since I bought mine.
  17. Dec 22, 2022 at 6:51 PM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Changed out the shift knob with an Amazon special. I’m actually surprised with the quality of it, for it only being $30. I was fully expecting it to feel like Chinese crap and returning it to Amazon the same day.
    Before:
    After: upload_2022-12-22_20-50-27.jpg
    I also got an ESR mag lock phone case and “wireless” charger. This is a pretty good setup too. Next step, is to find a way to mount it to the RAGO dash plate.
  18. Dec 22, 2022 at 7:17 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I hope you have better luck with your Amazon knob than mine! Mine turns every time I touch it and it makes me a little OCD twitchy sometimes when it's not on straight - I need to try a little PTFE tape or somesuch
  19. Dec 22, 2022 at 7:19 PM
    dherring256
    2018 MGM SR5
    Fuzzy Dice
    Messing with it a bit, it seems just as sturdy as the OEM one was. This is the one I got: https://a.co/d/6DpgL62
    MedCityMoto[QUOTED] likes this.
  20. Dec 22, 2022 at 8:26 PM
    Anohibian
    Anchorage, AK
    I’ll usually plug in if the temps are forecasted to be below 0F.
    the red[QUOTED] likes this.
  21. Dec 22, 2022 at 9:29 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I mounted mine in the same place. I also got this. Makes it look a little better IMHA.
    https://store.switchpros.com/rcr-touch-8/
    cartage1 likes this.
  22. Dec 22, 2022 at 11:32 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
  23. Dec 23, 2022 at 3:13 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    You could try a little medium strength (blue, I think) loctite on the threads. That's what I did so my RW Tomahawk would stay put.
  24. Dec 23, 2022 at 4:05 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    I don't have the Amazon shift knob. But, the knob I have was loose after I had the truck detailed and tightening it left the knob pointed in the wrong direction. I mounted a nut on the shifter and adjusted the nut until the shifter stayed tight and was in the right direction. The nut was small enough to allow the shifter to slide on over it. I hope this helps.
  25. Dec 23, 2022 at 4:30 AM
    MedCityMoto
    Happen to remember that thread pitch/size off the top of your head? That's a great idea
    NewImprovedRon likes this.
  26. Dec 23, 2022 at 4:38 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    I'm sorry but I don't. I tried several that were loose in my tool box until I found the right one.
    MedCityMoto likes this.
  27. Dec 23, 2022 at 4:40 AM
    MedCityMoto
    Google says it's M12 X1.25 and that sounds reasonable enough to me, I have a couple stainless of those for sure. Thanks for the idea overall!
  28. Dec 23, 2022 at 5:48 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Drove West to visit family yesterday. Right through the “winter storm of the century”. It was not that bad. I did see a few cars in the ditch along the side of the highway, but the worst part about it was the extremely gusty headwind I drove in for 10 hours. There’s more salt than snow or ice on the roads.
    As a friend of mine put it, “true, it’s -25ºF windchill. But it’s a dry -25.” Lol.
    Also saw this faint halo rainbow:
    Wallygator, 1794TX, TK1979 and 14 others like this.
  29. Dec 23, 2022 at 6:14 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I am SO glad I don't have to worry about this!
    texasrho83, PomDad, ATV25 and 3 others like this.
  30. Dec 23, 2022 at 7:32 AM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Does this color scheme have a particular meaning? Im thinking of getting it because I like it, but not sure if it stands for something. Google was no help
