Rear Shocks, What a Bee-Och
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Dec 21, 2022.
  1. Dec 21, 2022 at 12:27 PM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Tundramen,
    Spent 2 half days fighting with these factory shocks on back.
    The ONLY thing that worked was to use my Dremel tool.
    Had to use a cut off wheel. About 3/4 of an inch around the circumference, needed
    Cuts into the chrome shaft. After that and a MF of a time squeeze my Vise Grip pliers.
    FINALLY got the shaft to quit spinning. It took some time to cut into the shaft to make
    Enough friction for the Vice grips to bite into. If you are planning this anytime within the next century, get some penetrating oil on those nuts and bolts.
  2. Dec 21, 2022 at 12:30 PM
    Mine are still sitting in the corner waiting for an install one year after I put on the fronts. At least my bed bolts are removable.
  3. Dec 21, 2022 at 2:36 PM
    Aerindel
    Aerindel New Member
    Montana
    Luckily, the WEEK before I did mine, I inherited a snap on pneumatic reciprocating saw, which just barely fit between the frame and the truck bed and was able to cut off the nuts, only took about half an hour of sawing for each.
    Jack McCarthy likes this.
  4. Dec 21, 2022 at 2:48 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I ground two flat spots into the shaft of each rear shock with an angle grinder and a grinding stone. That let me get enough grip on them with vise grips to remove the nut on top.
  5. Dec 21, 2022 at 2:54 PM
    Only one blade required for both?
  6. Dec 21, 2022 at 3:16 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    BMF's and snowbobs shocks didnt put up any fight.
    bmf4069 likes this.
  7. Dec 21, 2022 at 3:35 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Oddly enough, I removed 2 dead shocks. They were KYB brand. Thought only Bill-Stumps were fitted
    To these Tundras.
  8. Dec 21, 2022 at 3:41 PM
    NWPirate
    Zach
    WA
    Same here, worked out great.
    FrenchToasty and Tundra2[QUOTED] like this.
  9. Dec 21, 2022 at 4:19 PM
    Aerindel
    Aerindel New Member
    Montana
    Yep. Exactly.
  10. Dec 22, 2022 at 4:40 AM
    Yeah, I don't understand that one.
    shifty`, Jack McCarthy, txagg and 3 others like this.
  11. Dec 22, 2022 at 5:12 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  12. Dec 22, 2022 at 6:26 AM
    My 2000 FGT had KYB shocks all around when I bought it. It’s the TRD off-road version with the progressive front coils.
  13. Dec 23, 2022 at 8:03 AM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    That’s pretty normal on older vehicles. At the shop I work at we usually just end up grinding them off anyway. Too much time involved with trying to break the nut free with it spinning.
  14. Dec 23, 2022 at 12:16 PM
    Black
    2014 Tundra Limited CrewMax
    I just split the nuts.
    Had to do it on my Tundra and Buddy’s Tacoma.
    KNABORES and shifty` like this.
  15. Dec 23, 2022 at 12:22 PM
    Jbhoops
    Jbhoops New Member
    2001 tundra access cab
    Just did.mine yesterday super easy but im.in California
