  1. Dec 17, 2022 at 4:41 PM
    Jim Kowalski
    Jim Kowalski New Member
    Southwest, USA
    2010 Tundra 4.6L 2WD
    Truck is new to me, and it has 151,000 miles, did the following the past couple of days:
    spark plugs (Denso SK20HR11) torque to 15 ft/lbs
    new air and cabin filters
    changed differential fluid
    new wiper blades
    center carrier bearing had a torn rubber support, so new carrier bearing and replaced all 3 U joints, replaced the transmission output seal while drive shaft was removed.
    brake fluid swap and bleed brakes
    inspected brake pads
    engine would produce a high idle and quite a bit of steam type exhaust on cold startup, replaced PCV valve and hose, old valve was overdue and was sticky when shaken. When replacing PCV valve plan on using a new PCV hose as these hoses get so stiff. 22mm deep set socket is needed to access the valve on the front of the intake.
    both headlamps were fogged, could not polish out so new fog and headlamps installed with diode dynamics bulbs in the headlamps.
    replaced both battery terminals with OEM Toyota terminals
    coolant and engine oil recently changed so just inspected.
    dropped transmission pan and put new trans filter in and did a pan only transmission fluid change (Toyota WS), followed the directions in this video and was able to successfully use the dash light to check and adjust the transmissionfluid level at the proper temperature:
    https://youtu.be/fLVZSoKbyZ0
    test drove and it drives very nicely.
    georgiey22, chugs, TheBeast and 7 others like this.
  2. Dec 17, 2022 at 4:54 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Welcome Jim K from the rust belt. Where you located, any pics?
  3. Dec 17, 2022 at 5:46 PM
    Jim Kowalski
    Southwest, USA
    Located in the Southwest, I will have to snap a few pics.
  4. Dec 18, 2022 at 5:38 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    He just dropped the trans pan for a quick service... Without shearing several thru-bolts.
    Did you even need to ask from what part of the country he hails?? ;):D
    joseph_womack likes this.
  5. Dec 18, 2022 at 6:12 AM
    COTundie
    Trey
    Pretty things
    Last week did a paracord wrap to all FOUR, front and rear grab handles. Completely neglected to notice the remaining single above the passenger door. My wife was quick to point out her preferred "oh shit handle". But the rest look great, feel great, and provide a total of 50ft of 'quick release' cord if needed.
    Shouldn't have waited so long
    Yesterday I got to fix my blinkers.. for the second time. Damn Morimotos. If they didn't look and perform so awesome...
    Couple months back I had the passenger, sequential blinker dissappear. Turned out to be a resistor which had disconnected itself under the wrapping of one harness. Fixed it.
    Then last week I lost ALL of the vehicles blinkers. Figured it had to be my handy work, so I removed the passenger Morimoto (breaking a tab for the second time) only to still blow fuses. Moving on to the driver side Morimoto, I found a small, intermediate harness which looked a bit melty. The harness had cut thru the insulation for a couple wires.
    Luck would have it that I had an appropriate 18ga, waterproof harness to replace the nasty (tho I could have just soldered the leads together and done away with the harness).
    I lost most of my 3 hour window fixing electrics and broken headlight tabs, but maybe there will be time for oil and tire rotation today. Still have to try out my new lifting bar (just wouldn't pick the rear tire anymore with the 2x6 chunk)
  6. Dec 18, 2022 at 6:21 AM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    Got some rims off Facebook and some snow tires, the stock tires on my TRD rims were junk in the snow this year, too many miles. Still got tread on them for a summer or two.
    26A48593-0688-4C62-AF25-9DC0291A01AC.jpg 30B651CE-133B-486E-A18E-E5880EDC4C61.jpg
  7. Dec 18, 2022 at 1:39 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Bought a Powerstop OE spec brake pad and rotor kit from Rockauto this week. Why, oh why did I not check the contents when it landed on my doorstep on Thursday?
    Ergo, today I replaced the front rotors and pads, hopefully they'll sort out the missing hardware for the rear pads and I can do those next week. :rolleyes:
  8. Dec 18, 2022 at 7:31 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Looks great! I wrapped my steering wheel with the paracord and love it, never did wrap the oh shit handles. Do you have a video on the knot style you used? I forgot how I did the steering wheel
  9. Dec 19, 2022 at 5:55 AM
    COTundie
    Trey
    Pretty things
    Beep, boop, beep....
    https://youtu.be/9aprLqv2GqQ
    Pretty quick to wrap. Really quick to unwrap.
    I got between 13 and 14 feet on each grab handle. I removed the handles to ease the process of wrapping them.
  10. Dec 19, 2022 at 8:09 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Would you mind sharing the part number and any install info for the intake accelerator, would really like to jump on this mod? Thank you for sharing!
    AZEric[QUOTED] likes this.
  11. Dec 19, 2022 at 11:07 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  12. Dec 19, 2022 at 1:03 PM
    Jorgesworld86
    Jorgesworld86 New Member
    Orange County,CA
    2013 Tundra Limited Rock Warrior
    Gave the truck the morimoto face lift. Got the headlights for $765 shipped and the fogs for $180 shipped. Now let’s see how long they last. Love how it refreshed the look.
    D4x4TRD, dondino, aelarson and 10 others like this.
  13. Dec 19, 2022 at 1:23 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Looks great! Where did you get the lights for so cheap?
    dondino likes this.
  14. Dec 19, 2022 at 1:32 PM
    Jorgesworld86
    Orange County,CA
    dondino, chugs and Tipsovr like this.
  15. Dec 21, 2022 at 11:05 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Each day I make a bit more progress on front.
    So far I’ve replace bumper, installed, wired, and semi-tested the winch (main priority)
    Just finished grill, next are the other trim pieces and then I gotta cut the skid plate again. Oh, I still gotta wire all the lights in but I plan to add more so I’ll save it for later, plus it’s lower priority at the moment.
    Where I’m at today…
  16. Dec 21, 2022 at 11:30 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    got #3 fuel pump installed starting to lose faith in this rig 78,500 miles..
    dondino likes this.
  17. Dec 21, 2022 at 12:47 PM
    COTundie
    Trey
    Pretty things
    What brand fuel pumps are you using?
  18. Dec 21, 2022 at 3:13 PM
    zeekevin
    zeekevin New Member
    flexfuel model?
  19. Dec 21, 2022 at 5:59 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Pulled the driveshaft that I just had rebuilt and balanced.....It's not right so it's going back next week to try again.
  20. Dec 22, 2022 at 5:13 AM
    Fiesta346
    PA
    2013 Rock Warrior
    non flex fuel and i never run it on E, my first one failed i went aftermarket that one failed back to factory now
  21. Dec 22, 2022 at 5:51 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Got some new shoes for the old truck. Cooper Discoverer Rugged Treks. I only have about six miles on them but they are already a vast improvement over the nearly bald Kuhmos that were on there.
    Edit- Now have a couple hundred miles on them. Really like these a lot. I've had BFG's on a Tacoma and Landcruiser and these feel much better than those.
  22. Dec 22, 2022 at 6:07 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    You may be aware, but this guy is a wizard
    omgboost likes this.
  23. Dec 22, 2022 at 6:18 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Replaced the EBC slotted rotors I just put on with stock OEM. Not sure if anyone else read my brake thread, but started to get some serious vibration pretty quickly, and I couldn't tell any issues as I would expect - bedded in properly, I'm old enough to drive like...well...and old person, etc. They tested the run-out and all came back at .006" or more. They were concerned with machining them (truth be told, they said they won't do slotted to begin with), but the thickness was already questionable and they've had a lot of slotted rotors with issues.
    $660 later I've got new OEM rotors all the way around and the shudder is gone...hopefully for good.
    WVI, georgiey22, Filthyphil and 6 others like this.
  24. Dec 22, 2022 at 6:22 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Good to know...and you can get yourself a nice quilt while you're there!!
    I've only been to Paducah once, but I know they have moonshine and quilts. :D
  25. Dec 22, 2022 at 8:11 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    @Trident , I am now! I wish I found him when I was looking.
    That's only about an hour from me.
    The NAPA guy beat the crud out of one of the yokes...
    Thanks for the info.
  26. Dec 22, 2022 at 10:41 AM
    joseph_womack
    Joe
    Louisiana
    Things always seem to happen last minute when I need to get somewhere…
    replaced a wheel bearing/hub
    D4x4TRD, dondino, Prostar 190 and 7 others like this.
  27. Dec 22, 2022 at 3:54 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    You're very welcome
    WVI[QUOTED] likes this.
  28. Dec 22, 2022 at 4:19 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I filled up with cheap gas in Ohio. Pa-3.79 Oh 2.59 a no brainer as its only 13 miles to Ohio from my house.
  29. Dec 22, 2022 at 9:15 PM
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    Which ones did you replace them with?
  30. Dec 22, 2022 at 10:09 PM
    joseph_womack
    Joe
    Louisiana
    Originally a dorman 2 ish years ago, that one basically disintegrated, we couldn't get any Moog ones at my shop so I just went with Napa brand instead, my boss said its way better
    Ohannon7 likes this.
