0 offset and 35's question. Help
Discussion in 'Wheels & Tires' started by bmw345, Jun 22, 2022.
  1. Jun 22, 2022 at 5:12 PM
    bmw345
    bmw345 [OP] New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I have been running 285/70-17 KO2's now for about 1500 miles on 17" Methods with 0 offset. Had slight rubbing with the 285's but nothing major. 2.5 inch lift in front and plus 1 in the rear Fox TRD Pro set up. I just snagged a set of brand new 35x12.5x17 Toyo AT3's off of Facebook Market place and I want to upgrade as soon as possible. My question is will I be all set by removing the Mudflaps and I also have the Coach Builder front bumper shims which will free up a solid 1/2". These mods will be done before mounting the tires. Anyone have a similar setup. Pics of truck with 285's for reference! 1E97F9E9-DCA7-494C-9D1F-32F2A1296F55.jpg229C8BAD-4486-4045-A6A2-6AB254F14F5A.jpg
  2. Jun 22, 2022 at 6:30 PM
    DPhung
    DPhung Measly Mechanic
    North AL
    2016 MGM Tundra CM
    Not the exact same lift setup but I’m running 3” up front with zone UCAs(wanting to upgrade to SPC)on method 17s 0 offset with Falken 35x12.50 and I get a slight rub even with a BMC.
    bmw345[OP] likes this.
  3. Jun 22, 2022 at 7:30 PM
    bmw345
    CT
    Dang! Wanted to avoid the BMC
  4. Jun 23, 2022 at 6:35 AM
    DPhung
    North AL
    2016 MGM Tundra CM
    It’s not a bad rub, it’s like only in reverse at full lock and hitting like a bump. But I also have 3” up front with the Zone UCAs that I believe have built in +3 caster.
    bmw345[QUOTED][OP] likes this.
  5. Jun 27, 2022 at 9:50 PM
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    I have 35x12.50s on 0 offset methods, I did BMC, trimmed some of the plastic on the rear of the fender wells, and removed the front lower plastic piece, also trimmed the bottom of the front bumper back at an angle. It will stuff to the bump stops with no rub. I think all of that is necessary to fully cycle the suspension on that setup.
    bmw345[OP] and joonbug like this.
  6. Jun 28, 2022 at 8:31 AM
    bmw345
    CT
    good to know. I will know for sure tonight. My guy removed the mudflaps and installed the coach builder bumper shims plus did the front liner mod by pushing it in and re bolting it in. 35’s go on this evening. Hopefully not much rubbing! Im excited!
    SAGE63 likes this.
  7. Jun 28, 2022 at 9:03 AM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    I had to get a BMC to squeeze my 35's. Its really not as bad as your mind takes you in the thought that your cutting the truck. But you may rub more cause of the 0 offset. I have 25mm offset right now and have zero rubbing with a BMC and so minimal trimming on the front of the wheel well.
  8. Jun 28, 2022 at 9:27 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I have 35s and zero offset and didn't have to get a BMC. I did have to get my bumper trimmed. That could have been solved with bumper shims.
  9. Jun 29, 2022 at 4:59 PM
    bmw345
    CT
    35's fitted, very slight rubbing toward full lock, I can live with it. Looks Wicked with 35's! Few pics! 08D19853-68A7-457F-87F7-3BC1B0318ED1.jpgCD274645-9BF5-4317-BB44-A3A7E98FE7FF.jpg
  10. Jul 1, 2022 at 9:02 AM
    Superbsdad
    Superbsdad New Member
    Josh
    Ohio
    2016 SR5 TRD OR
    No bmc needed? Can you post some close ups of where you are rubbing and how much clearance between the front bumper since it’s moved?
  11. Jul 1, 2022 at 9:16 AM
    The Tundra in its natural habitat…… feeding again.
  12. Jul 2, 2022 at 6:46 AM
    bmw345
    CT
    No BMC for now. I just drove 200 miles after the install and all is well. I am on vacation. I will snap some full lock pics when I can. Right now I only get some rubbing when backing up and turning the wheel! But it’s not bad.
    Superbsdad likes this.
  13. Jul 2, 2022 at 6:51 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    You’ll need a BMC and lots of caster.
  14. Jul 2, 2022 at 7:04 AM
    Trust86
    Trust86 New Member
    2007 DC
    2.5” level with zone UCAs. Only running 3.5 degrees of caster, with 35s, no BMC, no rub. All about offset and caster. I’m running icons 17x8.5+25.
  15. Jul 7, 2022 at 9:29 PM
    Okierunner
    I’m running 0 offset and normal caster with icon ucas. All in spec. No issues. Full bump no rub. And real 35s, not a 305/55/20 or a BFG 35. People way overcomplicate this topic.
  16. Jul 7, 2022 at 9:30 PM
    Okierunner
    Looks killer! Toyo at3?
  17. Dec 20, 2022 at 7:23 PM
    WildatheartTundy
    WildatheartTundy New Member
    Joe
    2022 SR5 TRD Off Road
    How????? Just put falken 35s with 17 methods 0 offset with a Icon stage 5 suspension. Rubs just a bit.
  18. Dec 20, 2022 at 9:47 PM
    Okierunner
    Body mount chop, removed plastic trim piece behind bumper, trimmed back of the bumper at an angle, good to go!
