  1. Dec 20, 2022 at 10:39 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    What is this piece called? Somehow it went missing.
  2. Dec 20, 2022 at 10:40 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Bedrail stake pocket but I couldn’t find the covers and had to buy new rails
    robabeatle[QUOTED] likes this.
  3. Dec 20, 2022 at 10:48 AM
    Back to cap less?
  4. Dec 20, 2022 at 10:51 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My trans temp on my 25 mile drive to work is 110 degrees. I checked the lines going to the radiator and then to cooler to see if somehow the radiator portion was bypassed, but it all looks normal. Any ideas why the radiator isn't warming up the trans fluid?
    Should I be worried or leave it alone? I have over 300k miles on the original transmission so it's obviously worked so far.
  5. Dec 20, 2022 at 10:54 AM
    Your fine, we have the inner and outer cooler on our trucks so the trans temp is very slow to rise in temperature.
    txagg likes this.
  6. Dec 20, 2022 at 10:57 AM
    robabeatle
    AZ
    Yeah, I am capless for a while now. Ill put in on when I get back on the road for a while.
  7. Dec 20, 2022 at 11:35 AM
    That would be nice, but if I did it myself, I would probably opt to just use vinyl unless it can’t be near the exhaust manifold like it is there. Dude seems to have tossed out the thermal insulator on the old line and didn’t reuse it for the new one.
  8. Dec 20, 2022 at 11:38 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I meant for adding an extra gallon of capacity. Make the low level light reach an extra 18 miles.
    Tundra2 and Jack McCarthy like this.
  9. Dec 20, 2022 at 11:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Wouldn't that also reduce your fuel pressure, and cause running issues?
    Unless you upgraded the fuel pump to a high flow?
  10. Dec 20, 2022 at 11:48 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'd imagine the pump runs to meet a pressure, and it might take a hair longer, i'd doubt it would be enough to confuse the computer. Imagine a fuel line with a giant fuel filter, but with less of a pressure differential on each side.
    the fuel system would still be running the same size injectors. And air bubbles while running empty would travel down the line slower.
  11. Dec 20, 2022 at 11:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  12. Dec 20, 2022 at 12:11 PM
    Stake pocket cover and/or per the parts catalog, Truck Bed Molding Cap. (link)
    I had to buy one. All it did was expose how badly dried out/greyed my rails are.
    No need to buy new rails, this is an easy-to-lookup part in the parts catalog, and only ~$4.50 when I bought mine.
    PS - I dunno why it says "right rear" or whatever. This is the exact part I bought and it fit both driver side stake pockets.
  13. Dec 20, 2022 at 12:14 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    get a fresh universal pair of plugs that have tie-downs attached. Trim the feet to fit.
    NUDRAT and robabeatle[QUOTED] like this.
  14. Dec 20, 2022 at 12:20 PM
    Yup, got one of those in the toolbox. Then one day I finally wised up and started using braided line w/AN fittings :D
    Ok, Dundee :rofl:
    I don't have one of these, but would love to have on in the toolbox. I think I've had to bend steel conduit all of twice in my life, but it's good for way more than just conduit!
  15. Dec 20, 2022 at 12:23 PM
    That looks like my next replacement. OEM is like twice the cost, isn’t it? Better than replacing the 4 bushings on each pack of leafs.
  16. Dec 20, 2022 at 12:31 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    This thing has 2" woofers on both ends. Super happy about being hung.
    oscardog86, bmf4069, txagg and 4 others like this.
  17. Dec 20, 2022 at 1:01 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    damn bro, so hung
    bmf4069, txagg and FrenchToasty like this.
  18. Dec 20, 2022 at 1:13 PM
    805Tundra
    Ben
    Central Coast
    one of my all time favorite movies
    EDIT: This comment will no longer make sense lol
    FrenchToasty and Mr.bee like this.
  19. Dec 20, 2022 at 1:14 PM
    Mine’s bigger…
  20. Dec 20, 2022 at 1:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Charging my phone and speaker at the same time with the engine off hasnt tripped anything. Thats cool.
    Jack McCarthy likes this.
  21. Dec 20, 2022 at 1:19 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    this speaker has impressive bass if you crank it. But i dont.
    805Tundra[QUOTED] likes this.
  22. Dec 20, 2022 at 1:32 PM
    805Tundra
    Ben
    Central Coast
    Stupid question: can I remove outer tie rod from LBJ without lifting the truck up? Out of peer laziness I just want to make sure I can get that part out before going and getting a puller.
  23. Dec 20, 2022 at 1:35 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I need to order some fender blankets cause people are gonna lean on my truck to jam.
    oscardog86, bmf4069 and txagg like this.
  24. Dec 20, 2022 at 1:37 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    yea, pull the nut and wiggle the steering wheel, should break loose, might need a tug or 2. Leave the nut on the shaft if you have to smack it with a hammer.
  25. Dec 20, 2022 at 1:39 PM
    805Tundra
    Ben
    Central Coast
    ok cool, seemed like something i could do with the truck on the ground but wanted to make sure before i did something stupid
  26. Dec 20, 2022 at 1:42 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I wouldnt trust counting twists or threads. Have a wire measurement. Get an alignment.
  27. Dec 20, 2022 at 1:50 PM
    Wood you look at that. Sweet battery hold down bracket.
  28. Dec 20, 2022 at 2:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Drove crackie again today. Fluid film still looking good. So is the 4 flat plug.
    Look at the tread on them there tares!
    oscardog86, bmf4069, txagg and 3 others like this.
  29. Dec 20, 2022 at 2:14 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Dat dare be uh redneckin 3-way!
    txagg, NUDRAT and Tundra2[QUOTED] like this.
  30. Dec 20, 2022 at 2:59 PM
    Nah, I think if it was full-on proper redneck, I'd expect it to be made in USA. Hyper Tough is one of WalMart's China-sourced brands.
    Tundra2 likes this.
