2013 Tundra Platinum Radio Harness
Discussion in '2nd Gen Tundras (2007-2013)' started by tc13, Dec 18, 2022.
  1. Dec 18, 2022 at 9:33 AM
    tc13
    tc13 [OP] New Member
    Can anyone tell me what the blue connector, five pin gray connector and the gray antenna connector are for? Is the antenna wire for GPS or XM? I'm trying to find the wires for the factory tailgate camera. TIA.
  2. Dec 20, 2022 at 12:23 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    The grey single wire most likely a GPS antenna.
    The grey 5 pin is the K6 connector, Pin#1 Red Parking Brake Switch, Pin#3 White Speed Signal, Pin #5 Green Reverse Signal
    The rectangular blue one I am not sure. I do not see it in the wiring diagrams. I would assume XM radio something.
    The rear camera is shown below.
    Pins 11,12,13,14 of the K23 Connector.
