Tool storage under oem tonneau cover
Discussion in '3rd Gen Tundras (2022+)' started by TundraWorkHorse, Dec 19, 2022.
  1. Dec 19, 2022 at 8:45 PM
    TundraWorkHorse
    TundraWorkHorse [OP] New Member
    2023 Toyota Tundra Platinum
    I need some sort of tool box below the folding OEM tonneau cover
    Thought of the BAK
    BAK INDUSTRIES BB2 00-21 TUN 92401
    But they emailed me back saying it only works with there cover and not the OEM
    Any suggestions?
  2. Dec 20, 2022 at 7:39 AM
    Perpendicular
    Perpendicular New Member
    Paul
    Austin, TX
    2023 Capstone
    I have that box, love it for the functionality and how it folds up to give you the space if needed. Can you take some pics of your rails by the front? I can see if they are similar to the BakFlip I am using.
  3. Dec 20, 2022 at 7:54 AM
    vyslouzil
    vyslouzil New Member
    Robert
    Not answering your question directly, but curious if this even works with the MX4 with the OEM rail attached below it? Diagram makes it appear it needs some space to clamp where that rail sits. Does your OEM cover have both the tonneau plate/rail and the OEM rail mounted below it?
    https://bakindustries.com/images/BAKBOX2318A0044RevB081418DD.pdf
  4. Dec 20, 2022 at 8:06 AM
    Perpendicular
    Paul
    Austin, TX
    2023 Capstone
    Mine has the OEM rail and the BakBox fits fine.
  5. Dec 20, 2022 at 8:19 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    ive been wanting something similar and was curious. Do you thing that storage unit would work if you used the same slot nuts as anchor points directly to the bed rail system.
    Looks like you might be able to to anchor sections 1 and 2 (ind the pdf) to the bed rail system using the slot nuts. Only part that seems sketchy is the top lip of bracket in diag #2
    Just a thought !
  6. Dec 20, 2022 at 8:21 AM
    TundraWorkHorse
    Got pics ?
  7. Dec 20, 2022 at 9:00 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I am not too sure if the Diamond back tool boxes will fit under the Bakflip but they are worth considering. they have all sorts of different sizes on their website. If they sit on the tie down rails, they might work with any cover.
  8. Dec 20, 2022 at 11:52 AM
    Perpendicular
    Paul
    Austin, TX
    2023 Capstone
    Sure, what is it you would like to see?
  9. Dec 20, 2022 at 12:13 PM
    TundraWorkHorse
    How the box is held on either side to the OEM covet
  10. Dec 20, 2022 at 12:16 PM
    Perpendicular
    Paul
    Austin, TX
    2023 Capstone
    The instructions they have above is pretty detailed as to how they attach. See pics of my install.
