Bed bump noise
Discussion in 'General Tundra Discussion' started by ttsidd, Nov 19, 2022.
  1. Nov 19, 2022 at 8:00 PM
    ttsidd
    ttsidd [OP] New Member
    Talha
    Chicago IL
    2021 1794 Edition Toyota Tundra
    Stock
    Constantly getting what the dealer described as (normal) noise from the bed portion over pot holes and bumps ( more like a “thud” to me) — anything I can do to get rid of it?
    Any pointers appreciated!
    Thanks,
    T
  2. Nov 20, 2022 at 3:52 AM
    CMikeB
    CMikeB New Member
    After much searching, weeping and wailing, I discovered the bed bolts were looser than they should've been. Re-torqued 'em and no more "thunk!"
    MadMaxCanon likes this.
  3. Nov 20, 2022 at 4:33 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    The bed bottom bolts holding it to the frame?
  4. Nov 20, 2022 at 4:49 AM
    CMikeB
    CMikeB New Member
    The bolts you see on top of the bed.
    MadMaxCanon[QUOTED] likes this.
  5. Nov 20, 2022 at 7:02 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    I was just going to say, I had the exact issue, even ONE loose bed bolt can cause this. And it was driving me crazy.
  6. Nov 20, 2022 at 8:35 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I hate scumbag dealers whose answer is always "oh that's normal" when in reality they have no clue.
    ttsidd[OP] and Tundrastruck91 like this.
  7. Nov 20, 2022 at 8:55 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Hey, it IS normal to have noises when the bed bolts or other things are loose. :rofl:
    sask3m[QUOTED], ttsidd[OP] and CMikeB like this.
  8. Dec 19, 2022 at 7:30 PM
    ttsidd
    Talha
    Chicago IL
    Stock
    Had all bolts tightened on / under bed…still getting noise!
    Predator steps?
    Rail gate remote locks?
    Anything in rear fenders?
  9. Dec 19, 2022 at 7:32 PM
    MadMaxCanon
    Could it be driveline noise since your hitting bumps? It wouldn't be too surprising. Hitting a hole while even at low speeds is pretty jarring
  10. Dec 19, 2022 at 7:46 PM
    ttsidd
    Talha
    Chicago IL
    Stock
    Not sure, is that a normal noise? Noise I am getting is more a thudding noise springing back and forth a couple of times…
  11. Dec 19, 2022 at 7:52 PM
    MadMaxCanon
    Have you checked your driveshaft and slip yoke?
