Driving with aggressive chains?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gort, Dec 19, 2022.
  1. Dec 19, 2022 at 4:09 PM
    Gort
    Gort [OP] New Member
    Canada
    2020 Tundra SR5+
    Is there any special considerations or things I should know if I'm intending to use tire chains when going on icy/snowy forest service roads?
    I am getting a set of 4 chains so all tires are covered, however I have heard mixed things about driving in 4-Hi, 4-Lo, with ATRAC, traction control, etc... What is the ideal "setting" for driving off road with chains on snowy roads?
    Typically when going off road in snowy conditions all I do is turn traction control off with a quick button press, I don't haven't tried any of the more complicated button sequences to turn off ATRAC, etc.
    I want to avoid damaging my drive train.
  2. Dec 19, 2022 at 4:54 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    1st consideration is clearance. UCA and other areas around the front tires at lock and compression.
