General Supercharger Thread
  1. Dec 19, 2022 at 7:42 AM
    #4591
    snivilous
    SW UT
    300k+ Supercharged 2008
    Only on the passenger side, which correct me if I'm wrong was concluded to be the leaner running side since the driver's side is fed first?
    Hard to say if I'd keep the 2.0 if I lived lower... It seems like the failure mode is prolonged heat, so doing stop light or highway pulls is probably fine even if it's a lot more often if you lived down there. I suspect it's still very reliable how I drive it, even if it made 11psi every day of the week.
    Though I would step up the injectors if I lived lower, initially I was shooting for 10.5 AFR but that was bouncing around a bit to 10.7-11 so I richened it out to further to like 10.2 just so I had some buffer on my 10.5 target. The injectors are at 95% consistently, so that would be the biggest issue to address. And as we know tuning is critical, I think the tune is pretty safe right now after a lot of tweaking and I am very liberal about dumping fuel. At the end of the day this is still my primary daily and tow vehicle too :D
    The 2.0 is very nice for things besides WOT too, normal driving around it's very noticeable since there is a lot of boost available at relatively low throttle. The truck rarely needs to downshift since it just lets more boost in and has good acceleration unless you want it to drop a gear. It doesn't feel like it's lacking on power and needs to rev out for everyday things like passing people which is nice.
    Silver17[QUOTED] likes this.
  2. Dec 19, 2022 at 7:46 AM
    #4592
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    M3Tundra-JK likes this.
  3. Dec 19, 2022 at 8:23 AM
    #4593
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    That TRX sounds like the Trans is keeping the RPM's right in the sweet spot. hard to beat that.
  4. Dec 19, 2022 at 8:51 AM
    #4594
    Silver17
    Eastern PA
    I saw in the comments of another trx video that is has a mode called “torque reserve” or something. It basically lets you build up to 4psi of boost for the launch. The TRX is just a brute out of the hole. It’s fast on a roll too, but most of its advantage is out of the hole I believe.
  5. Dec 19, 2022 at 8:57 AM
    #4595
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Wanna see the long term reliability of those TRX's
    Saltyhero13 likes this.
  6. Dec 19, 2022 at 9:01 AM
    #4596
    snivilous
    SW UT
    Does a warranty count as reliability?
  7. Dec 19, 2022 at 9:09 AM
    #4597
    Silver17
    Eastern PA
    That’s the sweet spot of the SC tundra. 85% of the power and straight line performance of the TRX, but the best part is it’s a Toyota and not a Ram so it’s something worth owning long term. I think I’m ok with being a little slower than an 90k truck with questionable reliability.
  8. Dec 19, 2022 at 9:28 AM
    #4598
    M3Tundra-JK
    Scott
    2005 GX470
    Pretty sure they're gonna deny me warranty up and down the lot lol. Just hit 9k miles on the truck
    nobodyintexas likes this.
  9. Dec 19, 2022 at 10:05 AM
    #4599
    Saltyhero13
    Saltyhero13 Throbbing Member
    That how I look at it. A 5 second truck and reliable daily driver.
    Without great tires for grip anything outside base settings can get squirrely under the wrong conditions with RWD. Crap, I even break traction in 4WD at times or at speed. I still haven't settled on replacement tires but still have life in these AT2 ( I fucking hate them).
  10. Dec 19, 2022 at 1:55 PM
    #4600
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  11. Dec 19, 2022 at 2:17 PM
    #4601
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Awesome!!!!:)
  12. Dec 19, 2022 at 2:18 PM
    #4602
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Pops or yours?
  13. Dec 19, 2022 at 2:19 PM
    #4603
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Pops, shooting to have installed before baja.
  14. Dec 19, 2022 at 3:48 PM
    #4604
    ZPhilip
    Philip
    West Chester, PA
    I’m looking forward to hearing your opinion and experiences of this blower. I don’t know of any active users on here with a Whipple.
  15. Dec 19, 2022 at 3:53 PM
    #4605
    M3Tundra-JK
    Scott
    2005 GX470
    Could be better. Will go back and clean up some of the over spray, and maybe a little q-tip paint touch-up. Used Krylon Farm & Implement: International Harvester Red Gloss Enamel
  16. Dec 19, 2022 at 3:59 PM
    #4606
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Sick!
  17. Dec 19, 2022 at 3:59 PM
    #4607
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’ll definitely keep everyone posted
    Black@Blue19 and M3Tundra-JK like this.
  18. Dec 19, 2022 at 4:02 PM
    #4608
    ZPhilip
    Philip
    West Chester, PA
    To the Harrop crowd, what boost psi are you reaching and what pulley do you have installed?
    I recently installed my Innovate PSB-1 AFR and boost gauge and observed a peak of 8.8 psi on stage 1 85mm pulley. Curious if this is a common or is it just a tiny boost spike that doesn’t reflect reality? And I’m around 300-500 feet elevation.
    And yes I just drilled a giant hole in the dash to run the cables for this gauge. I didn’t want the gauge on the pillar and I already have my Scangauge mounted on the steering column. This is my daily/work truck/ 2 kiddo car seat commuter so I dont want to have a gauge flashing in my peripheral vision all the time.
  19. Dec 19, 2022 at 4:20 PM
    #4609
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I'm also curious. I installed a 75mm pulley with Prospeed's 4.5 intake. Curious what kinda boost I'll see.. I'm close to sea level
  20. Dec 19, 2022 at 4:37 PM
    #4610
    Silver17
    Eastern PA
    My particular AEM gauge only reads in whole numbers. That said it would flash 7 psi with the 85mm, and flashes 8 psi with the 80mm.
  21. Dec 19, 2022 at 4:40 PM
    #4611
    ZPhilip
    Philip
    West Chester, PA
    Did you tap into the vacuum hose on top of driver side of blower?
  22. Dec 19, 2022 at 4:41 PM
    #4612
    Silver17
    Eastern PA
    Yup!
    ZPhilip[QUOTED] likes this.
  23. Dec 19, 2022 at 5:08 PM
    #4613
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    How much....
    does
    that
    weigh?
  24. Dec 19, 2022 at 7:51 PM
    #4614
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    I have the 75mm with the maggy box. I’ll max out at 12psi at 653ft above sea level.
    reywcms, Saltyhero13, ZPhilip and 2 others like this.
  25. Dec 20, 2022 at 3:37 AM
    #4615
    nobodyintexas
    nobodyintexas What?
    South of Houston
    my 85mm pulley was a smooth 6.3-ish on the dyno @ Peitz Performance.
    D3 said the 80mm was ~8-ish.
    My boost gauge is still on my workbench....next to the catch can.
    V10Ace and Silver17[QUOTED] like this.
  26. Dec 20, 2022 at 4:41 AM
    #4616
    Silver17
    Eastern PA
    I wonder if how free flowing the catback exhaust is can effect the boost numbers one would read, or if the exhaust only effects boost with changes to headers/cats.
  27. Dec 20, 2022 at 4:43 AM
    #4617
    ZPhilip
    Philip
    West Chester, PA
    Thanks for the info. My boost gauge was on the workbench from March until a couple weeks ago when I installed it.
  28. Dec 20, 2022 at 7:15 AM
    #4618
    ssmokedz
    Shelton CT
    Im running a Maggy with the stock pulley i see usually high 8 psi and a few times it has said low to mid 9 psi peak. I think its just a quick spike though as its consistent high 7's at wot. I have the same PSB-1. IMG_9030.jpg
    M3Tundra-JK, HulkSmurf14 and reywcms like this.
  29. Dec 20, 2022 at 7:23 AM
    #4619
    ssmokedz
    Shelton CT
    And i love the PSB-1 and where it's mounted. I can see it perfectly even in strong sunlight. Not that is necessary but i love the built in shift light too. I wish i knew about it when i was doing gauges in my camaro. IMG_9001.jpg
  30. Dec 20, 2022 at 7:26 AM
    #4620
    M3Tundra-JK
    Scott
    2005 GX470
    That spot looks really clean too. I'm a short dude and idk if it's just me but the A-pillars on this truck are HUGE. If I pull up to a stop sign, it's hard to see if anyone is at the crosswalk. I'm always leaning forward to look around it lol
    reywcms likes this.
