Talon's cat cover play ok with RCI front skid?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bmann7, Sep 13, 2022.
  1. Sep 13, 2022 at 4:13 PM
    bmann7
    bmann7 [OP] Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Already have an RCI front skid plate on my 2019 Platinum, just ordered the Talon's garage cat cover set and wonder if the two marry up ok during installation??
    Anyone know? Thanks in advance.
  2. Sep 13, 2022 at 4:57 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Do you mean the RCI trans skid? Unless that cat cover is pretty long I don't think it would reach the back of the RCI engine skid
    bmann7[OP] likes this.
  3. Sep 13, 2022 at 6:24 PM
    bmann7
    WA
    See signature line
    Have the RCI front engine skid plate.
    Ordered the Talon transmission and transfer case/catalytic converter covers.
    Just wondering if they go together ok?
  4. Dec 13, 2022 at 4:57 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Did you get your Talon plates installed?
  5. Dec 13, 2022 at 4:59 PM
    bmann7
    WA
    See signature line
    Yes, I did get them on but had to take it to a shop and the guy there wasn't pleased with me. Said to me good luck when it comes time for the next guy to figure it out!
    jonclark96 likes this.
  6. Dec 13, 2022 at 5:01 PM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Looks like I’ve got some work ahead of me when my plates arrive.
  7. Dec 13, 2022 at 5:52 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    They work just fine together. I have the RCI engine skid and talon plates.
  8. Dec 13, 2022 at 6:27 PM
    Talon2006
    Talon2006 New Member Vendor
    The hardest part is just getting to the bolts.
    we also have our own engine plate that works good with our plates.
  9. Dec 14, 2022 at 1:07 PM
    bmann7
    WA
    See signature line
    Correct! It's honestly quite a reach and difficult to wrench on. That said it can be done and looks great once it's completed.20220915_153125.jpg
    NewImprovedRon likes this.
  10. Dec 14, 2022 at 1:15 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Looks good!
    1/4" aluminum looks like it would be pretty tough.
    bmann7[QUOTED][OP] likes this.
  11. Dec 14, 2022 at 1:20 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Yep I just installed the RCI skid with the talon cat plates the other day and it was a pain for sure to get to the two bolts that overlap on the RCI and talon shield, but it'll work.
  12. Dec 14, 2022 at 1:22 PM
    bmann7
    WA
    See signature line
    Exactly - I have long arms and tools with extensions, and it was still tricky to do. Do feel protected under there though!
    Nbab23[QUOTED] likes this.
  13. Dec 16, 2022 at 6:41 PM
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    What's to keep a thief with a saw saw from cutting right through that aluminum bracket holding the plate to the frame? There is a gap between the frame and the actual rear shield that would be an ideal place to cut right through that bracket and then pry it down enough to get a small saw saw in there to cut the converter off.
  14. Dec 18, 2022 at 9:27 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    If the brackets are cut (which would be quite noisy and take time), prying and bending the 1/4" aluminum will not be an easy task. It's not a terribly long from where it is bolted at the front of the rear piece.
  15. Dec 18, 2022 at 2:27 PM
    RDRunner
    RDRunner New Member
    No offence to all the companies who have built these shields, but I think I could design one a lot better. I see serious problems with all of them. I would not use aluminum either (too easy to cut). I would use the same gauge steel as the normal front factory steel skid plate on my SR5 4x4 and design it a lot like it, where it goes frame rail to frame rail and then back at least 6 inches past the rear cats and turned up some to close any gap. I may end up making my own (or have someone make it after I buy the piece of steel).
  16. Dec 18, 2022 at 7:08 PM
    bmann7
    WA
    See signature line
    @Talon2006 maybe you can speak to this?
  17. Dec 19, 2022 at 8:01 AM
    Talon2006
    I have had customers contact me, and post on our Facebook page that they had someone try to cut their shield. They give up after short notice and moved on. That is a big reason why I don't offer aluminum in anything thinner then 1/4".
    Trying to cut both those brackets, hold that shield down, and get up to the cuts to cut it off is not going to be easy. Thief's want easy.
    Even on the 2wd trucks, that have a ton of space from the transfer case missing we have not had a thief try to climb up in there and cut off the cats. If you look at my transfer case plates there are three holes in the back of it. A long time ago I made a vertical plate that would bolt onto there and limit access. I never brought it to market because I truly felt it was not needed.
  18. Dec 19, 2022 at 8:13 AM
    bmann7
    WA
    See signature line
    I agree with 'thiefs want easy'.
    My scenario is occasionally parking overnight in a large (target-rich) parking lot. I just wanted to be one of the least attractive targets in the lot and when someone rolls up under my truck and they see quarter-inch plating covering everything I suspect they'll move along and leave my truck unscathed.
    So far so good.
  19. Dec 19, 2022 at 8:25 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Wouldn't you think the thin gauge steel would be just as easy for a thief to cut?
