Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
Discussion in 'Detailing' started by T-Rex266, Jul 27, 2017.
  1. Jul 27, 2017 at 10:52 AM
    T-Rex266 [OP] Fuck Cancer Staff Member
    I found this thread on another forum and wanted to share it here. I have zero affiliation with AutoGeek. The only thing I have added was their hyperlinks to make it easier for you all.
    First - You need and want an orbital polisher
    if you're new to car detailing, perhaps you just purchased your first car or at least the first car you had any desire to take care of, then you're going to need and want an orbital polisher.
    Why?
    The clear-coat finish on your car is hard enough that you with your hand and arm muscle are NOT going to be able to rub a compound, polish or cleaner/wax hard enough, fast enough and long enough to a SMALL area to effectively remove the swirls and scratches while at the same time leaving the paint looking great.
    Clear-coats are scratch-sensitive. This means even though they are hard, they scratch very easily. So, if you're a strong person with a lot of energy and you could rub a compound, polish or cleaner/wax hard enough, fast enough, and long enough to a SMALL area to remove the swirls and scratches without at the same time putting in swirls and scratches due to a lack of experience and technique- you still wouldn't be able to do en entire car. It's simply too overwhelming.
    I've been typing out articles on how-to remove swirls and scratches documented since 1994. That's 23 years- and that's just typing how to do. I've been teaching people in person even longer. So please take my word for it... you need at a minimum what I call as simple or entry level orbital polisher.
    My recommendation?
    Get the Griot's Garage 6" DA Orbital Polisher. This one,
    - Standard cord
    - HD Cord - 25' Heavy Duty Cord already pre-wired
    Why?
    It's the best bang for the buck. There are cheaper polishers on the market, but not better polishers for the value of your dollar. In addition, Griot's backs this tool with a lifetime warranty. It also has all the power you'll need to take care of your own vehicles or vehicles and for some of you, you can detail vehicles for money with this tool.
    Second - You're going to need a 5" backing plate and some 5.5" buffing pads.
    The Griot's polisher comes with a 6" backing plate and you can get 6.5" pads to use if you'd like. Again, from experience what works better )unless you're buffing out big flat RVs) is a 5" backing plate and 5.5" buffing pads.
    I'm not going to try to convince you on this point you caneither take my word for it or not. If you want to trust me, then here's the links to two great backing plates, both will bolt on to the free floating spindle bearing on this tool.
    Purchase your polisher from Autogeek or not, here's what you'll need to buff out a vehicle:
    5" Backing plates
    Third - You're going to need some buffing pads
    Most our kits, or any kit you purchase anywhere only comes with a few pads. That's to get you STARTED. That is NOT how many pads it takes to buff out a car.
    As a rule of thumb, if you need to remove swirls and scratches and you're going to use a compound or a one-step cleaner/wax over the entire car, then you want 1 pad per panel
    An example of a pane is a hood, or a door or a fender.
    The average 2-dor car has 9 panels.
      • Hood
      • Roof
      • Trunk lid
      • Driver's side front fender
      • Driver's side door
      • Driver's side rear fender
      • Passenger side front fender
      • Passenger side door
      • Passenger side rear fender
    Of course you can purchase less pads and still get the job done but here's the deal- as you work around the vehicle a foam buffing pad is going to become soggy as it becomes saturated with the liquid compound or liquid cleaner/wax. As the foam becomes soggy or wet, it stops working well. Heck, it stops working great. You can keep going though if that's what your budget allows for and push through the job and punish the pad.
    That said, a clean DRY pads works best. Works fastest and enables you to do your best work faster. So what is your time worth?
    At a minimum, figure:
    5-6 foam cutting pads for the compounding step
    3-4 pads for the polishing step
    1 pad if you want to machine wax after compounding and polishing
    If you're going to use a one-step cleaner/wax you don't normally want to use a foam cutting pad as the sharpness of the foam can leave a shadow effect which is actually micro-marring. Micro-marring is a nice way to say scratching. You can use foam cutting pads. (and I know some detailers do but I'm typing this article for newbies and I want to keep you safe.)
    So, for a one-step cleaner/wax I would recommend getting a minimum of 5-6 foam polishing pads. Of course when using a one-step cleaner/wax you're done after the first and only step so you don't need additional pads.
    Foam pads versus microfiber pads
    Below is a list of 5.5" foam pads and 5.5" microfiber pads. Here's the primary difference if you're new to machine polishing and don't know which style of pad to go with.
    You can quote me on this statement,
    "When comparing foam pads to microfiber pads, foam pads will finish out nicer and more consistently on a wider spectrum of paint systems" - Mike Phillips
    What this means is, vehicles have paint on them. The paint comes from a paint manufacturer. There are about a dozen paint manufacturers that provide paint to vehicle manufacturers and the re-finishing industry. (re-finishing industry is the local body shop or dealership that fixes the dents in your vehicle and sprays fresh paint on the repaired area so it matches the rest of the vehicle.
    Paint systems are not only different in their hardness and softness, or what I like to call polishability, but paints are ALWAYS changing. So there's no simple way to know if the paint you're buffing on is hard or soft without testing and experience, (I cover this in my on page 7)
    So when I say that foam pads will finish out nicer and more consistently on a wide spectrum of paint systems that means
    A: For the finishing step, not the compounding step. (look at what I wrote)
    B: I used the words wide spectrum because thousands of people will read this and then be buffing on a car somewhere and it will have a "paint system" on it and none of us except the person buffing on this car will know if the paint is hard, soft or somewhere in-between.
    Fibers are a form of abrasive
    Just like the headline reads, fibers are form of abrasive. A gentle abrasive in most cases, but an abrasive all the same. If you put a wool cutting pad on a rotary buffer and then buff on some black paint with some baby oil, after you strip the paint of the baby oil and look at the paint there will be hologram swirl scratches in the paint. They will not have come from the baby oil or the tool, so what put the scratches into the paint? Answer: The fibers that make up the wool pad.
    You can extrapolate this out to microfiber pads for orbital polishers. While for some paints, (harder paints), you can both compound and finish out with a fiber/microfiber pad, for other paints, (softer paints), you can compound with a microfiber pad and remove defects but the fibers that make up the pad can and will leave a scratch pattern called micro-marring. That's okay if you do a follow-up step after compounding and re-polish the paint but if you're seeing micro-marring from a microfiber pad then you'll have a high chance of finishing out without micro-marring if you switch over to a foam pad.
    And the above explanation is what I mean when I say,
    "When comparing foam pads to microfiber pads, foam pads will finish out nicer and more consistently on a sider spectrum of paint systems"
    Of course, you never know what you can do until you try.... and then inspect the results. And when inspecting, to measure the true and accurate results you'll need to chemically strip the paint and inspect with a quality swirl finder light or bright overhead sunlight.
    Car Detailing History 101
    To help understand the history of microfiber pads and when and why they were introduced into the car detailing world, I like to use the Meguiar's Microfiber DA Correction System as an analogy.
    Meguiar's introduced this system to change the production detailing industry by getting rid of the universally abused rotary buffer. The production detailing industry uses the rotary buffer for SPEED, not quality. The problem with the rotary buffer is that all to often it leaves the paint filled with holograms.
    Holograms = a circular scratch pattern IN the paint caused by the single rotating action of the buffing pad on a rotary buffer.
    Holograms mimic the pattern a rotary buffer is moved over the paint. Holograms is a SPECIFIC type of scratch pattern only inflicted into paint by rotary buffers, not orbital polishers. Orbital polishers can instill micro-marring and a visible pattern of how an orbital buffer was moved over the paint can be seen on darker colors but this pattern is NOT called holograms. You can call it buffer trails, or buffer haze or buffer shadows, or buffer patterns but it is NOT called holograms.
    The idea was to replace the rotary buffer with a free spinning orbital polisher from Meguiar's called the G100 which was a copy of the Porter Cable 7424 orbital polisher, and then later the MT300, which offers the same 8mm orbit stroke length has the G100 (or the Porter Cable), but has a longer body than the G100. (same 8mm free spinning orbital polishing action)
    To make up for the loss of direct drive power and speed offered by the rotary buffer, Meguiar's incorporated a microfiber pad or a FIBER pad to assist in faster defect removal. Or you could say this as faster PAINT REMOVAL as removing defects is actually removing paint to level the surface, that is level the surface with the lowest depths of the defects you're trying to remove to create a visually flat and also visually perfect finish. The fibers act as a form of abrasives and aid the actual abrasives in compounds and polishes.
    The downside of increasing the aggressiveness or cutting ability of an orbital polisher by introducing a microfiber pad is the risk of introducing micro-marring when the fibers instill their own scratch pattern into some paints, typically softer paints. This trade off is considered a net gain as compared to having the detailing industry inflict every car buffed out with a rotary buffer with hologram scratches.
    The above is an attempt to explain not only why there are microfiber pads on the market but where they fit into the car detailing or car buffing processes.
    Foam pads reduce the risk of micro-marring because they offer a uniform texture of the entire face of the pad, not individual fibers, or loops of fibers in the case of some brands of microfiber pads.
    You won't know if a microfiber pad will induce micro-marring into the paint of any car you are going to buff out until you do a Test Spot. One option for detailers that want increased cutting from any free spinning orbital polishers is to START with microfiber pads for the compounding or cutting step but finish with foam pad.
    Besides pads, abrasive technology is a HUGE factor as to whether you will see micro-marring or not no matter what type of pad you use. This is why I believe the most important factor when buffing out a car is the abrasive technology, not a person's technique, not the tool or the pad. It all starts with the substance TOUCHING the paint and in the car detailing world this would include:
      • Compounds
      • Polishes
      • Cleaner/waxes --> most cleaner/waxes, or cleaner/sealants contain some form of abrasive technology like compounds and polishes and this is why I include them in this group of substances that touch the paint.
    Pad options on Autogeek.com:
    Foam pads
    Here is a list of foam pad options available on Autogeek.com that will fit the above listed 5" backing plates
    Foam pads
    Lake Country Pad Manufacturing <-- Simplest pads available, makes these bubba-proof
    Buff and Shine Pad Manufacturing
    Griot's Garage foam pad options
    Meguiar's foam pad options
    RUPES foam pad options
    Microfiber Pads
    Here is a list of microfiber pad options available on Autogeek.com that will fit the above listed 5" backing plates
    Lake Country
    Buff and Shine
    Meguiar's
    Griot's
    RUPES
    Fourth - You're going to need some products
    By the word products I mean you're going to need some products to buff on and over the paint. Here's the normal types of products used to buff on car paint.
    Compound - Aggressive product that will remove deeper swirls, scratches and water spots as well as severe oxidation.
    Polish - There are three categories of polishes, but the key thing is, polishes are not as aggressive as true compounds. There are Medium Cut, Fine Cut and Ultra Fine Cut polishes on the market today. Having these options lets you choose and use the right level of cut for what you're working on. Some companies are REALLY GOOD at labeling their products to tell you which category they are in and some company's kind of let you figure it out on your own. That's where this forum can come in handy as myself or one of our great forum members can always answer your questions about compounds and polishes.
    Cleaner/wax - This is a product that will do three things in one step.
      • Clean or compound
      • Polish
      • Protect
    There are some amazing cleaner/waxes on the market today and also a boat load of really lousy products.
    AIO - An AIO is simply a cleaner/wax with the name AIO. I have no idea why some people like to call a cleaner/wax an AIO it's all just silliness to me but have at it.
    Non-cleaning wax
    A non-cleaning wax is what I call a true show car wax. A non-cleaning wax is just that, it does NOT contain any chemical cleaners or abrasives in it to abrade the paint and remove defects. It is solely for the purpose of providing protection and beauty to paint that is ALREADY in great condition.
    For example, If you purchased the above polisher, some pads and a quality compound and a quality polish, AFTER you compound and polish the paint you would NOT want to use a cleaner/wax as that's called working backwards, you're kind of going back to the compounding or polishing step since a quality cleaner/wax is able to remove defects using abrasives.
    Instead, what you want is a NON-cleaning wax. The cleaning or abrading process has already been performed by the compounding and polishing step, now you just want pure protection and beauty. And of course there are also non-cleaning synthetic paint sealants and also non-cleaning ceramic coatings. Pick your poison but the big picture is to choose something besides a cleaner/wax.
    Fifth - You're going to need lots of high quality microfiber towels.
    Hey - after you machine apply a compound, polish, wax or cleaner/wax you're going to need some towels to wipe off the residue. Use good towels and take care of them and they are like tools, invest in good tools. Use crappy towels and don't take care of them then each time you wipe your car's paint with the crappy towel you'll put scratches back in.
    Click the link below and watch the video, look at the pictures and read the text...
    How, why & when to inspect your microfiber towels when detailing cars
    Then order at least a 12 pack of these and do like I say in the above article to take care of them and inspect them before use.
    That will be a good start. They key is to wash and dry them correctly and just as important, have a DEDICATED laundry hamper in your garage THAT'S CLEAN (on the inside) to throw your dirty towels as you work around your car and then after washing and drying have a CLEAN place to store your towels so they don't become contaminated.
    The above is a really the minimum of what I call head knowledge that you need to know to make the transition from working by hand to working by machine SAFELY on your new car.
    Below I'll post a video that will show how even a newbie can get professional results their very first time.
    https://www.youtube.com/watch?v=ulWXODgg8V4&feature=youtu.be
  2. Jul 27, 2017 at 10:52 AM
  3. Jul 27, 2017 at 11:10 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Some good information right here. Some tricks that I'm gonna have to try next time. I use a Ryobi 18v orbital and works great. Cordless makes it so much easier to work around the truck.
    SouthBoundSteve and T-Rex266[OP] like this.
  4. Jul 27, 2017 at 11:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yikes that's a long read. I'll fly @WarEagleSteve in to do my truck before I read all that. o_O
  5. Jul 27, 2017 at 11:13 AM
    I still need to review it all. I've read a bit, but not all.
    joonbug likes this.
  6. Jul 27, 2017 at 11:16 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Do you even wash your truck? I think you would fly him in before you even took a hose to it lol
  7. Jul 27, 2017 at 11:17 AM
  8. Jul 27, 2017 at 11:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :notsure: What? NO! You make it sound like I drive some filthy truck or something. :cookiemonster: I hose my truck down pretty regularly... atleast every 2-3 months. I did use soap for the first time a couple of weeks ago when I got a foam cannon, but didn't actually wipe it. But it's still pretty shiny... considering I did it in 10 minutes. (4 minutes of that was setting up the powerwasher.) I also have plans to wax my truck somewhere between 2018-2021.
    TXMiamiFan and T-Rex266[OP] like this.
  9. Jul 27, 2017 at 11:42 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Lol nothing wrong with riding a dirty girl. Those canons are sweet and convenient. @WarEagleSteve should be able to get a pretty good deal on airfare with that kind of advance notice to come help lol
  10. Jul 27, 2017 at 11:44 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Uh I meant driving a dirty girl ;)
    Jsena, SouthBoundSteve and joonbug like this.
  11. Jul 27, 2017 at 4:27 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Dirt protects the paint from UV rays, right @joonbug?
    joonbug, SouthBoundSteve and Jsena like this.
  12. Jul 27, 2017 at 4:31 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Great write up bro..
    T-Rex266[QUOTED][OP] and joonbug like this.
  13. Jul 27, 2017 at 4:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup. Not only that, you don't scratch your paint trying to wash it off. Like @tigerfan00 said, he never washed his taco. And the paint was like new when he sold his truck.
    TXMiamiFan[QUOTED] likes this.
  14. Jul 27, 2017 at 4:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    But that's not the reason I don't wash my truck... I'm just a lazy bastard. :(
    831Tun and TXMiamiFan like this.
  15. Jul 27, 2017 at 7:07 PM
    JimBeam
    JimBeam Moderator Staff Member
    2015 Limited
    Don't worry...me too
    joonbug[QUOTED] likes this.
