Well that’s big, what do we do now?
Discussion in '1st Gen Tundras (2000-2006)' started by Cummins3500, Dec 17, 2022.
  1. Dec 17, 2022 at 5:58 PM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    which one for an oil change valve
    fumoto or stahlbus? Any regrets after installing
  2. Dec 17, 2022 at 5:59 PM
    Someone pointed out fumoto to me and I had to look it up.
    Cummins3500[OP] likes this.
  3. Dec 17, 2022 at 6:03 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    My brother in law and I have run Fumoto’s and they have been flawless.
    I’m not running any now… maybe I should order some :rolleyes:
    2mchfun and Cummins3500[OP] like this.
  4. Dec 17, 2022 at 6:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Whats the benefit? A hose so it doesnt drain into the skidplate?
  5. Dec 17, 2022 at 6:16 PM
    Cummins3500
    Logan
    @Diablo169 ya run the safety keeper on yours?
    @Mr.bee keeps everything clean like you mentioned. Plus makes oil changes a tool less deal.
    somebody sent me a video of the solo cup truck for oil filters not to spill any while removing them
    Black Wolf and Mr.bee like this.
  6. Dec 17, 2022 at 9:13 PM
    shifty` All my rowdy friends have settled down
    I've got one, haven't installed, but have experience with them elsewhere. I've seen complaints of slow drain on some vehicles, but opening the top-end (oil fill) can help.
    You still make a mess when replacing the filter, and still need to be able to get to the filter, so still a skid plate to deal with unless you're a contortionist or lucky.
    If you don't have 4WD and/or no skid plate, height/clearance may be an issue to think about, they stick out about twice as far as a standard drain plug.
    Cummins3500[OP] and Tundra2 like this.
  7. Dec 17, 2022 at 9:14 PM
    I'm actually curious to hear more about this trick. Do you need the skid plate off to manage it?
  8. Dec 17, 2022 at 9:20 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm using voice to text so if this doesn't sound right let me know my keyboard doesn't work anymore Phone Space G** d*** it About the oil filter I've always reached down through the top of the engine to remove it On mom's Sequoia with the 4.7 And on cracky
    Acatlin96 and Cummins3500[OP] like this.
  9. Dec 17, 2022 at 9:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've had to use a step ladder before for the Sequoia but it does work no schedule removal
  10. Dec 17, 2022 at 9:28 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I like pulling the skidplate and taking a gander at the dirty bits.
  11. Dec 17, 2022 at 11:17 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yup, gives me a chance to see utter things before they get bad.
  12. Dec 18, 2022 at 6:36 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Oil change intervals for me are 5k and that works out to be about every 12 months, so I pull the shield and do a old fashioned oil change. While under the truck I take a light and give the underside a good look for any problems. Once I saw an exhaust manifold nut that was loose and had I not been doing an inspection, I would have lost the nut and developed an exhaust leak and maybe blow out a piece of the gasket. There's value in doing things right and not always looking for the easiest way. But I am a believer in working smarter not harder. Just my opinion.
  13. Dec 18, 2022 at 6:53 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I'm partial to ValvoMax though fumotos are great too
  14. Dec 18, 2022 at 6:55 AM
    I really like my Fumoto valve. The only trick is that you have to get the oil warm first. It took over an hour to drain the only time I changed the oil cold.
    I run a piece of rubber hose up to the valve and then down to an empty milk jug.
    Cummins3500[OP] and FrenchToasty like this.
  15. Dec 18, 2022 at 8:28 AM
    Cummins3500
    Logan
    GXPaycheck and Elevatorguy like this.
  16. Dec 18, 2022 at 8:30 AM
    I feel like the angle of the dangle on our trucks wouldn’t benefit from this?
  17. Dec 18, 2022 at 8:40 AM
    chunk
    chunk New Member
  18. Dec 18, 2022 at 8:41 AM
    2mchfun
    IMO, the best thing about the valve and why I bought a Fumoto, is it provides insurance that the nut welded inside the pan isn't going to be breaking off during a change on my truck. The old, ounce of prevention is worth a pound of cure logic.
    shifty` likes this.
  19. Dec 18, 2022 at 8:46 AM
    Cummins3500
    Logan
    I may not have thought this all the way out:bananadead:. It’s gonna be a minute before I’m due an oil and get to try it. I wasn’t thinking about how steep the cup would be turned on our filters though. Ours maybe to sideways for this trick
  20. Dec 18, 2022 at 8:48 AM
    It might work, maybe with a bigger solo cup to get further up the canister neck. I just use news paper or junk mail to make a valley and let it drip into my catch pan.
  21. Dec 18, 2022 at 8:57 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Man just recycle some cardboard when you change your filter and sing Kumbaya. No mess. Then fill that solo cup with some liquor and celebrate your contribution to greater Whirled Peas.
  22. Dec 18, 2022 at 9:57 AM
    This is why I wanted more details.
    Right now, I'm just setting my catch-basin jug under the low side of the filter housing; it works fine. But I'd love something innovative.
    I'm in the process of clearing out my crankcase, so short OC cycles. I've had my skid plate off as a result. But if I had it on, I'd wish for an easy filter removal option.
  23. Dec 18, 2022 at 10:00 AM
    des2mtn
    SW
    Tonto cover
    I haven't tried it yet but I'm due for an oil change soon - with the Skid Row front skid plate it appears there's enough room to get the filter off without dropping the skid, and I should still be able to channel the oil still with cardboard.
  24. Dec 18, 2022 at 10:23 AM
    chunk
    chunk New Member
    I just barely crack the filter loose, until oil just starts to dribble out. If done correctly, the small stream will mostly miss the frame and when it stops i stuff a rag in the area and spin the filter all the way off with little to mop up. That's with shield off though. I don't know if it would work with the shield in place. Never tried it.
    shifty` and Cummins3500[OP] like this.
  25. Dec 18, 2022 at 10:36 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    this was dads fix when he first got the titan. I might add a plate over the hole with dzus fasteners, but it doesnt cause any problems as is.
  26. Dec 18, 2022 at 2:32 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I have an 06 2WD. I double up some walmart bags. Place them on the top of the skid plate under the oil filter. Remove the oil filter from the top reaching down into the engine compartment. The oil drops and filter drop down into the walmart bags on the skid plate. Remove bags with messy oil and filter and toss it in the trash.
  27. Dec 18, 2022 at 2:48 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    For the last couple years i've been filtering my used oils, and about half goes to grandpa, and half gets burned. The sludge and metalflake i catch has been collecting in a coffee can for maybe 5 years.
  28. Dec 18, 2022 at 3:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I like the stahlbus for my truck. I have fumotos on the other family cars. The Stahlbus just seems more robust and reliable since the truck finds itself in very remote locations
  29. Dec 18, 2022 at 3:55 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Folks with oil drain valves, how often do problems 'sneak' up on you? Do you pay attention to tire wear before their bald? Brakes? Bushings? "All of a sudden"?
    just curious. You wouldnt believe how often i hear 'all of a sudden' while shopping junk.
  30. Dec 22, 2022 at 7:34 AM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    I've used the Fumoto valves for years. Love 'em. Havent tried the cup trick yet. I've used a gallon baggie though. Same principle.
    des2mtn likes this.
