  1. Dec 17, 2022 at 3:01 PM
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    ^^^what is it?^^^
    I cannot I.D. it.
    Thanks
  2. Dec 17, 2022 at 3:03 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
  3. Dec 17, 2022 at 3:06 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Got that TRD skidplate installed finally, and these RC shackle mounts I picked up from @Cthulhu (thanks again!)
  4. Dec 17, 2022 at 4:02 PM
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
  5. Dec 17, 2022 at 4:37 PM
    hBaz
    hBaz New Member
    middle of nowhere south of OK City
    2021 black 1794 Edition with TRD package
  6. Dec 17, 2022 at 5:02 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    Busy day today. Removed Valhalla cat plates. Then, drained and replaced differential fluids front and back, drained and replaced transfer case oil, and transmission drain and fill. Gotta put the cat plates back on tomorrow. Whew!
    GAknight, Henry1jg, Tyman and 5 others like this.
  7. Dec 17, 2022 at 5:12 PM
    Figured out and fixed my horn wiring issue.
    bulldog93 and RobertD like this.
  8. Dec 17, 2022 at 6:08 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    How many miles do you have on your truck?
  9. Dec 17, 2022 at 6:09 PM
    Ranger2005
    Ranger2005 New Member
    Dean
    2021 1794 Crewmax
    Running boards, ceramic coating, sound system
    On the grill, did you get it with the green border and chrome center or is that a mod?
  10. Dec 17, 2022 at 7:34 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    Just under 60,000.
  11. Dec 17, 2022 at 9:49 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I didn’t like those big cleats. I put a bunch of the small ones like you got. I wish they did not make those cleats so big. The rail doesn’t seam that strong anyway by the way it flexes.
  12. Dec 17, 2022 at 10:34 PM
    Rangergillikin
    Alabama
    It’s an addiction. I have a tool fetish myself. I built myself a personal machine/fabrication shop. Its my fortress of solitude. I spend about 75% of my time in my shop when I’m not offshore at work. I’m the type of person that has to be working on or learning something new all the time. I spend most of my time working on my tools and building out my shop. I love finding a good deal on a machine or tool and restoring it. I’ve been getting a lot of stuff cerakoted lately by a local guy. I’m definitely going to get set up to do that. It’s really a simple process. Just got to find a good deal on a sand blasting cabinet. If you haven’t found a good blasting cabinet yet I found a website that sells upgrade kits that make cheap Harbor Freight blast cabinets work really good. Not having a blasting cabinet is the only thing holding me up from doing cerakote. Ive got every thing else. I’m going to use the air cure type. My guy said that it is actually tougher than the bake on. He does both air cure and bake on but for stuff that get a lot of use like guns he uses the air cure type. Everything I’ve gotten done so far has been the air cure and I really like it. Just takes around 7 days to cure to full hardness.
    Wallygator, GAknight, jpod and 19 others like this.
  13. Dec 17, 2022 at 10:37 PM
    Rangergillikin
    Alabama
    What camera do have. I want to get some cameras but can’t make up my mind. That plug is nice.
  14. Dec 18, 2022 at 4:00 AM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
    Went to CVT tents in chattanooga this saturday and got this bush company AX27. List 4299. Mounted and out the door…2800.00. Got a few other goodies with it. Maxtrax with mounts (prob gonna sell these) solar tripod camp light. (Def keeping this) Lift and wheel install is December 28 so there will be a follow up pic for that as well upload_2022-12-18_5-59-50.jpg
  15. Dec 18, 2022 at 4:10 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I have a trail edition. The grill and color matched surround and bulge are from the factory.
    Ranger2005[QUOTED] and bulldog93 like this.
  16. Dec 18, 2022 at 4:29 AM
    RustyShackle323
    Stewart
    NC
    First time doing all fluids? It seems like all on here are doing them at different intervals.
  17. Dec 18, 2022 at 4:32 AM
    MedCityMoto
    20-30k is typical interval for differentials and 60k for transmission, isn't it? I thought that's what I read on the 2.5gen anyway!
  18. Dec 18, 2022 at 4:34 AM
    RustyShackle323
    Stewart
    NC
    According to the service intervals, it does not state to “replace” oils at 30k. Believe 30k for diffs & transfer case seems a bit premature. But don’t plan to turn this into a back and forth.
  19. Dec 18, 2022 at 4:39 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I’ve been drooling over that sale the last few days wishing I was closer to their shop. Congrats on the tent!
  20. Dec 18, 2022 at 5:12 AM
    Bergy24
    Bergy24 New Member
    You can swap the inserts around too. FA3DEF9A-2C1A-4C70-8F3C-E729810D50D2.jpg
  21. Dec 18, 2022 at 5:25 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    Yes, it was the first time for all fluids. The front differential plug was covered in nasty black goop but the fluid was fairly clean. The rear differential plug had a couple of metal particles and the fluid was dirty. The transfer case fluid was pretty clean. The ATF was pretty dirty. I didn't find consistent interval information but thought 60 was good. I also don't want to remove the cat plates again for a while.
  22. Dec 18, 2022 at 5:36 AM
    RustyShackle323
    Stewart
    NC
    Thanks for the detailed feedback! I can understand that, that’s quite a job I can imagine. Don’t have any on mine yet, but plan to at some point in the future.
  23. Dec 18, 2022 at 5:47 AM
    MedCityMoto
    At least you don't have to remove the cat plate for anything except the transmission service in another 60k!
    Tigereye[QUOTED] likes this.
  24. Dec 18, 2022 at 6:15 AM
    hBaz
    hBaz New Member
    just a cheap simple one in truck that had in last truck. Hyperion, does the basic job and has ok phone app, not sure available anymore.
    But for a recommendation - I put Viofo in our primary drive. Very happy with it. Not the top but great for price point. Link below is for dual but also available in front only
    https://www.amazon.com/dp/B08DV51H2X?ref=ppx_pop_mob_ap_share
  25. Dec 18, 2022 at 6:41 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Except for needing to grease the front drive shaft
  26. Dec 18, 2022 at 6:47 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Shop looks sweet! Is that a blue disco ball?
  27. Dec 18, 2022 at 8:12 AM
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    ..but the sound makes it worth it :)
  28. Dec 18, 2022 at 8:28 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    So let's hear it @el_conquistador
    cartage1[QUOTED] and ATV25 like this.
  29. Dec 18, 2022 at 8:31 AM
    Bergy24
    Bergy24 New Member
    Prepped the Truck for the Pa. Winter around the corner, by spraying her down with Blaster Surface Shield.
    Went on well, with no runs (unless you are too close) Does not stink and very sticky.
    Followed up with a ceramic quick detail to the body and glass.
    https://blasterproducts.com/product/surface-shield/
    This is the 2nd winter for my truck but the first time using any rust preventive.
    I washed the undercarriage after the snow storms last year and really did not have any signs of rust but thought this would help ensure it stays rust free.
    I need to make time to install the Talon Garage Plates, but waiting for a warmer day.
    Henry1jg, TK1979 and bulldog93 like this.
  30. Dec 18, 2022 at 9:20 AM
    Rangergillikin
    Alabama
    It has sticky glue all over. We have horrible swarms of deer flies where I live. They are blood thirsty. They are attracted to blue.
