  1. Dec 17, 2022 at 10:58 AM
    Oil or water, what’s it taste like?
    NUDRAT likes this.
  2. Dec 17, 2022 at 11:03 AM
    Openbaffle
    Openbaffle New Member
    Pretty much replaced everything on the suspension at this point. No more e-brake dash light on either.
  3. Dec 17, 2022 at 11:05 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What's the size of the bolts that are on your truck's LBJs? The bigger ball joints use a bolt with a 17mm or 19mm head
    805Tundra[QUOTED] likes this.
  4. Dec 17, 2022 at 11:08 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    mine have a 17mm bolt
  5. Dec 17, 2022 at 11:11 AM
    805Tundra
    Ben
    Central Coast
    Jack McCarthy likes this.
  6. Dec 17, 2022 at 11:17 AM
    Thanks. Looks like no protective boots for that one unfortunately.
  7. Dec 17, 2022 at 11:24 AM
    805Tundra
    Ben
    Central Coast
    shoots ya can find one with boots either
  8. Dec 17, 2022 at 11:28 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Broke the DS door handle last week.
    Against better judgement, went with scamazon. Fit is perfect, color is a little off and the sticker is red.
    For as often as I take off my door panels, Im glad to have a bag of the plastic door clips as I tend to break one every so often.
  9. Dec 17, 2022 at 1:39 PM
    The color-matched OEM part is only a couple bucks more, is there any reason you didn't go with that one?
    robabeatle[QUOTED] likes this.
  10. Dec 17, 2022 at 1:42 PM
    Passenger cam seal, IIRC, the only path to exit is down by the harmonic balancer. I posted pics of the path of travel on here for someone, but hell if I can find it now.
    RUSTYNUTS[QUOTED] likes this.
  11. Dec 17, 2022 at 2:47 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    If that's it at least it's not as bad a job on his truck as the 05-06's to repair. @RUSTYNUTS I have the cam seals and can mail them to you if you want? I bought them for mine and they said they looked good. I'm figuring by the time mine needs another timing belt, these will be so old I won't want to use them.
    RUSTYNUTS likes this.
  12. Dec 17, 2022 at 3:10 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Little project in the works. I haven't done much lately and felt the need to modify and or break stuff.
    NUDRAT, oscardog86 and txagg like this.
  13. Dec 17, 2022 at 3:36 PM
    Easiest way to tell is to look behind the passenger side timing belt cover, I'd think.
    @Tundra2 posted a pic I used of the front of the block with no timing covers on, and it made it a bit clearer how/why it would leak down the front of the block and dump out around the area behind the alt/ps pump, between those and the HB. It's pissing me off I'm not able to find it.
  14. Dec 17, 2022 at 3:57 PM
    robabeatle
    AZ
    Lazy
  15. Dec 17, 2022 at 5:14 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Funny enough, always thought they were red from the factory and just sun faded
    robabeatle and 5N0W808 like this.
  16. Dec 17, 2022 at 5:20 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  17. Dec 17, 2022 at 5:22 PM
    The little stickers? If so, they are, I bought OEM replacements because my stickers were faded. Yes, I'm that vain. It pisses me off when the only thing that doesn't look new in my truck is the damn lock stickers, and nobody makes little vinyl re-pops.
  18. Dec 17, 2022 at 5:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You coulda just had some custom ones done up.
  19. Dec 17, 2022 at 5:25 PM
    Just seemed like a hell of a lot of work to try and get done, and who knows if the adhesive would hold, or what other probs might come up.
    And we see at least a couple people per year breaking off door handles, they are getting a little old ... and it wasn't too costly for them... so I said 'screw it', and next time I have my door panels off, I'll install.
    5N0W808 and Tundra2[QUOTED] like this.
  20. Dec 17, 2022 at 5:29 PM
    Openbaffle
    Attacking this tomorrow.
    oscardog86, KNABORES, Mr.bee and 2 others like this.
  21. Dec 17, 2022 at 5:39 PM
    Then drive thru a carwash :rofl:
    Yup, please tell me a little more about that :bananadance:
    (3 diff't ones attempted, that was the best result, nothing would penetrate, wipes right off - and paint marker flaked)
  22. Dec 17, 2022 at 6:15 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Whelp….I guess I’ll hang out in here for a bit
    NUDRAT, txagg and Jack McCarthy like this.
  23. Dec 17, 2022 at 6:25 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    The safest of spaces.
    when i drove the truck around yesterday and the day before everything worked great (aside from headlights.) i'm thinking about cutting my headlight housings and stuffing other lights into em. I'm due for housings anyway, so if i mess up, im not out much.
    i like these, but havent completely talked myself into dropping the coin yet.
    https://www.amazon.com/Anti-glare-Headlight-Start-up-Gradient-Compatible/dp/B0B14NSRNJ?crid=3JEYP4ZRYE1ME&keywords=7+inch+led+headlights+dot+approved&qid=1671330240&sprefix=dot+approved+led+headlights+7%2Caps%2C138&sr=8-39&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
    CodyP likes this.
  24. Dec 17, 2022 at 7:15 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Oil. Yeah I guess that matters.
    What about now?
    You’re saying the leak I’ve got requires the timing belt to be removed to change the seal? You positive about that? You’re breaking my heart here man.
    What is it about the ‘05-06 that makes the repair more difficult?
  25. Dec 17, 2022 at 7:15 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Are those small enough that they will fit inside though? 7” is huge
  26. Dec 17, 2022 at 7:17 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I've fit bigger things in smaller spaces. The tricky bit is if i find some projectors i like, ballasts are a little above my pay grade.
    CodyP likes this.
  27. Dec 17, 2022 at 7:25 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    the green is where I thought it was coming out. The red is the tail of a small stream from an unknown source. @shifty` you said passenger cam seal but it’s comin down the drivers side. Is there a reason to assume passenger? Are they more prone to leak or ?
  28. Dec 17, 2022 at 7:31 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Disclaimer: it started with a very minor leak, maybe a week ago. Now it’ll drop probably about an ounce per 5 minutes at idle. Got real bad, real quick
  29. Dec 17, 2022 at 7:47 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Pull the fan and clean what you can so you can get a better look while its dripping.
  30. Dec 17, 2022 at 8:10 PM
    Both mine and a recent member's were on the driver's side. This guy shows pictures of what I'm almost certain are cam seal leak on driver side:
    https://www.tundras.com/threads/questions-comments-concerns.114836/
    And here was mine, which was a mix of cam seal leak and valve cover leak - cam seals leaking down along/behind AC compressor:
    https://www.tundras.com/threads/hey-whats-leaking-here-lower-timing-cover-valve-cover.100798/
    There was one more member who showed stuff just like mine, but I can't find the thread after 3-4 minutes, I give up.
    Anyway, this is where I would expect to see oil leaking if it was the bank 2/pass side cam seals - down the block, on the body of the tensioner etc.:
    https://www.tundras.com/threads/eng...ra-timing-belt-tensioner.116837/#post-3004704
    Edit: @Mr.bee is on the right track. Clean, then monitor. It's what I did with my leaks in that thread.
