Is it worthwhile to change out alternator before it goes bad?
Discussion in '1st Gen Tundras (2000-2006)' started by jackcrab, Dec 15, 2022.
  1. Dec 15, 2022 at 6:54 PM
    jackcrab
    jackcrab [OP] New Member
    Got a 1st gen tundra, 300 k miles, most everything is OEM, including alternator. Wondering if it is worthwhile to change this out just because of how old it is, or should I keep it since it works fine.
    Thanks!
  2. Dec 15, 2022 at 7:00 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    If its charging and not making noise, leave it alone!
  3. Dec 15, 2022 at 7:02 PM
    It's not like it's a hard job. And the brushes are often worn by then. But if you need to be money-conscious then no. If you want to do preventative maintenance, then go for it, but only if you're replacing with DENSO product.
  4. Dec 15, 2022 at 7:07 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’d probably swap it with an denso, eat the core charge and keep the original as a spare, toss new brushes in it though.
    des2mtn and shifty` like this.
  5. Dec 15, 2022 at 7:08 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Just buy the $17.50 brushes. The primary wear part. And have them ready. Or buy the brushes, pull the alternator, take it apart (3 nuts), replace the brushes, put it back in and call it good. And save yourself a crap pot of money. The whole complete alternator change and core is a huge scam rip off.
    robabeatle likes this.
