Wheel studs on 22 tundra
Discussion in '3rd Gen Tundras (2022+)' started by Jprince, Nov 21, 2022.
  1. Nov 21, 2022 at 8:56 PM
    Jprince
    Jprince [OP] New Member
    2022 Lunar rock sr5 tundra
    Added 22in wheels
    Hi guys
    I'm wondering if anyone needed to install longer wheel studs on their 22 tundra in order to properly mount new wheels?
  2. Nov 22, 2022 at 8:49 PM
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    I didn't need longer studs but I did have to use the special 'ET' style aftermarket lug nuts. And you likely will too.
  3. Nov 22, 2022 at 9:29 PM
    Jprince
    Added 22in wheels
    Hmm u got a link to this particular type of lug nut? I just went to autozone and bought some open ended 14mm lug nuts. They are doing fine now but I just curious if I should have done something differently.
  4. Nov 23, 2022 at 1:37 AM
    docfnky
    docfnky New Member
    Skidmarcx and gnc1017 like this.
  5. Nov 23, 2022 at 4:32 AM
    gnc1017
    gnc1017 New Member
    Screenshot_20221123-062546.jpg See above. A reputable tire and wheel shop should have these or can get them for you.
    If you are only grabbing a few threads because your lug nuts are not extending into the holes of the new aftermarket wheels, that would be a very dangerous situation and I highly recommend not driving the vehicle until they are replaced.
  6. Dec 13, 2022 at 8:12 PM
    Jprince
    Added 22in wheels
    Thanks I for the info
  7. Dec 14, 2022 at 5:13 PM
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
