2002 Tundra still ain’t right
Discussion in '1st Gen Tundras (2000-2006)' started by Rcdlifttundra, Dec 10, 2022.
  1. Dec 10, 2022 at 6:36 AM
    Rcdlifttundra
    Rcdlifttundra [OP] New Member
    Grant
    2002 Toyota Tundra
    6 inch RCD lift 35x12.50x17 Tire swing gate tailgate delete 4.56 gears JBA headers Magnaflow exhaust
    I’ve had my first gen for about a year now. Bought it from my uncle who bought it brand new. He took really good care of the truck up until about 4 years ago. The truck sat for 3 years because he become Ill and only got driven here and there. The worst part about that is the truck spent almost its whole life in Florida up until I brought it home. Before that happened he had done a few things, RCD 6 inch, 35’s, 4.56 gears, intake, headers, exhaust, remap, and that’s about it besides general maintenance. Since I’ve had it, I’ve added SPC UCA’s, factory lowers, tie rods, ball joints, wheel bearings, diff mount brackets, sway bar links, sway bar bushings, icon 2.5 coilovers, icon 2.5 rears. I’ve done other basic maintenance as well and had numerous alignments at offroad shops locally and it still rides like shit and feels like it gets worse anytime someone touches it. I’m beside myself as I’ve put a lot on money, time, and research into bringing this truck back to life. I’m just trying to make sense of what’s going on and where my real issues could be coming from. I have alignment sheets upon request. Halp….
  2. Dec 10, 2022 at 6:39 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    I would think a 6" lift would not improve the ride of a vehicle.
    Although I do realize you said the ride has gotten worse, and the lift was already installed when you got it.
    Maybe others will have a better idea of what could be the cause.
    SPP
  3. Dec 10, 2022 at 6:57 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    If you remove the shocks, springs, and sway bar links, maybe you'll find a bind while cycling the suspension.
    Lil_Big_Bro likes this.
  4. Dec 10, 2022 at 9:07 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    All those suspension and tire mods = firmer and harder ride. Have E load 35s? What kind of air pressure you running?
  5. Dec 10, 2022 at 12:29 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Did the alignment guys check your rack and pinion bushings?
  6. Dec 10, 2022 at 2:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Describe how the ride is bad. Bouncy, jarring, bumpy, darts around, wheel doesn't return, etc.
    Also post your alignment sheets from oldest to newest.
    txagg likes this.
  7. Dec 11, 2022 at 6:23 PM
    I see a lot of info about what was done to the truck, but not a lot of info about what makes you say it's not quite right.
    Are we supposed to guess at all the things that could be wrong?
  8. Dec 14, 2022 at 12:13 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Did we get ghosted?
    AZBoatHauler likes this.
  9. Dec 14, 2022 at 12:39 PM
    Rcdlifttundra
    Grant
    2002 Toyota Tundra
    Haha no sorry. I’ll post some alignment sheets here later. Also will share my thoughts when I get off work
    N84434 and shifty` like this.
