2023 TRD PRO Tonneau covers
Discussion in '3rd Gen Tundras (2022+)' started by vroger, Dec 13, 2022.
  1. Dec 13, 2022 at 10:04 AM
    vroger
    vroger [OP] New Member
    Roger
    2023 Toyota Tundra Hybrid TRD Pro Magnetic Gray Metallic
    looking for a Tonneau covers for a 2023 TRD PRO. love your thoughts on hard vs soft. I had a linex hard cover for my 2020, but it didn't hold up.
  2. Dec 13, 2022 at 10:47 AM
    Woodman427
    Woodman427 New Member
    Post-22 owner. Back to reliable Tacoma
    I prefer hard cover for increased security. I had the Toyota OEM cover on mine. It was ok. It can be easily broken into using a coat hanger if you know the covers and where the latch wire is. I found it dented easily and the plastic latches are weak. I now have a Bison on my Tacoma. Very similar design to the Extang 2 that sits on top of the bed rails. Not as sleek but I prefer the on top design. Much much less water ingress. Yes you don't have the ability to fold the section up closest to the cab but I don't need it. The Bison is faster to take on and off then factory OEM and at half the price of an Extang and so far seems to be more more durable as it looks to be a much stronger aluminum surface.
  3. Dec 13, 2022 at 10:50 AM
    vroger
    Roger
    this one?
    https://bisontonneaucovers.com/coll...tri-fold-tonneau-cover?variant=34010826244141
    or this one? https://bisontonneaucovers.com/coll...oyota-tundra-flip-back-tri-fold-tonneau-cover
  4. Dec 13, 2022 at 10:54 AM
    Woodman427
  5. Dec 13, 2022 at 10:59 AM
    vroger
    Roger
  6. Dec 13, 2022 at 1:31 PM
    vroger
    Roger
  7. Dec 13, 2022 at 2:28 PM
    vroger
    Roger
    thanks. I was on my phone while at the dealer picking it up.
    would you attempt to put my linex trifold back on this until I find something else? it's the middle of the winter here in MN... and we are in a snow storm to boot..
  8. Dec 13, 2022 at 2:56 PM
    hiimbrando
    hiimbrando Chop shop owner / Degenerate car part buyer.
    Brandon
    Dallas, Texas
    I'd stick with the hard covers. The soft covers are a bit cheaper but aren't as rigid. My bak flip mx4 started to leak a tad bit but a couple piece of foam in the corner of the bed stopped the leaking.
    vroger[OP] likes this.
  9. Dec 13, 2022 at 3:12 PM
    vroger
    Roger
    any experience with a brand you would recommend?
  10. Dec 13, 2022 at 3:17 PM
    hiimbrando
    Brandon
    Dallas, Texas
    I would look into the Bakflip MX4 trifold. I got my second hand for $200 off facebook marketplace.
    Install is fairly easy. Its low-profile and if you use your bed a lot, unfolding is quick compared to the clamp style bed covers.
    22PlatWCP and vroger[OP] like this.
  11. Dec 13, 2022 at 5:30 PM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    I love my Weathertech Alloy cover. Hard cover. No water gets in, no drain tubes
  12. Dec 13, 2022 at 6:35 PM
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    I put a DiamoundBack SE on my 21 Pro. Locks up... No leaks... no problems. I will never buy a different cover ....ever. Check out their website they have a few different models to choose from. They also have a scratch and dent area. A little pricey, but it will out last the truck.
    They don't show a cover for a 23 yet on their website but the 22 cover will most likely work. I'll bet if you call them they will have the answer for ya.
  13. Dec 14, 2022 at 11:34 AM
    vroger
    Roger
    So looking at my bed, they have this rail around it. Would you need to remove it to do any of these covers? Or is it setup for oem cover as is?
  14. Dec 14, 2022 at 11:40 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    This really isn't that difficult. Pick a cover for a '22 or '23 that matches your bed length, read the instructions that come with it, and voila.
    22PlatWCP likes this.
  15. Dec 14, 2022 at 11:51 AM
    vroger
    Roger
    Looking at the BAKFlip MX4 Tonneau Cover for example, it shows a bolt that you bolt on, which you can't do with those rails. my old cover has the same bolts, and those rails are in the way. Hence, my question.
    Nm6300'asl likes this.
  16. Dec 14, 2022 at 11:52 AM
    vroger
    Roger
    ok, they have a install video, in which they remove the rails. so there we go.
    DFS likes this.
  17. Dec 14, 2022 at 11:59 AM
    DFS
    DFS New Member
    Answered your own question, you can do this!
  18. Dec 14, 2022 at 3:01 PM
    Lemoyne40
    Central PA
    No ... you will not need to remove it. It actually needs to stay for the locking rods to slide into. ( I think this an option you need to specify when ordering.... with or without bed rail ) You can't go wrong with this cover. Again, expensive..... but worth every nickel! If you have questions give them a call. Very great people to deal with in my experience with them.
    I think the directions said it will take you about 1 1/2 hr to install. Did mine in 45 minutes. ( I did have an extra set of hands to help) The only thing to really worry about is removing the bed rail cover. Be careful, take your time... it really just pops off. Place the stiffeners where they say they need to go....snap back on... install the cover... adjust the rods (very easy ) just follow the directions and you will not have a problem.
  19. Dec 15, 2022 at 1:59 PM
    zonehenge
    zonehenge New Member
    Pete
    Western Mass
    2022 Solar Octane TRD Pro
    285 75 18's Wild Peak, PPF for front, Go Rhino RB20 slims, Truxedo Sentry CT, TVD decals
    I have the truxedo sentry ct on my 2022 pro, very happy with it. Sturdy, low profile, and rolls up out of the way.
