  1. Dec 13, 2022 at 10:13 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    but the UCA to spindle connection.......
    I build a lot of closets. In this situation, I'd just install a vertical panel. Then you can hang the short shelves on it as if it's a wall, and the shelf layout can be different on the two sides. If you need a couple shelves full length, then just stop the vertical panel under the lowest full length shelf, if that makes sense. If you're worried about the weight, you can always double the vertical panel. Usually melamine, because you don't need to paint it and easy to clean.
    How dare you
  2. Dec 13, 2022 at 10:15 AM
    bmf4069 Captain wtf
    Yup, that's it. Anything else is way out of my league. I can run wire, terminate it, build the rack and set the equipment, but I can't do any of the other stuff. I'm but a simple man.
    NWPirate likes this.
  3. Dec 13, 2022 at 10:28 AM
    bmf4069 Captain wtf
    My "van" had to go in the shop for the trans, PW, and the brakes are starting to squeal. 13k miles. Can't say I'm not liking my replacement for now...
  4. Dec 13, 2022 at 10:29 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    No matter how many times I drive something like that, I cannot get used to the little round knob shift selector in the Daimler vehicles.
    5N0W808, GODZILLA, NWPirate and 2 others like this.
  5. Dec 13, 2022 at 10:33 AM
    bmf4069 Captain wtf
    Same. I reach for the shifter every time. I'm still not sure why they went to that...
  6. Dec 13, 2022 at 10:44 AM
    shifty` Goons of Hazzard
    I started on the other side of the panel - doing the other stuff, starting on the configuration, then racking, then learned the LV side of things when I finally got tired of paying out the nose subbing out other people to do the work.
    There are definitely guys I've met along the way I'd pay in a heartbeat to do the work, because what they do is beyond "work", it's ART. They have a passion for their job and will do it better than I ever could. But I can count on less than 10 fingers how many times I've found that in the last couple decades ... but those guys never stick around for long, are flaky as hell with their scheduling, or are booked to the hilt with work.
    https://www.youtube.com/watch?v=l-5aPNxv-pU
    bmf4069[QUOTED] likes this.
  7. Dec 13, 2022 at 10:53 AM
    bmf4069 Captain wtf
    I never put up pics of the relay cabinet I got to wire up the other day, did I? I didn't get to finish it, but spent a week just getting this far. It starts as a blank shell, we put all the equipment in, then wire it. This one is for a 230kv breaker in a substation.
    5N0W808, txagg, NWPirate and 2 others like this.
  8. Dec 13, 2022 at 11:02 AM
    Now that's what I'm talking about.
    bmf4069[QUOTED] and FrenchToasty like this.
  9. Dec 13, 2022 at 11:15 AM
    Sunnier
    Sunny
    San Diego, CA
    I don’t even have to click on it to know, that includes access to the elevator and the pool on the roof.
  10. Dec 13, 2022 at 11:23 AM
    I ended up buying a bunch of 1x3x96 top-grade pine, a couple 1.5x1.5x96 for support verticals, and 24x48 laminated pine for the shelves. I'd prefer using melamine, 20" deep, but I can only get it in 15.75" depth here. And realize in hindsight I probably should've just gotten 1x2x96 for the verticals, then narrow crown'd it to the face of the pine shelves. Maybe I'll head back up and swap out. I'd prefer oak, but FFS, I would've been paying $500 out the door. Pine set me back $300. Ouch.
    I'm just going to run the 1x3 for my horizontal lips. Top 2-3 shelf lips will run the full 74" width, and dog-leg everything up the short wall to provide a full "L" of horizontal supports. For now, it'll be five 24x48 pine shelves the whole way up on , and I'd planned to anchor the vacant corner with the 1.5x but like I said, I think I'll narrow crown a 1x2 against the shelf edges, then cut additional 1x2 to fill in between shelf boards, adding a lip, basically creating a notched 1.5x. I don't have a table saw, so notching my existing 1.5x would be a pain in the ass.
    Like this, where the brown is the 1x3 horizontals, the red is the 1.5x or 1x2 vertical support, and the manila colored crap is the 24" deep 4ft shelves.
  11. Dec 13, 2022 at 11:23 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How'd you do the QR code?
    I'd like to have some custom stickers made for each build thread attached to the corresponding vehicle
  12. Dec 13, 2022 at 11:23 AM
    I was expecting to get rickrolled. Instead, I landed here.
    RainMan_PNW, Tundra2, 5N0W808 and 4 others like this.
  13. Dec 13, 2022 at 11:37 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    What say ye?
    with a slightly leaking axle seal, think i can get it to seal if i drive around to get everything warm, then opened the fill plug and stuffed a shop vac in? Sure, the damage might already be done, it's been a while since it got the new axle, but it started leaking between ?june-july? And dec. Maybe it got hot and just pushed out since the vent is probably plugged.
  14. Dec 13, 2022 at 11:40 AM
    5N0W808, 805Tundra and NWPirate like this.
  15. Dec 13, 2022 at 11:42 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  16. Dec 13, 2022 at 11:43 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  17. Dec 13, 2022 at 11:43 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Dec 13, 2022 at 11:43 AM
    des2mtn
    SW
    Tonto cover
  19. Dec 13, 2022 at 11:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    CodyP[QUOTED] likes this.
  20. Dec 13, 2022 at 11:46 AM
    Sunnier
    Sunny
    San Diego, CA
    Well, damn, have we grown up-?!
    bmf4069, txagg, alb1k and 3 others like this.
  21. Dec 13, 2022 at 11:47 AM
    tdrich7 and 5N0W808 like this.
  22. Dec 13, 2022 at 12:25 PM
    18" TRD Off Road Wheels
    The first gen section would be a desolate ghost town... I would miss it.
    5N0W808, bmf4069, Tundra2 and 2 others like this.
  23. Dec 13, 2022 at 12:43 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Its been so hard to not heckle the lane assist/adaptive cruise thread. I've written hilarious responses a dozen times, but didnt want the whiny 3rd gen guy to get me banned.
    5N0W808, bmf4069, txagg and 3 others like this.
  24. Dec 13, 2022 at 12:58 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    is the dryer or whatever the circled doohickey on the high pressure side? I need to make a new strap bracket and move it about 1/2" closer to the consenser and up a hair for clearance. Might use txagg's torch if needed for a smooth bend. Would heating this increase the pressure enough to hurt things? Or should this sort of thing be done without any pressure? I can get the appropriate jaws for my brake line bender. But 20 year old aluminum is different.
    5N0W808 and txagg like this.
  25. Dec 13, 2022 at 1:00 PM
    Yeah it’s high pressure side, you’ll probably be ok as long as your not getting it cherry red
    Mr.bee[QUOTED] likes this.
  26. Dec 13, 2022 at 1:01 PM
    Sunnier
    Sunny
    San Diego, CA
    Great idea (I’d have never thought of); you young people :rolleyes: have it going on.
  27. Dec 13, 2022 at 1:02 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Should the system be running while heating and bending? Like a lot of little bends or 1&done?
    i really dont want any creases.
  28. Dec 13, 2022 at 1:06 PM
    Leave it off. Yeah a bunch of little bends would be best and probably less stress on the pipe vs one big bend
  29. Dec 13, 2022 at 1:24 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I just used a QR generator online. When it got to the part that wanted me to sign up, I just went back and made a screen shot. Lower res but works
  30. Dec 13, 2022 at 1:26 PM
    Sunnier
    Sunny
    San Diego, CA
    And the not-as-youngsters still win for thrifty problem-solving! :yes:
