New member 01 AC SR5
Discussion in '1st Gen Tundras (2000-2006)' started by importxpresions, Dec 13, 2022.
  1. Dec 13, 2022 at 6:10 AM
    importxpresions
    importxpresions [OP] New Member
    2001 SR5 AC Imp Jade Mica 2WD
    First of all this is a great forum. Lots of information for guys/gals looking to get into Tundras.
    We’ve been in the market for a truck for awhile and finally pulled the trigger on a local 2001 SR5 AC. Vehicle is 2wd non LSD, pretty basic but with the future addition of an eaton/detroit truetrac, it’ll be more than capable for our use. Mileage is 103k and had excellent records, the owner changed the oil by date and not mileage lol (approx 2,300 miles on the oil changes for several years). It's had a water pump replacement, all fluids changed, plugs, and dayco timing belt installed. I did look over the lbj’s/ubj’s and they are MOOGs with approx 2,300 miles on them. I’m contemplating replacing lowers with OEMs but may put 10k on them before I do so.
    We took the truck to a local Toyota dealer and dropped the spare tire and checked the frame for rust. So far just surface rust on the bottom of the frame, tow hitch, and rear axle as it was a northern MO truck, just barely on that salty line. We believe it was garage kept as the clear coat and plastics are immaculate, the clear coat/paint is basically 100%. Truck now resides in NE Oklahoma, no salt here. We're a Toyota/Lexus family and currently our families cars include a 12 Corolla, 13 RX350, 15 RX350, 17 RX 350, 17 CT200H, 17 GX460 and 17 RX350.
    My plans for the truck are:
    -POR-15 any surface rust and likely just coat the frame. I'll document before and after if we ever decide to sell it since people are wary of coated frames.
    -install Eaton detroit truetrac
    16CMTXED, bmf4069 and Jack McCarthy like this.
  2. Dec 13, 2022 at 6:14 AM
    Welcome from NY.
  3. Dec 13, 2022 at 6:17 AM
    Use the semi-gloss black if you're concerned about the coated frame. It blends perfectly with the matte black appearance of the original frame.
  4. Dec 13, 2022 at 6:48 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Nice looking Tundra. Welcome aboard!
    importxpresions[OP] likes this.
  5. Dec 13, 2022 at 7:34 AM
    Welcome! Yeah, the metallic green and metallic red often see clearcoat fail if parked out in full sun regularly.
    RE: MOOG lbj ... gotta be careful with non-OEM balljoints. Lots of pics of people's front wheels laying on the ground. And if you happened to replace the lca, know that MOOG had a big recall on them. MOOG isn't what they used to be.
    If you search this forum for balljointfail you'll see a variety examples of what non-OEM balljoint users often end up with. A few choice samples:
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1304#post-2944930
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1375#post-2989574
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1327#post-2960003
  6. Dec 13, 2022 at 8:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Dec 13, 2022 at 9:07 AM
    importxpresions
    Thanks for the heads up! I'll probably go ahead and get some factory ones ordered sooner rather than later.
  8. Dec 13, 2022 at 10:43 AM
    Nice find! Is that a trailblazer SS, or just the grass making it look low?
  9. Dec 13, 2022 at 11:52 AM
    importxpresions
    lol good spotting, regular TB. It's got 242k on it and the 4L60E trans finally went out. It'll eventually go for a transmission rebuild, the stock motor is still in good shape. If the motor went out I'd probably look at swapping an LS into it.
    bmf4069[QUOTED] likes this.
  10. Dec 13, 2022 at 12:11 PM
    I'm shocked the 4l60e lasted into the 200s, you're usually lucky to get 140k out of them. Y'all must baby that thing.
  11. Dec 13, 2022 at 12:35 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Very nice classic! Great find!
  12. Dec 13, 2022 at 1:53 PM
    importxpresions
    We did basic maintenance, synthetic oil every 5k and transmission fluid changes every 60k. We did tow occasionally with it, only small boats and trailers.
    Funny enough I changed the transmission fluid the last time and 50-100 miles later the transmission started slipping and then the fluid pump went out. Probably should have left the old fluid in there as I believe the last change of Dexron III to IV may have contributed to the failure. I should probably say "accelerated" as it was probably worn out already.
