GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Dec 11, 2022 at 9:55 AM
    #1771
    WoodfordAZ
    WoodfordAZ New Member
    Alex
    2022 White Tundra SR5 TRD
    I did a search on this thread for "ring" and "hubcentric" and found people asking the same question but no answers yet. So, here it goes. My truck is going into the shop tomorrow (12/12) for its Ikon lift to be installed. A few days ago, I picked up my 17x8.5 +35 Method 706's wrapped in Falken Wildpeak 315/70-17 from Discount tire. They said it needed a lift before they would let me drive out with them. Anyway, they gave me rings and lug nuts and sent me on my way to take everything to lift shop. I was test fitting to trim away some of the rear fender liner only to discover Discount gave me the wrong rings and wrong sized lug nuts. It's Sunday so I can't do anything about it today. Does anyone know the specs on the rings that I do need? Measuring the stock wheel it looks like 95mm ID. The ring they gave me measure about 78mm ID. Frustrating. I hope Discount has what I need tomorrow.
    Thanks for any assistance.
  2. Dec 11, 2022 at 10:52 AM
    #1772
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    I used 95mm to 106mm for my Wheels. I may be wrong, but I think 78mm is for GM.
    95mm is our hub size and it depends on your wheel hub to determine your needed rings.
    I temporarily used lug centric lugs without running rings until my hub centric rings came in. Lug size is M14x1.5….I used these.
    DYNOFIT 14mmx1.5 Wheel Lug Nuts, 32x Black M14x1.5 Lug Nut,Conical/Cone Bulge Seat, Closed End Long Extended XL Spline with 1 Socket Key Fits 8 Lug Aftermarket Wheels https://www.amazon.com/dp/B078RJ6GK6
    WHEEL CONNECT Hub Centric Rings, 106 to 95.1, Set of 4, Aluminium Alloy Hubrings, O.D:106mm I.D 95.1mm. A https://www.amazon.com/dp/B0BH3RB3TZ
    These rings fit perfect. And the reassurance also is a plus.
    WoodfordAZ likes this.
  3. Dec 11, 2022 at 1:54 PM
    #1773
    jimmyz
    jimmyz New Member
    Interior of BC
    2023 Limited Wind Chill Hybrid Crewmax
    I have had an overall amazing experience with AT3W’s.
    samwell885[QUOTED] likes this.
  4. Dec 11, 2022 at 4:22 PM
    #1774
    samwell885
    samwell885 New Member
    2022 Limited 4x4
    I ordered a set of P rated Wildpeaks and will have them on early next week! Thanks!
  5. Dec 12, 2022 at 7:17 AM
    #1775
    Breathing Borla
    Northern Illinois
    what size and weight?
  6. Dec 12, 2022 at 9:35 AM
    #1776
    samwell885
    2022 Limited 4x4
    275/60R20
    48lbs
  7. Dec 12, 2022 at 9:46 AM
    #1777
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    I'm looking at this tire size as well.
    Did you consider the Cooper AT3 4S, and if so, what made you decide on the Falkens?
  8. Dec 12, 2022 at 10:40 AM
    #1778
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    2023 Tundra CM Limited TRD OR Midnight Black
    @charlieyankee88 - Are you happy with the BFG KO2 in the snow? I got a Limited TRD OR coming in a couple of months and plan to get those tires on it before it leaves the dealer. I live in Winnipeg, Canada… snow on the ground over half the year. It’s a place where - in certain months - you only leave home to take your kids to hockey or get beer.
    jpod and Hanny-Tundra like this.
  9. Dec 12, 2022 at 10:53 AM
    #1779
    Hanny-Tundra
    Hanny-Tundra New Member
    Canadian Passport Confirmed!
    jpod likes this.
  10. Dec 12, 2022 at 11:48 AM
    #1780
    Dreyg
    Dreyg New Member
    18x9 AGP PRO Style wheels with 285/65R18 tires under $2k total. $189 per wheels from their website and come with lifetime structure warranty. Fits OEM center cap
  11. Dec 12, 2022 at 12:26 PM
    #1781
    samwell885
    2022 Limited 4x4
    They also have great reviews. I just went with a brand I recognize and I like the look. Great snow reviews.
    topdec[QUOTED] likes this.
  12. Dec 12, 2022 at 12:33 PM
    #1782
    49ºNRTH
    49ºNRTH New Member
    2022 Platinum WCP
    Can confirm the TRD center cap PT280-34221-2F fit the platinum wheels, no dust cap modifications required. It sits low enough there is no interference
  13. Dec 12, 2022 at 12:36 PM
    #1783
    Breathing Borla
    Northern Illinois
    oh man, awesome, can you get a close up of the cap from the side? it sits perfectly flush? so you just popped it off and the other one went right in? and its tight so it wont fall off?
  14. Dec 12, 2022 at 12:39 PM
    #1784
    Breathing Borla
    Northern Illinois
    those look so much better without the chrome lugs or center cap, I actually like those now!!
    49ºNRTH[QUOTED] likes this.
  15. Dec 12, 2022 at 12:41 PM
    #1785
    49ºNRTH
    49ºNRTH New Member
    2022 Platinum WCP
    It's perfectly flush and popped in same as the OE caps would. Pleasant surprise for sure as I figured I'd have to mod the dust caps
  16. Dec 12, 2022 at 12:43 PM
    #1786
    Breathing Borla
    Northern Illinois
    awesome, thanks for posting back, I like the way that looks, may even black out the TRD or something as well.
  17. Dec 12, 2022 at 12:46 PM
    #1787
    49ºNRTH
    49ºNRTH New Member
    2022 Platinum WCP
    No worries! Glad I could contribute somewhat. Next time I'm out I'll get a better picture of the whole truck, I totally agree, the wheels look decent with black lugs and toned down center caps. Now I just need to de-chrome the grille surround and call it a day...
  18. Dec 12, 2022 at 12:50 PM
    #1788
    Breathing Borla
    Northern Illinois
    ya, I have a deal with my dealer that they will replace grill surround and fender flares to color match, I will then likely swap out the tires to Cooper at3 4s 33" p-rated, keep the stock wheels and do this black lug center cap treatment and call it a day.
    The only thing Im on the fence on is leave the tailgate top piece black or color match that too. I may just wait to see how that looks with the black piece on the back before swapping it out. The grill surround and flares have to color match for me though.
  19. Dec 12, 2022 at 1:15 PM
    #1789
    topdec
    topdec New Member
    Got a great deal on a set of takeoffs for my Limited. When funds become available, I plan to get Cooper AT3 4Ss in 275/60R20.
    I like the Geolandar X-CVs and will be using them in the winter.
  20. Dec 12, 2022 at 2:04 PM
    #1790
    charlieyankee88
    charlieyankee88 Taco to Tundra
    22 SR5 TRD OR
    TRD 3" Lift, 18” Vision Manx 2, BFG KO2, Fas-Top
    @Hanny-Tundra this is my third set. I had two over the time I owned my Tacoma. I have always lived in snowy climates, not as bad as you, but in the inland pacific. For me these tires have performed very well. I would recommend them. I hope they come out with a 285 75 R18 in the future because I like the taller skinnier profile for snow and other reasons. Hope this helps, congrats on truck.
  21. Dec 12, 2022 at 2:19 PM
    #1791
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Mind sharing what lugnuts you used? Having a hard time finding the black oem style lugnuts :9
  22. Dec 12, 2022 at 2:37 PM
    #1792
    49ºNRTH
    49ºNRTH New Member
    2022 Platinum WCP
    Nice, I wish my dealer would have been able to put something like that together for me. I have most of the pieces now, just waiting on a light bar and some time to swap everything over. I'm sticking w/ the black tailgate insert and flares, actually don't mind how they look
  23. Dec 12, 2022 at 2:45 PM
    #1793
    49ºNRTH
    49ºNRTH New Member
    2022 Platinum WCP
    I got them from Canadian Lug Nut and Wheel. One thing to be mindful of, the lugs are a 22mm (like the previous gen Tundra) not a 21mm like the current gen
    I just keep a 22mm socket and breaker bar behind the seat. Eventually when the 21mm OEM black lugs are more readily available I might swap these out but they do the job for now
    jproy12[QUOTED] likes this.
  24. Dec 12, 2022 at 2:53 PM
    #1794
    topdec
    topdec New Member
    Now that I have another set of Limited rims, I'm looking to sell a set of 4 powdercoated 4Runner Trail rims...I don't have 50+ posts to be able to post on the marketplace thread but if anyone is interested, pls pm me.
    iiawah808 likes this.
  25. Dec 12, 2022 at 3:26 PM
    #1795
    iiawah808
    Oahu, HI
    Have you test fitted these to see if they clear our calipers?
  26. Dec 12, 2022 at 3:28 PM
    #1796
    topdec
    topdec New Member
    I have not test-fitted these on the 3rd gen Tundra. I could do that if anyone locally is interested at taking a look.
    iiawah808[QUOTED] likes this.
  27. Dec 12, 2022 at 6:29 PM
    #1797
    dutch2112
    dutch2112 New Member
    2023 Limited hybrid Trd
    35” Falken Wildpeak AT3, 17x8.5 method 305 nv, trd lift kit, trd pro grill, trd exhaust
    Is it strange that although I am excited to lift the truck and put my new method 305’s and Falken 35’s on that I really enjoy the stock look of my truck and my miss it?
  28. Dec 12, 2022 at 6:37 PM
    #1798
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    I don’t have a picture yet (because dirt and snow) but 275/65/20 WILL fit on a TRD Sport stock with no lift and no rub. This has been a concern because they’re a bit lower. Posting because I only found that information by searching forever so wanted to post refreshed info!
    dano7891 likes this.
  29. Dec 12, 2022 at 6:39 PM
    #1799
    topdec
    topdec New Member
    Did you find a tire in 275/65R20 that is SL or P-rated?
  30. Dec 12, 2022 at 6:50 PM
    #1800
    ColumbiaGorge
    Joe
    Columbia Gorge
    24 Limited
    No, I went with the AT3W again which are E. I had the Falkens that come on the Off-Road and they were terrible in the snow. I’ve had the AT3W on the last 3 trucks and love them
    dutch2112 likes this.
