After Market Wheels
Discussion in 'Wheels & Tires' started by trd1993, Oct 10, 2022.
  1. Oct 10, 2022 at 7:22 PM
    trd1993
    trd1993 [OP] New Member
  2. Oct 10, 2022 at 8:20 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Interesting. I have never heard of them before. Even their logo font resembles the TRD logo.
  3. Oct 10, 2022 at 10:43 PM
    SawF16
    SawF16 New Member
    Will be interesting to see if the oem caps fit or if they just come with caps that really say TRD.
  4. Oct 11, 2022 at 1:21 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
  5. Oct 11, 2022 at 1:21 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    TRD L Power likes this.
  6. Dec 12, 2022 at 11:08 AM
    Dreyg
    Dreyg New Member
    Both of these OEM Toyota center caps will work with AGP wheels
  7. Dec 12, 2022 at 11:11 AM
    Dreyg
    Dreyg New Member
    18x9 AGP PRO Style wheels with 285/65R18 tires on stock Tundra
  8. Jan 9, 2023 at 3:48 PM
    charliep
    charliep New Member
    2022 Lunar Rock Tundra TRD OR
    Pretty sure you didn’t use the factory lug nuts. Did you use a standard a tapper lug nut?
  9. Jan 9, 2023 at 8:25 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Off set and weight?
  10. Jan 9, 2023 at 11:28 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    Henry1jg and bigjuice[QUOTED] like this.
  11. Jan 10, 2023 at 12:12 AM
    MTRock
    MTRock 1889
    Montana
  12. Jan 15, 2023 at 6:10 AM
    rst
    rst New Member
    Is +12 offset the same as factory one?
  13. Jan 15, 2023 at 7:00 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Factory regular wheels are 60 offset, TRD pro is 45 I believe (could be 40 or 50, don’t remember exactly). 12mm offset is much higher and will give 2in of poke with a 35x12.5 in tire
  14. Jan 15, 2023 at 9:42 AM
    rst
    rst New Member
    Thanks
  15. Aug 27, 2023 at 8:21 PM
    AggiePhil
    College Station, TX
    What difference would off-roading make with these?
  16. Aug 30, 2023 at 7:00 PM
    Trdtundra77
    Trdtundra77 New Member
    Central Il
    2022 Tundra limited 4X4
    Did you buy tpms sensors or use your stock ones? I'm looking to get a set of these with nitto Ridge grapplers or Bfg K02s
    What size would you recommend on a stock height limited ?
  17. Aug 31, 2023 at 5:33 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    20230830_103838.jpg Purchase quality rims and tires. I bought Gen3 TRD Offroad rims used sub 500 miles with oem tires removed. I took 85 - 1/4 oz wheels weights off the rims from balancing! Can't believe how Toyota can subscribe to such poor quality tires.
  18. Sep 1, 2023 at 9:19 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I used my TPMS sensors from the TRD OR wheels. I heard of others having issues with aftermarket sensors and didn't want to go down that road.
    ChucklesToy likes this.
  19. Sep 1, 2023 at 9:26 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    @303Gen3 Which wheels were these? The 18" ones with the exposed aluminum bits or the 20" all black ones?
    I have a set of the 18" OR wheels sitting and waiting for a home.
  20. Sep 1, 2023 at 2:36 PM
    303Gen3
    Golden Colorado
    These. Near perfect. Can't imagine the tires that were on them. Likely E load and meaty. 18 inch. Gonna put all season highway tread SL on them.
  21. Sep 1, 2023 at 2:52 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have a set of those too, they came with Michelin LTX Trail tires. More of an onroad tire than snow or offroad tire, I gave them to my nephew to put on his F150. I took the TPMS out and put those in my new wheels, Those rims are sitting collecting dust now. I even have the steel spare wheel! They are too heavy to ship and local sales have a bunch online on Craigslist for really low prices like 700 for the set or 1200 for the tires and wheels. I was thinking about putting them on my trailer but the center bore is too small for most trailer hubs and pretty much every other 6 bolt truck hub. Not too sure what to do with them now, maybe a plastidip finish and use them for a second set for highway cruising.
  22. Sep 1, 2023 at 3:16 PM
    303Gen3
    Golden Colorado
    I think the original owner took the Michelin's off at or near purchase and went with a bigger/wider tire. I had the Michelin AT's on my other truck and they were very good - but not as quiet as the Yokohama's I looking at. None of what I purchased or you have available here in Colorado. You need the Tundra Express! Mine came via F150 express from TX.
  23. Dec 4, 2023 at 12:02 PM
    super_mech
    super_mech New Member
    Tundra '23 - 1794 OR
    Anyone have any resolution on these 18 inch replica TRD Pro wheels? Looking to put these on a Tundra, just a little hesitant about being able to use the stock lug nuts or if I need to purchase some special type?
    Henry1jg and forzamrit like this.
  24. Jan 4, 2024 at 8:24 AM
    forzamrit
    forzamrit New Member
    23’ Tundra Limited DC TRD OR
    Bump.
    Looking at the AGP bronze TRD Pro wheels and wondering if the stock lugs will work. Thanks!!
  25. Jan 4, 2024 at 10:43 AM
    super_mech
    No, stock lugs will NOT work. You will need to purchase some Extended Thread Acorn Lugnuts. Regular Acorn Lugnuts will only grab about 3 threads.
    Here is what I was referred to from the AGP service rep:
    https://www.amazon.com/dp/B08L75GQS3?ref=ppx_yo2ov_dt_b_product_details&th=1
    Installed with no issues so far. Have about 6K miles cross country through snow and off-roading in Moab. Torque checks good.
    See below for some detailed pics. Let me know if you have any questions, the lack of information out there is frustrating. Not a lot of info on ET lugnuts either, but here is a short summary of some critical information:
    1. ET lugnuts are required for *some* aftermarket wheels on Tundras (sometimes Tacoma?) as the lug studs are somewhat short as compared to other OEM's, and even the rear of the Tundra. Also the wheel itself might be "thicker" at the hub due to backspacing or generally more material is added as compared to OEM wheels for increased strength (another reason why the lug bores on the wheel may be reduced in size and do not accept OEM/mag-style lugnuts). Some guys have resorted to changing out these lug studs to longer versions, however there are complications there as well.
    2. The aftermarket wheel MUST accept ET lugnuts. I saw some stories of the very bottom of the wheel lug bore being too small to accept the extended collar of the ET lugnut. As such, the threads of the collar would engage the wheel lug-hole bevel, not fully seating and not allowing the 60 degree bevel of the wheel to engage with the bevel portion of the ET lugnut.
    3. The ET portion of the lugnut, or the cylindrical collar below the 60 degree bevel of the main portion of the ET lugnut (the first 4-5 threads of the ET lugnut) MUST NOT extend past the mating surface of the wheel to the vehicle hub. This might seem obvious but I saw some confusion for some, or generally forgetting to check this critical detail. Having the collar go beyond the bottom of the wheel lug-bore will allow the ET lugnut to bottom out against the vehicle hub prior to the wheel itself mating to the vehicle hub. SOme ET lugnuts are longer than others, it is not standardized or correlated to thread size and pitch.
    4. When installing the first lugnut or two, make sure the entire weight of the wheel is not resting on the collar of the lugnut. Somewhat hard to explain, but there is a very small amount of play between the ET lugnut collar and the lug-bore of the wheel. When the lugnut is installed at the 12 oclock, the wheel bore will rest on the extreme 12 oclock portion of the lugnut creating a "canted" situation or not allowing the ET portion to "sink" into the wheel past the bevel and into the bore of the lug-hole. There have been reports of the collar "breaking off" within the wheel lug-bore. As the ET portion of the lugnut is a thin-walled thread, my assumption is that it is susceptible to cracking at the interface of the cylindrical portion to the bevel/conical version of the ET lugnut.
    5. DO NOT use power tools to install these. As mentioned, the ET portion is somewhat more sensitive upon initial engagement. Also buy yourself an extra key or two. This was one of my biggest hesitations/misgiving with ET acorn lugnuts with the spline drive. I did try to find some hex head ET lugnuts, but all I could find were some chrome ones. I have seen these spline keys shatter, don't want to get stuck without a removal tool.
    Anyway I was a little hesitant about these wheels, mostly because of the lack of info first from the manufacturer on what lug nuts will fit ("special lugnuts required" ... ok???), and then lack of info or even wide usage of ET lugnuts. I think SCS wheels or some Methods use them, but not a lot of literature about it online. I wasn't trying to get into the game of wheel spacers and whatever other wonky stuff is out there. I am happy with the results so far, and will try to report back if I have any issues.
    IMG_5509.jpg IMG_5515.jpgIMG_5511.jpg IMG_5632.jpg IMG_5837.jpg IMG_5845.jpg
  26. Jan 5, 2024 at 8:29 AM
    forzamrit
    super_mech,
    Thanks for the awesome and detailed response! This is just what I needed. I was on the fence about the bronze but they look great with Army Green.
    Beautiful truck btw!! You must have one of the nicest trucks on this forum.
    Thanks again!
    super_mech likes this.
  27. Jan 6, 2024 at 6:30 PM
    dan81
    dan81 New Member
    Northern CA
    White 2023 Tundra Limited
    @super_mech apologies if you posted this already but what are the specs on your setup? Suspension/tire size etc? And these are the AGP pro replica 18”?
    as mentioned already the truck looks killer and that post was super helpful!
    super_mech and forzamrit like this.
  28. Jan 8, 2024 at 12:03 PM
    super_mech
    @dan81 I am on a stock suspension for a TRD Off-Road package. I am running BFG KO2's with a 275/70/R18 on the AGP 18" TRD Pro Replica wheels.
    Glad to help with the info!
    Team_Toyota, Henry1jg and forzamrit like this.
  29. Jan 18, 2024 at 2:30 PM
    GoTTi74
    GoTTi74 New Member
    Bay Area, California
    2022 Tundra Ltd TRD OR CM LB
    I was looking into the 18" AGPs and while looking for experience, I found your build! First of all, what a beauty!!! Second, thank you for sharing your experience and information about log nuts, etc. This is much appreciated :)
    Lastly my two questions:
    How much poke do you get, given the offset of the AGPs is +12 whereas the OEM is +60(?) and the tires are wider? On the pictures it looks like it's only a little but the angles don't provide a clear view...
    Did you reuse your previous TPMS or add new ones? I want to keep or sell my OEM wheels as is and I've heard that not all TPMS sensors work...
    super_mech[QUOTED] likes this.
  30. Jan 18, 2024 at 4:17 PM
    super_mech
    @GoTTi74 Thanks, I am very happy with the truck. Going to be a lot of good times I hope!
    I'm not sure on the measurements of what the wheel poke ultimately ended up being. I think I was willing to go up to +25 based on what I saw on other Tundra wheel setups. This ended up working fine for me with the tire combo. Some better pics below.
    I did not reuse my TPMS, I left it without as I will be putting my OEM wheels back on in summer. Yes OEM sensors are expensive, and aftermarket are hit and miss. Also the TPMS not working light on the dash is not too bad!
