What did I do wrong?
Discussion in 'Electrical' started by pvn.beluga, Dec 11, 2022.
  1. Dec 11, 2022 at 4:35 PM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    I should have tested the lights prior to completing wiring to see if the lights would power up. I did this prior to my CaliRaisedLED ditch lights and they worked, but I'm not sure what step I did wrong in the process of trying to wire up my Squadron Sports to my Auxbeam.
    So what I did was cut the 2 plugs from the relay, fuse, and switch leaving the plugs (Black and White) on its' own.
    Twisted the whites to whites, and blacks to blacks to create a split for the Black and White wire that would eventually run to the Auxbeam. Crimped the twisted whites to the single white wire, and crimped the twisted blacks to the single black wire.
    I figured white to whites and blacks to blacks would be correct, but is this the reason why there isn't any power running to the ditch lights?
    Educate me on this...
  2. Dec 11, 2022 at 6:09 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Did you by chance blow a fuse?
    pvn.beluga[OP] likes this.
  3. Dec 11, 2022 at 7:32 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Honestly don’t think so. I’ll have to check the 30A mini fuse.
  4. Dec 11, 2022 at 7:33 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Black and white should just be positive and neutral right?
  5. Dec 11, 2022 at 7:36 PM
    Outbound
    Aaron
    Northern Alberta
    I'm no electricity-ologist but red is usually positive, black is negative, white is neutral.
    bulldog93 likes this.
  6. Dec 11, 2022 at 7:37 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Try flipping the plugs/connectors if possible? I thought my new led fog lights were broken but I plugged in the oem connectors upside down which the style lets you do.
  7. Dec 11, 2022 at 8:40 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    My old ditch lights ran red/black too… except the Squadron Sports ran white/black…
    If I were to split the black and white, how would I run a red for positive?
  8. Dec 11, 2022 at 8:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    There are general conventions that say red is positive and black is negative in DC wiring, while black is hot (+) and white is neutral (-) in AC wiring. But truth be told, it really varies. The only hard/fast rule is that in AC wiring, only a ground can be bare and all hot wires in a box must be identified as hot if they enter the box with white insulation (i.e. with a red or black wrap of tape).
    This is why no one should ever rely solely on color of wire when tapping or cutting factory wires. Always verify actual pin-out and function.
    There’s a good chance you may just be wired backwards and a quick swap will fix it. Try that first, then look for blown fuse, then bad splices or bad connections. Eliminate one variable at a time. Try powering the light directly off the battery to confirm polarity. Etc.
  9. Dec 11, 2022 at 8:53 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Would it be ok to touch the black to positive and white to negative on my battery? Or… should I not try that?
  10. Dec 11, 2022 at 8:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Shouldn’t do any harm. Check the lights directly and see which way they light up. Then work your way out from there through your wiring harness to be sure all this connections are good. Finally, connect to the auxbeam. If one position doesn’t work, then check on a different switch/position.
  11. Dec 11, 2022 at 9:18 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Just found a video of what exactly I did.
    https://youtu.be/M3wRJe7ws3M
    So this guy actually created a 3rd plug after the Y split. I actually did a Y split using heat shrink crimps and just ran the black white directly to the Auxbeam. What would the 3rd plug do in this situation?
  12. Dec 11, 2022 at 9:20 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I’ve had two sets of bajas do this same thing to me. Try reversing the wires, the polarity is probably wrong
  13. Dec 11, 2022 at 9:27 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    So the plugs itself were already installed on the wiring harness. I know that when I installed the harness for the Squadron-R that the A B had to match both sides…
  14. Dec 12, 2022 at 5:48 AM
    Outbound
    Aaron
    Northern Alberta
    That's entering into the realm of voodoo magic for me. Sorry, I'm not much help when it comes into the more advanced pixie wrangling.
  15. Dec 12, 2022 at 12:00 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Let me check my fuse.... it seems like baja runs white as positive and black as negative...
    @Baja Designs
    NoMoreGreen likes this.
  16. Dec 12, 2022 at 3:47 PM
    newwelder27
    newwelder27 New Member
    2021 Tundra SR5 TRD 4x4
    Led bed lights, RLB switch controller, ARB air compressor, ditch lights
    So white is your positive and black is your ground. Here is a schematic to help you out. The teal is if you are using a spot or auxbeam type switch panel and the other color is for just to like a rocker type switch.
  17. Dec 12, 2022 at 3:49 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Look at that properly drawn electrical circuit. Nice. ✅
    RainMan_PNW and pvn.beluga[OP] like this.
  18. Dec 12, 2022 at 3:55 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Holy cow! Haha, man that's extremely advanced for me. But I think I'm understanding it. So I think at this point, I may have blown a fuse by putting black to positive and white to negative when turning on the ditch lights. I'll keep you guys updated.
  19. Dec 12, 2022 at 4:31 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @pvn.beluga, The white is the positive and the black is your negative.
  20. Dec 12, 2022 at 4:40 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Your 55" universal harness is essentially a y-split to female delphi?
    Baja Designs[QUOTED] likes this.
  21. Dec 12, 2022 at 4:46 PM
    Baja Designs
    San Marcos, CA
    Yes, this allows you to essentially run two lights off a single female Delphi plug. I replied to your other thread if that helps.
    Best,
    Brandon
  22. Dec 12, 2022 at 4:57 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    So the harness you suggested comes in red/black... and the harness that comes with the lights is white/black. Is there a difference?
  23. Dec 12, 2022 at 5:06 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you run power to the relay? Connect the main red and black wires to your battery posts.
  24. Dec 12, 2022 at 5:16 PM
    Baja Designs
    San Marcos, CA
    For that splitter, the red is going to be the positive lead and the black is your ground.
    Best,
    Brandon
  25. Dec 12, 2022 at 5:21 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @pvn.beluga I hooked up a double relay harness to my Auxbeam this past weekend.
    Run these to your battery posts
    Then take the terminals that run to the harness switch and cut accessory and ground terminals off. Run the accessory wire to + and the black wire to - on the Auxbeam. You won't use red.
  26. Dec 12, 2022 at 7:27 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I completely cut out the relay and the switch wires because I assumed I’d be able to run black white directly to the Auxbeam switch panel.
  27. Dec 12, 2022 at 7:38 PM
    newwelder27
    That looks right from what I can see. Those wires are on the 30amp fuse. It should work what model aux beam you have?
  28. Dec 12, 2022 at 7:47 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I’m using the 8gang. https://auxbeam.com/products/qp006232
    The 1st switch runs from the right side of the panel. Evens/Odds
    Sorry it’s a bad photo too.
  29. Dec 13, 2022 at 10:25 AM
    Baja Designs
    San Marcos, CA
    Have you checked the continuity coming through the wiring harness right before the plug on the lights? If all is correct and the light has power but won't turn on you can have the lights sent in under warranty and we can cover the repairs if they are damaged. Here is my email if it comes to that point, brandonk@bajadesigns.com.
  30. Dec 13, 2022 at 11:06 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    We may have blown the 30A fuse. Going to swap it out and see.
