Power Steering Error message
Discussion in '3rd Gen Tundras (2022+)' started by TundraTRDman, May 17, 2022.
  1. May 17, 2022 at 3:53 PM
    TundraTRDman
    TundraTRDman [OP] New Member
    2022 Tundra Limited TRD off road Double Cab
    Just received this error message stating "Power Steering Malfunction Steering Power Low Visit Your Dealer" The steering appears to be working OK. Anyone seen this before?
  2. May 18, 2022 at 4:09 PM
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    Happened to me once when my truck was new. It cleared itself and never happened again.
  3. May 19, 2022 at 4:42 AM
    TundraTRDman
    I had the message all day, even after shutting the truck off and restarting. This morning I go out and start the truck and the message is gone. I guess I'll wait and see if it comes back. Spoke with my Toyota dealer service advisor and he had no idea. ???
  4. May 20, 2022 at 8:23 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Id probably take it into dealer and have them scan the computer, even if it went away. It should have a stored code if it cleared itself. Want them to at least have a record of it happening, so it if happens again and same code they have something to follow.
    Mattedfred and wing-2 like this.
  5. May 20, 2022 at 9:41 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Had it come up once when the truck stalled out in a parking lot during a tight (& fast) turn. That was around 5k or 6k miles. Hasn't happened since. I'm at about 13k miles now.
    On a side note: The 2022 Tundra steering system is a "fly-by-wire" type of system. Your steering wheel isn't directly connected to the steering rack via a steering box & shaft. It's more efficient than old hydraulic-assisted steering but more complicated. You move the wheel which tells a computer to moving the steering rack.
    The error code will be stored in the ECM module so they'll be able to pull the history when you take it in.
  6. May 20, 2022 at 9:48 AM
    Vermilion
    Vermilion New Member
    had it happen once with my 2020 Highlander. Cleared itself and never came back
  7. May 20, 2022 at 9:59 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    The tundra still not that advanced yet. :( It has steering shaft connecting the steering wheel to the steering rack. It just electronic power steering not hydraulic.
    Lee.M, Mattedfred and pwpblue like this.
  8. May 20, 2022 at 10:41 AM
    KroppDuster
    Bilstein 5100s
    That's good to know. I guess I'll find the article that talked about the electronic steering system for 2022 and send a correction. haha. They equated it to fly-by-wire and that wheel feedback is simulated. I guess you can't believe everything you read on the internet. lol
    TakiEvo[QUOTED] likes this.
  9. May 21, 2022 at 3:54 AM
    TundraTRDman
    I have an appointment with the dealer to check it out on Tuesday. We will see if anything comes out of it. Still no repeat of the error message.
  10. Jun 6, 2022 at 10:31 AM
    BadFish3rdGen
    BadFish3rdGen New Member
    Randy
    2022 SR5 Lunar Rock TRD OFF Road
    Just happened to me. Low speed driving through town. Nothing crazy. Steering is not affected at all. I will take it in to dealer tomorrow morning cause i am on shift tonight. Hoping it erases itself by then.
  11. Jun 6, 2022 at 10:45 AM
    EmergencyMaximum
    I have the same system in my venza(2013), never had this sort of warning or message pop up. Feels like normal steering.
    Boy, these new tundras just keep on giving...messages :)
  12. Jul 22, 2022 at 6:42 PM
    GranolaJones
    GranolaJones New Member
    2023 Tundra
    Mine just gave me this at 417 miles. Do you mine sharing what the dealer said when you took yours in?
  13. Oct 18, 2022 at 7:42 AM
    ktundra2022
    ktundra2022 New Member
    2022 sr5 TRD
    I've got this truck in January 2022. I live in the South (AL) and was planning to give this to my father within 3 years and he live in the North (MI). I've experience this issue multiple times already and this time is the last time I am willing to let the brand new truck (with 2,658 miles in) that cry's power steering malfunction for the last time. I'm taking a lost but I'm selling it and not waste my time and worry about it in the long run or potential issue that may cause an accident driving down the highway because Toyota is not addressing this issue (software or hardware). I've also got my rearview mirror replaced because it will sag down within 3-5 days. Yes, I know there's a digital but I like to use the standard mirror but this shouldn't of happen either way. See below for the summary of my visits to the service department.
    1st visit: power steering malfunction notice came on during end of Jan or early Feb (cold-ish weather month). Went to the dealership and they reset it and said nothing to worry. Went home thought everything was fixed.
    2nd visit: truck got towed to Toyota. Service guy told me the bad news. The power steering rack has to be replace. I was like sure let's do it and hoping that it will resolve it. Except the fact that it only take one month in the shop (some states if a vehicle is out of service for 30 days it is consider as a lemon per regulation). Power steering rack got replaced and system reprogram. This was around Feb. or Mar. timeframe.
    3rd visit: Truck was in the shop for one week 10/7/2022-10/15/2022. They reprogram the system and if the light comes on again they will have to replace the rack again. I have my suspicion, if it's a hardware issue (i.e., power steering rack) then it should resolved the issue once it was replaced in the 1st time around. What are the chance of having two bad power steering rack and it whole unit.
    Warning light came on again today (10/18/2022), current temperature where I'm at is 42 degree.
    Summary: I've noticed the warning only comes on and have steering issue during cold start and only when the temperature drops to the 30s or low 40s degree. I can put money on it that when the temperature rises later on in the afternoon, the warning will disappear and the power steering will be working properly again. Living in the South I have no problem with it durning warmer weather months but if this truck goes to the North that is 6+ months out of commission. I'm not a programmer or a mechanic but I know a little or two about software and programming. If this is a programming issue, this shouldn't happen durning cold start as software don't care about temperature. This also means the software has to implemented across all Toyota not just my vehicle/few trucks. Plus, it takes time for software developer to update their program. If it is a software issue then why it is not a recall on it already for everyone to have their truck to update their software. This is a hardware issue somewhere else not on the rack that cause the lost of communication durning cold temperature. I hope this helps those that is dealing with this issue. My trust in Toyota has gone down the drain.
  14. Oct 18, 2022 at 7:53 AM
    KroppDuster
    Bilstein 5100s
    Welcome to the forum, and I guess also "goodbye" (since you're selling the truck). Sorry this was your first post here.
    I was having a little trouble following your post, but if I catch the gist of it...I would pursue action via a lemon lawyer before outright selling. Especially, if as you say, you're going to take a loss on it. If it qualifies, and you win your lemon case, it will help mitigate your loses.
    All the best to you.
  15. Dec 11, 2022 at 2:50 PM
    Delta6
    Delta6 New Member
    Just wanted to give an update about the power steering issue related to this thread. Apparently I purchased the Tundra that ktundra2022 was having issues with and sold. I reached out to him with no reply, but based on his issue and the service records, everything matches. This is also the only place I’ve found that has posted anything about this particular issue. I bought the truck from a local dealership in AL and was told there was a power steering issue that needed to be corrected before delivery. I wrongfully assumed it was something minor, but was later told the entire rack was being replaced. It was no big deal to me because I was a current Toyota owner and have owned Toyotas in the past with no issues. To make a long story short, after the rack was replaced and the truck was delivered the same power steering warning come back on. I confronted the GM of the dealership about the issue being a known issue with this particular truck and was told they would make it right whether with this truck or getting me a new one. The dealership got their regional rep involved and ultimately I was told the issue was traced to a plug that was not connected from the factory. The GM said there was two power sources for the power steering, a primary and a secondary. Apparently a wire from the secondary power source was the problem. I’m not a mechanic and don’t know anything about the new system. All I know is I really like this truck, have driven it a few weeks since the repair and after a couple of weekend trips there are no issues. Hopefully this problem isn’t a big one, but maybe this post will help someone else out.
  16. Dec 14, 2022 at 3:35 AM
    Toolslinger
    Toolslinger New Member
    Eastern PA
    2023 Limited - Blueprint, DC, 6.5 Bed, 4x
    Man, that's a whole lotta trouble over a bad connection... Hope that is really the issue.
    Delta6 likes this.
  17. Dec 16, 2022 at 6:14 AM
    WicWico
    WicWico New Member
    Happened to me this week at 10,600 miles. :/ Drove it home. Two hours later the message was gone. It cleared itself.
  18. Dec 16, 2022 at 7:02 AM
    Delta6
    Delta6 New Member
    Yes, that appears to be the case with most people who’ve had the problem. Unfortunately my vehicle would clear the warning, but it would always come back.
  19. Jul 31, 2023 at 12:51 PM
    bbigelow6573
    bbigelow6573 New Member
    2022 Crewcab Platinum
    Has anyone here had there engine shut down do the the steering?
    I had to have my truck towed to the dealership
    iKampz likes this.
  20. Jul 31, 2023 at 8:44 PM
    xc_tc
    xc_tc New Member
    Your engine shut off for another reason. Since the steering is electric, you get this warning when then engine shuts off abnormally.
  21. Jul 31, 2023 at 9:12 PM
    bbigelow6573
    So far the shop can’t find around the battery why there was electrical smoke and no errors. The area toyota rep will be here on Wednesday to look at it. I hope something is figured out.
  22. Aug 1, 2023 at 5:16 AM
    EmergencyMaximum
    That voltage looks a little low on the gauge.
  23. Aug 15, 2023 at 1:05 PM
    scruff1221
    scruff1221 New Member
    2022 Tundra Trd Off-road
    Had this same fault/error on cold start Saturday--Did not drive and left parked
    Started up Monday to drive to dealer--Fault is gone
    Got call today notifying I need a new rack and pinion : (
    Any thoughts on long term issues etc?
  24. Aug 15, 2023 at 1:53 PM
    bbigelow6573
    Well, my issue was a recirculation pump. They replace it now I have a knocking coming from the engine that they don’t know what it is
  25. Aug 15, 2023 at 2:33 PM
    iforceAZ
    iforceAZ New Member
    Is this system purely an electric motor system?
    Are any hydraulic fluids or pumps involved at all?
  26. Jun 19, 2024 at 10:33 AM
    2024 tundra sr5
    2024 tundra sr5 New Member
    that happend to my tundra too when it was brand new.2024 toyota tundra sr5.the dealer sayed that airpump? was loose.
  27. Jun 19, 2024 at 10:47 AM
    scruff1221
    Had the same fault at 22 K miles--Had to have rack and pinion changed out
  28. Jun 20, 2024 at 1:33 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    AKA I was doing donuts, lol.
    pwpblue likes this.
  29. Jun 10, 2025 at 11:23 AM
    Jflo1794TRD
    Jflo1794TRD New Member
    NorCal
    2023 Tundra 1794 trd off road 4x4
    So something similar happen to me yesterday. Truck stalled after pulling out of the highway shoulder. Ended up receiving two messages for 10mins then the engine finally shutdown and I was on full electric mode at very low speeds for about 2mins. That’s when I found parking. Turned the truck off and couldn’t start it again.
    Anyone experienced this ? I have a 2023 Tundra Hybrid with 43k miles .
  30. Jul 11, 2025 at 10:17 AM
    Tundra-Val
    Tundra-Val New Member
    Have a 2022 Tundra SR5 with 21K miles. Got the same message last night 07/11/2025. this morning when started the message was gone. Checked battery and is fine.
