De badging and those dam stickers
Discussion in '3rd Gen Tundras (2022+)' started by Ruger19, Dec 7, 2022.
  1. Dec 7, 2022 at 9:03 AM
    Ruger19
    Ruger19 [OP] New Member
    2022 Tundra
    Got around to de badging my new ride. Badges came off easy. Used heat gun, fishing line, and finished off with some 3m adhesive remover (the stinky stuff). Turned out flawless.
    But those back stickers are a bitch. Have one left to do. Has anyone else had this problem? Maybee an eraser wheel? I've done this to the last 3 Toyota trucks I've owned and have not come across this Issue. Stickers are thick and have 2 layers.
    Vr0ck and iiawah808 like this.
  2. Dec 7, 2022 at 9:36 AM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    LOL…..I’m in the exact same boat as you with the damn bed decals. Horrible time so far. Haven’t even finished one.
  3. Dec 7, 2022 at 9:37 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I wonder if your dealer could help or advise? Pretty certain mine would.
  4. Dec 7, 2022 at 9:39 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've read the eraser wheel takes paint or clear coat off
  5. Dec 7, 2022 at 10:20 AM
    Justin Case
    Justin Case New Member
    The TSS decal is the only thing I have left to show for the ~6k TSS package so I left them on when doing my de-badge. Glad I did not attempt removal.
  6. Dec 7, 2022 at 10:33 AM
    Ruger19
    2022 Tundra
    The SR5 4x4 has two on each side and one on the tail gate and those dam stickers:(
  7. Dec 7, 2022 at 10:34 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Not if you use it correctly.
    One needs to be aware of the RRMs of the drill or driver.
    Keep the RPMs low.
    If the RPMs are too high or you apply a constant pressure (too much heat), you're likely to damage the paint
    I removed my TSS sticker with a 3M eraser wheel the day I bought it home.
    Flossed the badges off with a fishing line and used the eraser wheel to remove the residue.
    Used denatured alcohol for removing the sticky residue.
    I've used it on a few vehicles to remove dealer stickers and decals.
    I wouldn't touch Toyota paint with a heat gun, it's too fragile.
    https://youtu.be/yAa_mf-Gpbs
    Personally, I would use a 3M eraser wheel over a cheaper knockoff.
    This has examples of how much heat is generated using an eraser wheel and which one he feels works better.
    https://youtu.be/7Y_2DYBwoTU
    Yaboy and texasrho83[QUOTED] like this.
  8. Dec 7, 2022 at 10:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wouldn't trust myself with it lol. I've yet to meet a decal or badge I couldn't wrench off with spit and elbow grease.
  9. Dec 7, 2022 at 10:51 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I tried to peel that TSS decal off in one or 2 pieces and that wasn't going to happen.
    https://youtu.be/WB27bqr7kJQ
    OHwendTrd and texasrho83[QUOTED] like this.
  10. Dec 7, 2022 at 10:58 AM
    Tb2
    Tb2 New Member
    James
    heat gun
  11. Dec 7, 2022 at 11:19 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Is the adhesive remove you used in a black can or red/white can?
  12. Dec 7, 2022 at 11:21 AM
    Ruger19
    2022 Tundra
    I have a 3M eraser, just haven't attempted it yet. Probably finish it up this weekend and stop being a wussy.
  13. Dec 7, 2022 at 11:22 AM
    Ruger19
    2022 Tundra
    Red and white can
    Doxiedad likes this.
  14. Dec 7, 2022 at 11:42 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Mine came off in one piece
  15. Dec 7, 2022 at 12:08 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Lucky you.
    It was a pretty chilly December day when I did mine.
    That sticker didn't have a lot of flexibility.
    Besides, I had fun using the eraser wheel.
    I knew I was going to use it for my 2014 badges being that I used it to debadge my 2005..:D
  16. Dec 7, 2022 at 12:16 PM
    Ruger19
    2022 Tundra
    One piece, was it a Gen 3 ?
  17. Dec 7, 2022 at 12:38 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    No, @texasrho83 and I drive Gen 2.5 Tundras.
    Your best bet would be a 3M eraser wheel.
    Go slow and under whatever RPM is read on the wheel..
    Mine reads 'do not exceed 4000 RPMs'.
    texasrho83 likes this.
  18. Dec 7, 2022 at 1:21 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    ^This
  19. Dec 7, 2022 at 2:09 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  20. Dec 8, 2022 at 2:18 PM
    Ruger19
    2022 Tundra
    Job complete. The 3m wheel worked like magic. Cordless drill and low rpm. Took my time and was finished in 15 minutes. No adhesive to remove and zero scratches. B013SfpntiEAeOIyeM5vGj_UL6uAmUHgDfQU4ri4_d7021d38f0005361d272ad4df1952fb5256d0127.jpg 0L8SJLhCAIKyRHGgV-j0H3vIYsrXQfJUqZ6ockB1_f54b40151e163bd165fe164f6f3838974884a603.jpg
    Siblue, 1lowlife, motojunkie and 3 others like this.
  21. Dec 8, 2022 at 4:44 PM
    motojunkie
    motojunkie New Member
    South Florida
    2022 Tundra TRD OR 2023 Supra GR
    Yep these new TRD bed decals are a pain to remove! They don’t peel right off like the Tacoma ones. That’s how I got mine off. I was so scared but it came out perfect.
  22. Dec 8, 2022 at 6:01 PM
    GoTTi74
    GoTTi74 New Member
    Bay Area, California
    2022 Tundra Ltd TRD OR CM LB
    Yup, the TRD decals are not the easiest. I used a plastic razor scraper, a heat gun and some Goo-Gone and it took me 45-60 minutes on the first side. Tried without heat gun on the other side and it was off in ~30 minutes.
  23. Dec 8, 2022 at 6:25 PM
    weshoover
    weshoover New Member
    Wes
    2022 tundra crewmax lb trd off road
    eraser wheel is a must still took me about 25 mins per side had to go pretty hard at it. ended up having to do i little bit of a buff job on the paint after as I pushed too hard with the eraser wheel so be careful. never came across a decal harder to get off.
    1lowlife and iiawah808 like this.
  24. Dec 8, 2022 at 10:34 PM
    mgotham
    mgotham New Member
    CA
    2022 Army Green TRD Off-Road
    I was going to post a thread on this because I went through the same ordeal. Just never got around to it.
    I was trying to take off the rear bed decal and instantly noticed it was nothing like my tacoma or any of the numerous vehicles I’ve debadged in the past.
    Tried with a heat gun and it only took off the top sticker layer. Tried goo gone and adhesive remover that did nothing. Drove to my local wrap shop for help and they had no clue and hadn’t seen anything like it.
    Finally I searched on here and saw one post about the 3m wheel. Drove to auto zone and got one for 30 bucks and it did the trick. At first it left some cleaning to be done after but I just used a microfiber and some polish and it looks like glass.
    Hopefully people read here before attempting with anything else because it simply won’t work.
    142BE878-A97C-4C69-A56F-8AEF43BBAAA3.jpg DD9DE4C5-93DD-446D-847E-25A8B955902E.jpg
    LakeLife, 1lowlife and iiawah808 like this.
  25. Dec 9, 2022 at 3:51 AM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2008 Limited Double Can 2WD
    Wrong, it does not damage the clear coat.
  26. Dec 9, 2022 at 4:20 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Anyone have experience removing the tailgate raised lettering? Its a totally different type of sticker. I dont think the 3m wheel would work.
  27. Dec 9, 2022 at 5:50 AM
    DeafJam
    DeafJam New Member
    Louisiana
    2023 Toyota Tundra Hybrid, 1794 edition
    Cosmetics for for a pavement princess.
    He isn’t wrong and neither or you I would suppose. If the operator is smart, you are right, if the operator is on the left side of the bell on IQ, he is right.
    You can damage paint with a rotary when cutting and polishing if you don’t control the heat. I don’t trust myself, so I have a double action for that. A giant eraser spinning at 2 to 4k rpm’s can generate a lot of heat if someone is brain dead about what they are doing. Go look at reviews of some poor dudes erasing cars that aren’t clean, or stripping clear off on Amazon. They have then.
    A man can try to build idiot proof tools. God will show man his fallacy and build a better idiot. God wins every time.
    22whatwedo likes this.
  28. Dec 10, 2022 at 1:05 AM
    iiawah808
    Oahu, HI
    Finally killed my decals with the 3m wheel. Made easy work of it. Little bit of polish and like mentioned before….glass.
    So much better
    mgotham likes this.
