2016 121,000 miles needs new transmission
Discussion in '2.5 Gen Tundras (2014-2021)' started by AndrewSR5, Dec 9, 2022.
  1. Dec 9, 2022 at 12:42 PM
    AndrewSR5
    AndrewSR5 [OP] New Member
    Suburbia, Tx.
    2016 CrewMax SR5
    Recently I knocked the rear axle out by hitting one of the little "U" poles next to a gas pump.
    Axle replaced (along with surrounding parts) Reputable garage, I trust them.
    I get the truck back and about 2 weeks of normal driving it slammed into gear one morning. Check engine light and "Traction control off" on the dash.
    It drives fine, but when the the motor is cold it doesn't shift out of 4th on it's own. I release the gas and it shifts. Once it's warmed up it drives normal. (Drove like this for about a month)
    I take it back and they tell me it's not related to the original issue. I'm not mechanically literate to intelligently argue about it.
    Does this seem right?
  2. Dec 9, 2022 at 1:43 PM
    What’s the service history on the transmission?
    FlyingWolfe likes this.
  3. Dec 9, 2022 at 1:54 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    What were the codes when the dash lit up? Are you sure it shifted into higher gears when cold previously? Mine won’t shift into higher gears when cold either, (not sure if it holds in 4th or 5th) until a mile or two down the road. I assume it’s tuned this way as not to lug a cold engine.
    norma30a, TTund16 and AZBoatHauler like this.
  4. Dec 9, 2022 at 10:20 PM
    AndrewSR5
    Suburbia, Tx.
    2016 CrewMax SR5
    Never touched it.
  5. Dec 9, 2022 at 10:22 PM
    AndrewSR5
    Suburbia, Tx.
    2016 CrewMax SR5
    Definitely shifted before; like night and day.
    I didn't get the codes.
  6. Dec 9, 2022 at 10:33 PM
    I would suggest a full service on the transmission first.
  7. Dec 9, 2022 at 11:04 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is it 2wd? Is so, and if the driveshaft was removed from the transmission at any point during the repair or for towing, you very well might have low transmission fluid.
  8. Dec 9, 2022 at 11:36 PM
    Good point.
  9. Dec 10, 2022 at 9:12 AM
    AndrewSR5
    Suburbia, Tx.
    2016 CrewMax SR5
    It is 2WD. I will bring that up to them, thanks.
    AZBoatHauler likes this.
  10. Dec 11, 2022 at 6:43 AM
    2mchfun
    Not sure if it will help, but you could always try to disconnect the battery for a bit and let everything reset and relearn. As mentioned above, make sure the fluid level is right. Highly doubt it is related to your wheel catching the post.
    baraynavab likes this.
  11. Dec 11, 2022 at 7:15 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Yeah 2nd resetting the tranny and checking the tranny fluid making sure you have enough.
    2mchfun likes this.
  12. Dec 11, 2022 at 8:46 AM
    Justin Case
    Justin Case New Member
    Would def check trans fluid level yourself. Lots of info posted on site. Some shops are not aware of how to check or set proper level.
    AndrewSR5[OP] and 2mchfun like this.
  13. Dec 12, 2022 at 9:36 AM
    AndrewSR5
    Suburbia, Tx.
    2016 CrewMax SR5
    What does a transmission service include?
  14. Dec 12, 2022 at 12:03 PM
    Rocko9999
    Rocko9999 New Member
    Drain and fill.
  15. Dec 12, 2022 at 1:41 PM
    Drain and fill, and the technician will cycle all the solenoids to check for function, change filter (if needed).
  16. Dec 30, 2022 at 4:48 AM
    AndrewSR5
    Suburbia, Tx.
    2016 CrewMax SR5
    After service was done now it's worse.
    insurance is saying they don't know this was caused by the incident; and they need to open the transmission to find more info which I would be responsible for in the event they do not cover the replacement.
    They are doing more "Research"...
    Chadwicktr and 2mchfun like this.
  17. Dec 30, 2022 at 5:47 AM
    Thanks for the update. Keep us updated on what the outcome is.
    2mchfun likes this.
  18. Dec 30, 2022 at 6:00 AM
    centex
    centex New Member
    It’s very possible that something internal got damaged when the axle was damaged. Not sure how fast you were going or which direction but if it was hard enough to take the axle out then the shock could have gone right up the driveshaft into the transmission.
    hagrid, MedCityMoto and snivilous like this.
  19. Dec 30, 2022 at 7:15 AM
    2mchfun
    There is a chance of damaged internals in the rear differential. Somewhere on here, I read that a rear gear was cracked from an impact. Maybe something going on in there causing the tranny to respond in a strange manner. Not likely, but I think it might be worth jacking it up and throw it in neutral, then manually spin the tires and see if all rotates in a relatively smooth manner in both directions. Just a way to try and narrow it down a bit. Another option would be to change the rear differential oil and see if any metallic shavings or chunks appear in the old oil. Be honest with us and tell us more about the collision too. Did it hit hard and knock you around a little bit inside the cab?
    Edit: oops! Forgot to read your OP again!
  20. Dec 30, 2022 at 7:19 AM
    2mchfun
    Apparently the thing took a big enough wallop to need a new rear axle. Definitely enough to damage the transmission. I have zero doubt now.
    Rocko9999 and JLS in WA like this.
  21. Dec 30, 2022 at 8:51 AM
    clarkritchie
    clarkritchie New Member
    Maybe it's just me, but I'm struggling to picture what a little "U" pole next to a gas pump looks like, and how hitting one knocks the axle out.
  22. Dec 30, 2022 at 9:08 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Thinking something like these, not turning wide enough, and the Tundra was in a desperate hurry for a drink??
    norma30a likes this.
  23. Dec 30, 2022 at 9:18 AM
    clarkritchie
    Aye aye. But I'm still struggling to get my head around the angle, not to mention the speed, at which one must be going to collect with this to cause this sort of issue.
  24. Dec 30, 2022 at 9:18 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    If the rear axle was forced forward, I could see the driveshaft yoke running out of clearance and damaging the transmission internals. If the axle was forced backward, then not sure how it could have damaged the transmission.
    landphil and snivilous like this.
  25. Dec 30, 2022 at 9:21 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    That's what I imagined but in my mind's eye the pump was displaying Nascar logos... ;)
    I wonder just how much forward progress was required to upset the axle in an area that isn't exactly suited to boy racer stunts?...
  26. Dec 30, 2022 at 9:25 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Damn this almost happened to me too one early morning before coffee, but my sliders kickout saved me and instantly paid for itself. Sorry for the troubles OP.
  27. Dec 30, 2022 at 9:39 AM
    clarkritchie
    Maybe the OP can clarify what exactly happened here.
    What I'm picturing is: pulls in to get gas, when done, can't exit forward and so decides to back up (the direction of travel of the arrow here), and so cranks the steering wheel and somehow or other the rear wheel got snagged up on the bollard, e.g.
    These bollards are pretty clearly blue Loctite'd in place, thank god they did not use red.
  28. Dec 30, 2022 at 10:03 AM
    Bammer
    Monroe, CT
  29. Dec 30, 2022 at 1:29 PM
    2mchfun
    I Imagine the assembly was in rotation with a significant amount of torque going through it and then an instant sudden complete stop occurred at which time there is a chance that even more force was applied to the skinny pedal momentarily...not good and likely the cause for improper transmission function.
  30. Jan 1, 2023 at 8:31 AM
    blanchard7684
    blanchard7684 New Member
    Struggling to see how even rear axle damage occurred with this scenario unless it was at speeds above 30 mph which is nuts.
    given service history it is likely a valve body solenoid that is sticky.
    I've had cold shifting that was super harsh even when truck was new. I also have seen shift strategy change when ambients are below 40 deg F.
