2022 Tundra Prinsu Rack Install Help
Discussion in '3rd Gen Tundras (2022+)' started by ByeF150HelloTundra, Dec 8, 2022.
  1. Dec 8, 2022 at 2:58 PM
    ByeF150HelloTundra
    ByeF150HelloTundra [OP] New Member
    DFW
    2022 Tundra SR5
    Looking for some guidance on this install. Followed their video and got stuck when drilling holes through the roof. There are 8 holes total. The 2 rear-most holes drilled through with a 1/8 bit up to a 3/8 and I got the plus nuts installed. For the other 6 holes, I’m only able to get through it with the 1/8 bit. My 3/8 cobalt bit is barely doing anything. Seems like it’s reinforced steel. Using a Dewalt drill with a 20V battery if that helps. Any tips?
  2. Dec 8, 2022 at 3:20 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I'm 99% sure that it's all the same exterior steel. You sure your bit isn't just dull?
    Also...I'm sure they've called it out but it's worth mentioning if they didn't...are you using a depth collar on your bits? You don't want to drill into the overhead SRS airbags.
  3. Dec 8, 2022 at 3:45 PM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Yep, using a depth collar. And yeah, I’ve tried 3 different new bits with no apparent progress. Guess I’ll try a titanium step bit to step up from my 1/8 to a 3/8.
  4. Dec 8, 2022 at 7:45 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Are you really drilling holes through your trucks roof?
  5. Dec 8, 2022 at 8:46 PM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Yeah, it’s done all the time. Understand that it’s not everyone’s thing though.
  6. Dec 9, 2022 at 8:53 AM
    KroppDuster
    Bilstein 5100s
    First time I ever installed a snorkel there was a certain amount of pucker factor drilling an 6" hole in the fender of a $40k vehicle.
    But, once you get over the mental hurdle of the first one, all the rest of the holes across all the other vehicles are pretty easy. hahaha
  7. Dec 9, 2022 at 9:29 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Get yourself a cobalt bit set or cobalt unibit, set drill for slow speed, high feed pressure, and a sulpherized cutting fluid.
    iiawah808 likes this.
  8. Dec 9, 2022 at 9:45 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    This thread just spiked my anxiety!
