Driver’s Door is stuck shut!
Discussion in '2.5 Gen Builds (2014-2021)' started by mrmisky1969, Dec 4, 2022.
  1. Dec 4, 2022 at 12:54 PM
    mrmisky1969
    mrmisky1969 [OP] New Member
    James
    Torrance, California
    2016 Toyota Tundra TRD
    5100 Bil’s on Middle Setting 275/70r18 Falken WildPeak ATs Rear Firestone Airbags ECCP Towing Mirrors LED Int/Ext lighting White Out Front Door Handles Blackout Emblems Custom Painted Front Grille
    I replaced my door actuator, and possibly the cable became detached at the actuator trying to maneuver it into position. But, it could be a bad actuator on the opening side. Obviously can’t get the door open both sides and not able to get the door panel off. Any advise on how to get to the latch or get the door open. My remote works , but the latch is still not releasing.
  2. Dec 4, 2022 at 1:00 PM
    2mchfun
    Welcome here! Check out the forum search box. Seen this here somewhere but can't remember the exact solution. Good luck!
  3. Dec 4, 2022 at 1:56 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
  4. Dec 4, 2022 at 2:03 PM
    bfunke
    bfunke Tundra Curmudgeon
    Always trip the latch with your finger before you close the door and then test that the latch unlocks. Did you carefully insert the silver rod into the lever on the door latch mechanism? I don’t believe the door card can be removed with the door shut. You may be able to reach the lever with a slim Jim.
  5. Dec 4, 2022 at 2:12 PM
    bfunke
    Also recommend using OEM actuator mechanism only. Some of the aftermarket parts are poorly made
