  1. Dec 4, 2022 at 6:10 AM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    LevelUp[QUOTED] likes this.
  2. Dec 4, 2022 at 7:57 AM
    JT828
    JT828 New Member
    2019 Platinum
    Got the Eibach Stage 2R coilovers with rear reservoir shocks, TRD sway bar, and Coachbuilder 1” shackles installed.
    The truck is level and handles amazingly now. No more bad body roll, nose-dive on braking, or bed bounce. It feels a lot more planted and secure on turns and lane changes.
    The ride is a little stiffer than the stock platinum suspension but handles bumps without bouncing afterwards. I am still on stock size tires at the same PSI for comparison.
    I had 5100’s on middle setting in my last truck. These are a better ride by far. Can’t wait to get my 275/65/20s installed.
  3. Dec 4, 2022 at 8:36 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    When do you think you'll install your new tires/wheels?
    I'm anxious to know what rubbing you have with that size tire? I'm considering the same size but I have a 3/2" lift but think there will be some rubbing with a +25 offset.
  4. Dec 4, 2022 at 10:03 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    [UPDATE] I found the intake I needed through a local forum member. Thanks @ssmokedz !
    [Original] Anyone with a supercharger still have their original 5.7 intake manifold laying around?
    I need one for the replacement engine I'm putting in my truck. The salvage yard broke the one on the replacement engine I bought and the inside of my original is coated in oil and the "glitter of death".
    Check out the carnage through the intake runner. I see a valve without the valve stem turned sideways, a mangled compression ring and a chunk of the piston on the right side and a broken valve guide on the left.
  5. Dec 4, 2022 at 10:43 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    OUCH !!!
    cartage1 likes this.
  6. Dec 4, 2022 at 11:26 AM
    Bergy24
    Bergy24 New Member
    What the heck did you do to create that much damage? How many miles?
  7. Dec 4, 2022 at 11:34 AM
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    Minor fix: added some grit to my iBoards. They are slippery and I don't need Mrs. Catus or the pup busting their ass on them! It's just some black sand I found on clearance at PetSmart and spray-on Herculiner. We'll see how well it holds up.
  8. Dec 4, 2022 at 12:16 PM
    careyrob
    Carey
    Massachusetts
    @Bergy24 A valve spring broke, the valve dropped into the cylinder and turned sideways. That broke the piston and then the rod knocked 4 holes in the block.
    205k miles. No warning. No noise. No bang. It just died while I was driving about 35 mph. Then it wouldn't start like the battery was dead. I had it towed home and found the alternator was dead.
    I changed the alternator and the noise started when I cranked it up. I got out of the truck to figure out where the noise was coming from. Then everything quickly came apart right there in the driveway.
  9. Dec 4, 2022 at 1:00 PM
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Had some decent early December weather today, so took some time to clean it up in preparation for the upcoming winter. A nice wash, wax, and a topping of PS bead maker.
    Last week, had some aftermarket seat heaters installed. Should be about ready for winter as I'm going to get.
  10. Dec 4, 2022 at 1:04 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    This is not mine, but is on Craigslist in TX. Not sure if they would ship.
    https://sanantonio.craigslist.org/pts/7562559363.html
    Note sure if a 2012 can fit on a 2017.
    cartage1 and RainMan_PNW like this.
  11. Dec 4, 2022 at 1:10 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Got it mounted today sans lighting and a winch but the lights will be here in the week. Light bar on the way too.
    20221204_150225.jpg 20221204_150238.jpg 20221204_150242.jpg 20221204_150620.jpg 20221204_150627.jpg
    Thanks again to @STravis for being very available to help with cutting my panels etc for the perfect fit.
    AggiePhil, Major, SMTundra and 20 others like this.
  12. Dec 4, 2022 at 1:13 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    You do what most of us here can't do. Responsible buy and still have a kick ass truck
  13. Dec 4, 2022 at 1:59 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Bumper is on and glass cut. Hopefully shouldn’t have any more rubbing during articulation
    AggiePhil, Major, GAknight and 27 others like this.
  14. Dec 4, 2022 at 2:43 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Pulled a Amazon delivery truck out of my steep driveway. I better be getting one day deliveries haha.​
  15. Dec 4, 2022 at 3:19 PM
    careyrob
    Carey
    Massachusetts
    Thanks @3rdTundra. My replacement engine was shipped from San Marcos. It was fine before they pulled it out of the truck.
    $300 isn't bad for all of that, but I only need the intake plenum. I already have duplicates of everything else they're selling except the air cleaner and engine cover.
    I'll try and contact them about it.
  16. Dec 4, 2022 at 3:39 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    why are there differant colors? Did you do that?
    AggiePhil likes this.
  17. Dec 4, 2022 at 3:47 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    What are these for? Allow you to add more connections for lights and stuff? Not sure how they work?
  18. Dec 4, 2022 at 4:30 PM
    rocsteady
    Dave
    New Jersey
    Bit of a mistake resulted in a set of amber grille lights showing up at the house. Decided to install them in homage to my "couple vehicles ago" 2012 Raptor. I liked em on the Raptor and I like em on the Tundra too. Used the fuse spot that will have them on whenever the ignition is on. (had to move my front camera from where I had it and I'll be waiting on camera mount to put it below the "T" in the grille).
    **Only drawback is that it'll be a p.i.a. to remove the grille now as the "Raptor Lights" do not have a quick disconnect in the wiring like the front camera does.
    AL9nZEWSjDHUIfuhLym5EJ3F6S5K6JfMfn8dGMQp_1a52106f8d701735bc970fedb0154c1c064cf46e.jpg
    I really like the amber color of the Diode Dynamics fogs in "backlit" mode.
    AL9nZEVDr-9PTA8j-5pKOTZzc2iskuNcw7VdFZu__d3c103cc0a862fd2e26bb3d25b041a7d8ff9c533.jpg
  19. Dec 4, 2022 at 4:41 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Nice, that's a good look!....and idea!
    catus[QUOTED] and WFD473 like this.
  20. Dec 4, 2022 at 5:25 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Pretty much - they have a bunch of threaded holes with screws of various sizes on the sides/back specifically for adding accessories. Plus, they're really beefy, which is nice!
    Gonna be using them/switch pros/electrical tray to install this bad boy soon.
    A bit overkill, but I want to be sure I do it right - or as close as I can get :rofl:
    bulldog93 and mgm16trdpro like this.
  21. Dec 4, 2022 at 6:07 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If you have enough power running to that thing, there won't be any windows to tint!!!!!
    Major likes this.
  22. Dec 4, 2022 at 6:10 PM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    HUGE FAN!!! Send me a PM on info for that bumper
  23. Dec 4, 2022 at 7:08 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Yeah think I crossed over to the point of high output alternator and AGM battery
  24. Dec 4, 2022 at 7:15 PM
    Tripleconpanna
    Too bad you can't post a realistic audio clip exemplifying the performance...
    Maybe you can just post a day/time when you're going to fire that thing up, and we'll all just step outside and see who can hear or feel it :muscleflexing:
  25. Dec 4, 2022 at 7:24 PM
    JT828
    JT828 New Member
    2019 Platinum
    I should have the new tires on in the next week or so. 275/65/20 on stock +60 offset Platinum wheels with 2” level doesn’t rub once you take off the little front air deflectors.
    With +25 offset you might have to do some more massaging on the liner but I don’t think you’ll have much rubbing.
  26. Dec 4, 2022 at 7:38 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    mazulla offroad.
  27. Dec 4, 2022 at 10:21 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Chrome delete completed!
  28. Dec 4, 2022 at 11:11 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
  29. Dec 5, 2022 at 12:30 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    That truck looks ready to tackle a brick wall and laugh about it. JEEZ.
  30. Dec 5, 2022 at 3:43 AM
    bflooks
    bflooks New Member
    Metrowest MA
    That truck and your comment made me think of this truck and these comments:
    https://youtu.be/_Fp69Av6_5Q
