Rear sway bar install question
Discussion in 'Suspension' started by Convertedman, Dec 4, 2022.
  1. Dec 4, 2022 at 12:42 PM
    Convertedman
    Convertedman [OP] New Member
    Scotty
    Cumming, Ga
    2021 CM 4 wheeler Limited Cavalry Blue
    6in Ready lift, Toyo 35/12.50/20
    All, I installed the RSB today. I’ve read a lot on guys having to install to the back of the axle due to having a 6” lift. I have a 6” lift and installed to the bottom of the axle and everything looks to be sitting properly. Is there something I’m missing? Do I need to swing it to the back? If so, why?
    Thanks. I haven’t tightened anything down yet trying to make sure I have it right first.
  2. Dec 4, 2022 at 1:15 PM
    blenton
    blenton New Member
    The end links should be vertical and the sway bar should be horizontal. With your sway bar installed as such it appears that the end links are angled forward and the sway bar is pitched up. This setup would yield a less effective anit-sway moment, as well as the possiblity of the links inverting as the suspension cycles.
    It will take a little effort and time - but not much - to rotate those mounts to the back of the axle as has be suggested, but you will see the difference.
  3. Dec 4, 2022 at 2:10 PM
    Convertedman
    Scotty
    Cumming, Ga
    Does make sense. Lee there was something I wasn’t thinking of.
    Thanks for the reply.
  4. Dec 4, 2022 at 2:23 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    How close is the sway bar linkage to your tailpipe?
  5. Dec 4, 2022 at 3:14 PM
    Convertedman
    Scotty
    Cumming, Ga
    Its a couple inches away. I moved the brackets facing back like Blenton mentioned doing. looks better. the end links are now angled reverse, which would give more play as the suspension moves.
  6. Dec 4, 2022 at 3:31 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I mounted mine on the backside of the axle housing but I'm over 6" so I bought extended links from BDS. They bolt up to the TRD bar just fine. Now I've got the RSB brackets facing downward.
    Chad D. and Leo's first like this.
