General Supercharger Thread
  1. Dec 3, 2022 at 9:33 AM
    #4471
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Sounds like a good question for the turbo kit company in the other thread. A straight up question of, is it still safe to tow 10k lbs with this turbo setup? Towing is one scenario I’d take the SC any day over the big single turbo. The off the line grunt with the supercharger is perfect for getting a heavy trailer moving. Like I mentioned once before from a standstill it will straight up spin (by accident) the 12.50 tires on dry ground with 1,000 lb tongue weight, a bed cap, and a loaded bed. The towing improvement is probably my favorite part of having the SC.
  2. Dec 3, 2022 at 10:13 AM
    #4472
    Saltyhero13
    Saltyhero13 Throbbing Member
    Agree. I think SC is where it's at for towing. The other turbo technologies (Twin Scroll and Variable Geometry) don't seem to be there for a nonOEM application.
    I would also want to know if the banks heat up evenly or not long term. The piping from the manifold looks like one bank will have a shorter path to the outlet that feeds the turbo, may not be pronounced enough to make a difference like in the video. Looking at other collector designs I am curious to see the inside of the "Y" too, looks shallow where the streams could interfere with each other. Not a fluid guy so what the frack do I know.
  3. Dec 3, 2022 at 10:32 AM
    #4473
    Saltyhero13
    RE: The second half of the question I think it is tough to beat a blower on the little end of low RPMs.
    What I am finding is turbos are usually good for a specific RPM band outside of which they get very inefficient (they heat up the air too much). The Twin Scrolls and Variable Geometry turbos are supposed to be better across a wider range than a traditional turbo; too many problems or too complicated dialing them in from what I am reading.
    The other option is compounding where a big turbo feeds a small turbo; looks like the key is to keep the small turbo in its most efficient island. This gives a broader response; small handles the lower RPM end, big provides enough air to feed the small turbo on the big RPM end where a single small would choke. Problem is air gets really hot compounding (like 400 degrees) so you need intercooling to deal with the heat otherwise you loose the benefits of all the boost you make. Given limited space placing a properly sized intercooler is usually the big challenge after you've figured out all your turbo piping.
    nobodyintexas[QUOTED] likes this.
  4. Dec 3, 2022 at 11:35 AM
    #4474
    Saltyhero13
    no ignition puns intended.
  5. Dec 4, 2022 at 7:01 AM
    #4475
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Saltyhero13 likes this.
  6. Dec 4, 2022 at 7:50 AM
    #4476
    Saltyhero13
    Found something interesting about another supercharger that reads IAT temps post intercooling. Looks like there is an issue with the temp sensor getting heat soaked because of its position. It wasn't a Harrop but the aftermarket responded with a spacer (riser) kit.
  7. Dec 4, 2022 at 7:55 AM
    #4477
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
  8. Dec 4, 2022 at 8:03 AM
    #4478
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I suspect it's EPA related.
    but that bad boy would bolt right to a godzilla F250
  9. Dec 4, 2022 at 8:22 AM
    #4479
    Silver17
    Eastern PA
  10. Dec 4, 2022 at 9:25 AM
    #4480
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    [UPDATE] I found the intake I needed through a local forum member. Thanks @ssmokedz !
    [Original]
    Any of you still have your OE intake manifold laying around?
    My engine died at 205k miles so I'm swapping it with a low-mileage used engine from an auto recycler ($6k). The workers broke the intake manifold pulling the engine out of the truck.
    My original inatke is full of oil and metal from the demolished valve and piston.
    I'm not confident that I can get all of the metal particles out of the original intake and I can't inspect it thoroughly enough even with a digital bore scope.
    If you still have your original 5.7 intake would you be willing to part with it? I'm in Central Massachusetts btw.
  11. Dec 4, 2022 at 10:23 AM
    #4481
    Saltyhero13
    Holy shit! What numbers were you pushing?
  12. Dec 4, 2022 at 10:27 AM
    #4482
    careyrob
    Carey
    Massachusetts
    Naturally aspirated. Stock engine.
    One of the valve springs broke, dropped the valve into the cylinder, broke the piston and then the rod knocked 4 holes in the block.
    I need an intake manifold which isn't used after installing a supercharger so this seems to be the best audience for locating one.
  13. Dec 4, 2022 at 12:28 PM
    #4483
    snivilous
    SW UT
    300k+ Supercharged 2008
    Ahhhh a week late! I literally threw out all my stock intake stuff on Wednesday after having it sit in a box for years.
    M3Tundra-JK likes this.
  14. Dec 4, 2022 at 3:59 PM
    #4484
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I'll be installing one soon, but probably still a month away
  15. Dec 4, 2022 at 11:57 PM
    #4485
    So1988
    So1988 New Member
    12psi is considered average here. I have been to 21psi.
    I have not removed the coolers but I anticipate rear side at corners.
    Putting TRD SC today with bigger crank pulley. Aiming for 12-14 psi.
    reywcms likes this.
  16. Dec 4, 2022 at 11:59 PM
    #4486
    So1988
    So1988 New Member
    rcsb
  17. Dec 4, 2022 at 11:59 PM
    #4487
    So1988
    So1988 New Member
    I have 18"
    275/60/18
    M3Tundra-JK[QUOTED] likes this.
  18. Dec 5, 2022 at 12:05 AM
    #4488
    So1988
    So1988 New Member
    I am on 60mm Griptech pulley
  19. Dec 5, 2022 at 12:58 PM
    #4489
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Lol same. Literally just tossed mine out
  20. Dec 5, 2022 at 1:04 PM
    #4490
    careyrob
    Carey
    Massachusetts
  21. Dec 5, 2022 at 1:11 PM
    #4491
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Let me reach out to a few people but they maybe not getting blowers installed for a bit also
  22. Dec 5, 2022 at 1:21 PM
    #4492
    careyrob
    Carey
    Massachusetts
    I'm trying not to appear rude or ungrateful, but the used engine only has a 30 day warranty so I have to find something and get it installed ASAP in case the replacement engine is bad.
    If I don't get it running before 30 days and it turns out that it's bad I'll have no option, but to buy a second used engine for $6,700.
  23. Dec 5, 2022 at 1:25 PM
    #4493
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I'd get a short block from prospeed for that price
    nags, So1988, rockmup and 2 others like this.
  24. Dec 5, 2022 at 1:44 PM
    #4494
    careyrob
    Carey
    Massachusetts
    @reywcms that would be great, except I don't have a useable core and one of my cylinder heads is damaged as well.
  25. Dec 5, 2022 at 2:37 PM
    #4495
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I still have my intake off my 2014 5.7 motor. Yours for the shipping cost. I will have to find a box big enough for it. I will dig it out tonight if you want it.
    Warreng, ZPhilip, Wynnded and 5 others like this.
  26. Dec 6, 2022 at 6:02 AM
    #4496
    careyrob
    Carey
    Massachusetts
  27. Dec 7, 2022 at 7:30 AM
    #4497
    ssmokedz
    Shelton CT
    Nice meeting you. I hope it works out for you!
    Wynnded and Saltyhero13 like this.
  28. Dec 7, 2022 at 12:26 PM
    #4498
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Uhhh, I spoke too soon. At WOT on the Dyno, cylinder one injector isn't working correctly and throwing a misfire. I'll have to pull it out and see what's going one. On the plus side, it made 450whp on 7 cylinders, lol.
  29. Dec 7, 2022 at 1:31 PM
    #4499
    M3Tundra-JK
    Scott
    2005 GX470
    I have the Five-O injectors coming in a few days. Will put up some comparison pic. They ended up being the exact same price as pro speed's, because five-o has a 10% off banner for joining their mailing list.
    snivilous[OP] likes this.
  30. Dec 7, 2022 at 2:02 PM
    #4500
    Saltyhero13
    Silver17 and nobodyintexas like this.
