33's, 34's, or 35's?
Discussion in 'Wheels & Tires' started by UTAHRTK, Dec 3, 2022.
  1. Dec 3, 2022 at 7:17 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Hope all is well. I am pondering which size of A/T tire for next set and would appreciate your input/recommendations. I live in San Diego and spend most time on the road and little time on trails. I have researched tires and set ups on this site and am leaning towards 34's; maybe TOYO AT3 305/70/17. Other tires in that size are Nittos and Coopers.
    Currently running 17" Method wheel with 0 offset and Mickey Thompson ATZ 295/70/17. Suspension is Bilstein 6112 at about 1.75" with stock UCA and 5160's rear with no lift. I don't have any issues doing a BMC if needed but I prefer not to increase height in front and I am not prepared to replace the front suspension. Thanks.
    Also, yes 37's are bad ass, but they are not an option for me- at this time.
  2. Dec 3, 2022 at 7:30 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I’m right with you almost to a T. I have 295/70 Toyo ATlll but on 18” methods. For me the next leap may just be 37s
    :muscleflexing:
  3. Dec 3, 2022 at 7:57 AM
    TheBeast
    TheBeast The Beach
    35's.
    Also not all 35's are equal. BFG tend to size smaller than Toyo for example.
    I know a good guy in Vista for BMC if you need. he can adjust your suspension too.
  4. Dec 3, 2022 at 9:41 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Here is mine on a 2.5/1.5 with 295/70r17s top, and 33x12.50r17s bottom. Both 0 offset 17x8.5. IMO the side profile view looks better with the taller 295/70 and the front/rear/angled view looks better with the wider and shorter 33x12.50s. I currently have the 33s. No 35s on this truck yet though, I don’t like the idea of sacrificing power. upload_2022-12-3_12-40-21.jpg
  5. Dec 3, 2022 at 9:48 AM
    Shanet421
    San Diego,CA
    Jason does great work!
    TheBeast[QUOTED] likes this.
  6. Dec 3, 2022 at 10:33 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    If you move to 35s+, and use your truck as a truck, then you will want to regear which will significantly increase your costs.
    33/34s with stock gears are OK, still have the power and MPG hit but nothing like the power and MPG hit from 35x1250 and larger meats, which get very heavy quickly. Not to mention the added stress on the truck from tires that big over time and the usual additional steps that can be needed to fit 35s without rubbing.
    Ive run 35s on a daily driver, half ton, not sure I will do it again. They look great, but there are tradeoffs especially if you do not regear.
  7. Dec 3, 2022 at 10:50 AM
    Junior 88
    Junior 88 New Member
    Junior
    18 tundra Sr5
    7inch bds on 35s
    You have more fun on 35's.
    I have a bds 7inch lift on 35x12.50x18 big ko2.
  8. Dec 3, 2022 at 11:09 AM
    Silver17
    Eastern PA
    Looks nice. Does that BDS lift negatively impact the turning circle like the RC lifts?
  9. Dec 3, 2022 at 11:10 AM
    UTAHRTK
    SOCAL
    Thanks for the great comments and pics. Such a hard decision… I will update - eventually. Have a good one!
  10. Dec 4, 2022 at 7:16 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Don’t mean to high Jack the thread. I’m looking at these method wheels 314’s in 18’s. How do you like the wheel finish on your wheels? What off set are the 17’s? I know the 18’s are 18.
  11. Dec 4, 2022 at 7:29 AM
    Silver17
    Eastern PA
    I don’t have the 314s anymore, but I liked the finish a lot. They were durable and held up well, I also kept them clean and coated with protective products. Color is subjective but I like the titanium color as well, black would have been just as nice. I got grey figuring it’s easy to plastidip them black occasionally to change up the look, but you cant duplicate the titanium. The 17s are 0 offset.
  12. Dec 4, 2022 at 7:51 AM
    RusPro21
    Don
    Pa.
    Thanks what did you switch too? Yeah the 18’s don’t come in titanium. Only the matte black.
  13. Dec 4, 2022 at 8:02 AM
    Shanet421
    San Diego,CA
    I’m not a tire expert by any means but why does the exact same tire in load F weigh less than one in load D?
    D91868C7-E18A-4F20-BE37-7B6E9C918A29.jpg BE46017B-8EBA-43C8-876F-21A0B051FFBB.jpg
  14. Dec 4, 2022 at 8:06 AM
    Silver17
    Eastern PA
    Dang they used to offer them in 18s, as I wasn’t sure which to go with at the time. I switched to RRW RR7H wheels in matte gunmetal (lower picture above) also 17x8.5 0 offset.
  15. Dec 4, 2022 at 8:08 AM
    RusPro21
    Don
    Pa.
    Yeah I assume they did not sell the titanium in 18’s a lot so they only offer the matte black in the 18’s. I’m getting in patient waiting for the SCS F5’s for the tundra to release.
  16. Jan 13, 2024 at 10:32 PM
    Natetrdoffroad
    Natetrdoffroad New Member
    Did the 33x12.5 require a bmc or trimming? I plan on having a similar setup but I will only have a 2" level in the front
  17. Jan 14, 2024 at 4:03 AM
    Silver17
    Eastern PA
    They did not require a BMC but I had previously trimmed the mudflaps in certain areas to prevent rub. I believe the previous owner of the truck had done some trimming toward the front of the wheel well but I don’t think that was a concern. I have since gone to a 305/70r17 which is larger than both of those tires and it has not rubbed with those either.
  18. Jan 14, 2024 at 8:22 AM
    Natetrdoffroad
    what is your suspension setup?
