BILSTEINS - CHANGING SETTING FROM 1.3 to 1.9
Discussion in 'Suspension' started by NSURIT, Dec 3, 2022.
  1. Dec 3, 2022 at 3:45 PM
    NSURIT
    NSURIT [OP] New Member
    Todd
    2021 CREW
    Truck is currently on order.
    I have had Bilstein 6112s on my 2021 Tundra CM for just over year and they are set at 1.3. I want to change the setting to a 1.9 and add some small shackle extensions in the rear. Will the Bilstein springs adjust to the new 1.9 setting or have the front springs already settled in at the 1.3 setting?
  2. Dec 3, 2022 at 4:27 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You’re totally fine to do that. If anything, the coils might settle a wee bit more after increasing the preload to the 3rd notch, but you’d probably need something more precise than a tape measure to tell.
