2006 dbc coil spring ?
Discussion in '1st Gen Tundras (2000-2006)' started by growit, Dec 2, 2022.
  1. Dec 2, 2022 at 1:27 PM
    growit
    growit [OP] New Member
    2006 Dbcb SR5
    I have 320,000 miles on my truck, it rides fine but noticed the drivers side is a bit lower than passenger, less than an inch.
    Not sure if it's the coil spring sagging or just a full tank of gas.
    All opinions are appreciated. Thanks
  2. Dec 2, 2022 at 1:29 PM
    Actually, that's something I should be throwing in the new-to-1stGens thread.
    There's a naturally lean in these trucks, with one side up front favoring 1/4" - 1/2" lean to one side. I think some guys on here even dubbed it the 'first gen lean' or 'tundra lean'. There's a good thread for you, let me dig it up.
    Meanwhile, when was the last time you replaced the struts, and what make/model strut did you go with? 320k is a lot of mileage on suspension.
    Tundra2 and Riverdale21 like this.
  3. Dec 2, 2022 at 1:34 PM
    Damn. Can't find the thread, but you'll see some of the people posting stock numbers in this thread (including me, IIRC) you'll see lean in front, back, or front and back. But virtually always up front by at least a quarter inch. It really seemed to get the goat of a lot of the 2.5 gen guys, still existed on their trucks.
  4. Dec 2, 2022 at 1:45 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Slacker....just busting your balls. Can't remember everything
  5. Dec 2, 2022 at 2:10 PM
    What were we talking about again? :confused:
  6. Dec 2, 2022 at 2:23 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Lol :D
    Hi06silver and shifty` like this.
  7. Dec 2, 2022 at 5:01 PM
    growit
    2006 Dbcb SR5
    Shifty,
    Struts were done around 175k , and upper and lower control arms, ball joints-oem, and driveline at around 250k. Just did plugs and coils and steering rack, runs great.
    shifty` likes this.
  8. Dec 2, 2022 at 6:05 PM
    Cummins3500
    Logan
    Coach builder makes some spacers to fix that and level it out side to side. I’ve got them set in my parts pile just haven’t installed them yet.
  9. Dec 2, 2022 at 10:34 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    TacomaWorld calls it the Tacoma Lean.
    I’m in the same boat after my 5100’s and 885’s. I’m going to try a 1/2” Leaf Shim on the drivers side. If that doesn’t correct it I’ll add a 1/8” spring spacer to the front driver coil over.
  10. Dec 3, 2022 at 6:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    1st gen off road also sells spacers to correct the lean. I have one on the V6
  11. Dec 3, 2022 at 8:12 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Weird I‘be not noticed this on mine but I don’t wanna look now lol
