SHOW OFF YOUR RETRO HEADLIGHTS
Discussion in 'Lighting' started by Eclipsed & Floating, Jun 25, 2017.
  1. Jul 17, 2017 at 7:17 PM
    pats_fan
    pats_fan New Member
    2020 Midnight Black Metallic Tundra TRD Pro CM
  2. Jul 17, 2017 at 7:48 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I just dropped mine off. Got some Platinum headlights on the cheaps off a brand new truck. Doing the housings satin black, Morimoto D2s 4.0 projectors, Panamera shrouds with RGB halo beneath, sequential switchbacks replacing the bottom LED strip, and using my VLEDs in the OEM turn signal bowl. Sequential strips will start inside with the VLEDs and travel outward.
    Should have some pics of the progress pretty soon. Very excited.
    I didn't get a bed rack because of this so they better be amazing.
    Oh yeah, having the shrouds and the side amber marker color matched MGM. Might be too much, we'll see.
  3. Jul 17, 2017 at 7:58 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  4. Jul 23, 2017 at 3:44 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    How'd you wire up the leds on the shroud. And where did you get them from? I want to run the same setup.
  5. Jul 24, 2017 at 9:47 AM
    scurdyness
    scurdyness One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    Eledobleu
    BlueBottle[QUOTED] likes this.
  6. Jul 24, 2017 at 10:31 AM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    How many of you did the retro fit yourselves?
  7. Jul 24, 2017 at 5:26 PM
    BDell52
    BDell52 New Member
    2022 TRD Pro
    Here's mine...
    Djone27 likes this.
  8. Jul 24, 2017 at 5:44 PM
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Ooooohhh!!! I like those. Do your led strips on the bottom match the halo?
    BDell52[QUOTED] likes this.
  9. Jul 24, 2017 at 5:47 PM
    BDell52
    BDell52 New Member
    2022 TRD Pro
    They do, at least if there is a difference I can't see one.
  10. Jul 24, 2017 at 5:50 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Is the rest painted black?
    How is the output?
    I wonder if you paint the shroud white would it look good on my truck?
    I want something very different, though classy, and super bright. You accomplished at least two of those three. How about the output?
  11. Jul 24, 2017 at 5:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    For those of you that paint the front signal reflector black, doesn't that make the signal dim?
  12. Jul 24, 2017 at 5:55 PM
    BDell52
    BDell52 New Member
    2022 TRD Pro
    Yes everything is painted black on the interior. The output is very good on them, a lot better than the stock headlights. Maybe painting the shroud white and the interior area where the daytime running light/turn indicator light is on the stock headlights might work/look really good? I had Eledoubleu do these for me. I went with all black because whenever this TRD Pro grill shortage is over my entire front end will end up being blacked out.
  13. Jul 24, 2017 at 5:56 PM
    BDell52
    BDell52 New Member
    2022 TRD Pro
    Doesn't seem to at night, plus my halo's and led bar are switchbacks, so I wasn't to worried about the signal reflector being dimmed out a bit.
  14. Jul 24, 2017 at 5:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks. Are you using led bulb in the factory location?
  15. Jul 24, 2017 at 6:00 PM
    BDell52
    BDell52 New Member
    2022 TRD Pro
    Actually just using the factory bulb at the moment. I plan on switching it out when I a do a complete light overhaul switching out everything left to led bulbs.
