Granite - A Third Gen Story
Discussion in '3rd Gen Builds (2022+)' started by Outbound, Jul 31, 2022.
  1. Oct 24, 2022 at 4:44 PM
    #61
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    Not on mine. I'm in Texas just up the road from the plant is San Antonio
    Tundra4us and X42069[QUOTED] like this.
  2. Oct 24, 2022 at 4:44 PM
    #62
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    So strange to me that it doesn't. There are a lot of cosmetic differences between Canadian and American models. For the sake of mass production you would think they would be the same
    Unitdosed[QUOTED] likes this.
  3. Oct 24, 2022 at 4:46 PM
    #63
    Unitdosed
    None, yet
    It would be interesting to hear what Toyota has to say about that. I'm tempted to go back to my dealership and ask them to swap out the steering wheel and shifter. I do have the same pedals.
  4. Oct 24, 2022 at 4:48 PM
    #64
    X42069
    X42069 New Member
    M
    I highly doubt they would entertain that idea.... Unless you are willing to pay of course
  5. Oct 24, 2022 at 4:54 PM
    #65
    Unitdosed
    None, yet
    Im actually fairly certain I recall reading that this package comes with those two items. Can anyone here dig that up?
  6. Oct 31, 2022 at 8:02 AM
    #66
    JUNNEL20
    JUNNEL20 New Member
    Junnel
    I have these same ones, but it appears that yours are installed backwards. I believe the widest section of the running board goes to the front, then tapers towards the rear.
    TK1979 and Outbound[QUOTED][OP] like this.
  7. Oct 31, 2022 at 10:05 AM
    #67
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Could be. I'm not sure what the official installation set up is but I requested them to be installed with the wide section to the back. Being short, I like to stand on them when I need to reach to the middle of the back seat and I can stand on the end of the running board and easily reach into the Cross Bin under my Diamondback cover. It just gives me a bit more real estate to stand on in the areas where the board is more of a step vs the front where I just use it as an assist when climbing in.
    Henry1jg likes this.
  8. Oct 31, 2022 at 10:09 AM
    #68
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I suspect they're on correctly as I'd be surprised if your Toyota dealership would agree to install them backwards...
    Outbound[QUOTED][OP] likes this.
  9. Oct 31, 2022 at 10:13 AM
    #69
    Outbound
    Aaron
    Northern Alberta
  10. Nov 1, 2022 at 8:21 AM
    #70
    JUNNEL20
    JUNNEL20 New Member
    Junnel
  11. Nov 1, 2022 at 8:49 AM
    #71
    Outbound
    Aaron
    Northern Alberta
    Worth a try since it probably wouldn't take very long to do.
    JUNNEL20[QUOTED] likes this.
  12. Nov 2, 2022 at 6:27 PM
    #72
    AverageAZN
    AverageAZN New Member
    Austin
    2004 Toyota Sequoia
    OME/Dobinson long travel lift, 34s
    hmmm i was looking at the same ones. I guess they are technically backward according to Rhino. I think id prefer them "backward" for two reasons, 1. the bed step possibility as mentioned, but 2- as a better taper going forward for hitting rocks etc. It wouldnt catch as bad on the slim side and then would slowly bump the truck away from the rock... So backwards is the way to go for sure imo.
    Outbound[OP] likes this.
  13. Nov 2, 2022 at 7:02 PM
    #73
    AverageAZN
    Austin
    2004 Toyota Sequoia
    You convinced me to pull the trigger on those running boards. I wonder if you can highlift jack right on them...
  14. Nov 2, 2022 at 7:37 PM
    #74
    Outbound
    Aaron
    Northern Alberta
    I wouldn't use a highlift on them. I can almost guarantee they'll bend or buckle.
  15. Nov 10, 2022 at 1:09 PM
    #75
    Outbound
    Aaron
    Northern Alberta
    First Week of Winter Report
    Ok, we've had our first week of winter with frigid temperatures and plenty of snowfall. I put about 200kms on the truck this week test it out. I didn't get to test everything I wanted but that will all happen this winter.
    First off, the Michelin LTX Trail tires suck donkey ding-ding in the snow. I'll be having them replaced in the next month or so. I'm having issues sourcing the Nokian Hakkapellitas and steelies I want so I'll probably go with the Cooper AT3 XLT I was going to buy in spring and worry about the Nokians toward the end of next year.
    Overall, the truck has done pretty well. I do park in the garage for now, so I'll be parking outside for the next storm to give the remote start and defrost a workout. I didn't have any issues with the sensors, but I also didn't get a chance to drive much on snowy highways. In town driving though, there were no problems.
    The 4x4 system works well. I do notice some lugging and jerking when making slow, sharp turns like in a parking lot. I'm chalking that up to the shitty Michelin tires constantly slipping. I'll test that out more when I get better tires. The MTS deep snow system isn't worth using for daily driving. I'd only use that if I were out in a field, rural backroad or on a trail with some actual deep snow. It turns off a bunch of sensors and constantly flashes that reminder on the screen which gets annoying.
    I found running the truck in Eco mode to be highly beneficial. The slower application of power resulted in less spinning and more control on the compact snow and ice.
    I didn't notice any excessive blowing of snow into my view from the hood channels like other people have mentioned. Everything seemed to blow off and out to the side.
    The keyless entry likes to act up a bit when it's really cold, especially if your hands aren't warm. I ended up unlocking the truck with the fob a couple times.
    My wipers never froze up on me, even after sitting for a hour in a parking lot in the blizzard with melted snow on them. Maybe luck, maybe due to the fact I hit the defrost button as soon as I got in the truck. Speaking of which, the heated mirrors and back window defrost work great. It hasn't been cold enough to need the heated seats or heated steering wheel, but we're likely mere weeks away from those temps.
    More to come as the winter progresses.
    PS: Still haven't needed tow hooks.
  16. Nov 10, 2022 at 4:04 PM
    #76
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's not typical 4x4 behaviour? Probably not enough slip for sharp, low speed turns.
  17. Nov 10, 2022 at 4:07 PM
    #77
    Outbound
    Aaron
    Northern Alberta
    Kinda what I figured but it does fine on gravel. :notsure:
  18. Nov 18, 2022 at 8:42 PM
    #78
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    Just got my RB20s in today, and purposely installed them flipped partly thanks to this thread lol. Actually love the look, and would probably find the fat side near the bed more useful.
    Question- did your rear most bracket fully clamp down on the running board in the area I circled?20221118_203623.jpg
  19. Nov 19, 2022 at 4:52 AM
    #79
    Outbound
    Aaron
    Northern Alberta
    I havent actually gotten underneath mine yet. I'll have a look in about a week when work settles down and I have time.
  20. Nov 19, 2022 at 2:05 PM
    #80
    ToyoMon
    ToyoMon New Member
    Installed last night... checked this morning and actually just had to adjust the boards in a little. All is well thanks! You probably don't have this issue or you would have felt the rear portion of the step drop a bit when stepping on it.
  21. Dec 1, 2022 at 11:09 AM
    #81
    Outbound
    Aaron
    Northern Alberta
    Falken Wildpeaks
    I had new rubber installed today. After going back and forth between these and the Cooper AT3 XLT, I bit the bullet and ponied up for the Falkens. The reviews and recommendations from people on this forum and others overwhelmingly favored the Falkens.
    I went with 275/70R18 for size. Slightly larger than stock but not enough that I need to modify my suspension. I don't plan to lift my truck for a long while if at all, so staying close to stock was ideal. Nevermind they won't crater my fuel economy. There's also no rubbing at full lock.
    First impressions are brief as I literally just got them, but so far so good. Driving across town in -20F with compact snow and icy sections was fine. These tires are a night and day difference from the stock Michelin LTX Trail that just plain sucked. On the few clear stretches, I didn't notice any extra road noise.
    I'm looking forward to putting these tires to work, especially next spring when the backroads get soupy and sticky with gumbo mud.
    Oh, these tires really make my truck look way better so that's helpful too. :D
    I paid just under $2000 Canuckistani pesos, including install and Integra Tire's repair warranty. My wallet hurts but it can relax now because this is the last of the high dollar truck mods for awhile. I think. Maybe. No promises.
  22. Dec 1, 2022 at 12:49 PM
    #82
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Yes. That's the front axles binding.
    It's good on gravel because of the lack of traction. The lack of traction keeps the CV joints from binding, which is causing the jerking/lugging. In situations where you feel this, widen your turn to keep the joints from binding. Your axles will thank you. :)
    You guys probably know all of this already. It's just the "old man" in me that felt compelled to share this. hahaha
  23. Dec 1, 2022 at 4:28 PM
    #83
    Unitdosed
    None, yet
    How often should I run my truck in 4x4 to keep things in working order?
  24. Dec 1, 2022 at 4:56 PM
    #84
    Outbound
    Aaron
    Northern Alberta
    Not much traction on snow and that's where I was getting the jerking and lugging. Doesn't seem to be a problem since I put the new tires on today. I think the lousy Michelins were the cause of my issues.
    Once a month has worked for me.
  25. Dec 1, 2022 at 8:34 PM
    #85
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Did you use your stock wheels? I was thinking that's a pretty good price since I paid $2300 for Blizzaks a couple years ago but I also had to buy wheels.
  26. Dec 1, 2022 at 8:40 PM
    #86
    Outbound
    Aaron
    Northern Alberta
    Yep, I stayed with the stock wheels. Next year I might buy studded Nokians and steel wheels.
  27. Dec 2, 2022 at 10:53 AM
    #87
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Good info. I put the same on mine - just pure stock size 18's. since i am in the sunny south of ontario now, i havent had any real snow to try them out in. It will be the first time in a long time i chose not to run dedicated snows, so even with a very brief experience, its good to hear that the are not shit in the snow & ice!
    Tks man
  28. Dec 3, 2022 at 9:09 PM
    #88
    AGTAB
    AGTAB New Member
    Curtis
    Canada
    2022 Tundra limited offroad
    i have a set of hakks 275/70r18 on oem TRD offroad wheels i'll be selling by next season if youre looking. in edmonton
  29. Dec 3, 2022 at 10:37 PM
    #89
    Outbound
    Aaron
    Northern Alberta
    I'll keep that in mind next year, thanks!
  30. Apr 2, 2023 at 2:06 PM
    #90
    Outbound
    Aaron
    Northern Alberta
    It's been awhile since I had any updates here. Granite has been in semi-hibernation for the winter, doing simple mom-mobile stuff as The Woman does errands while I'm at work. However, spring is pretty well here and the fishing, shooting, road trip and exploring season is almost here.
    Today I got to play with the Gazelle T4 hub tent that showed up last week. One of the things that I was very interested in learning was how the tent would fit in my short box. Well, now I know. It fits comfortably with plenty of room for other gear.
    TRDFerguson, kirkb, Fotnot and 2 others like this.
