2022+, Is this the perfect hitch lock?
Discussion in '3rd Gen Tundras (2022+)' started by ehcropydoc, Nov 30, 2022.
  1. Nov 30, 2022 at 6:02 PM
    ehcropydoc
    ehcropydoc [OP] New Member
    Hi guys,
    I wanted to write up a quick, no nonsense post about a “perfect” hitch lock setup. Many of these floating around Amazon will NOT work for your Tundra. However, the one I found is simply great and wanted to share in case others were in the same boat as me.
    More importantly, this lock is large enough to allow for the use of the safety pin (see pics below):
    Hitch: https://amzn.to/3Uk8RvB
    Hitch Lock: https://amzn.to/3UnwJ1x
    earlwright239 likes this.
  2. Nov 30, 2022 at 6:08 PM
    Can’t they just steal the rest of the clip pin parts of that hitch?
    =JSG=, TRDFerguson and biebs96 like this.
  3. Nov 30, 2022 at 6:10 PM
    ehcropydoc
    I thought the same exact thing before I purchased!
    They can take the pins but not the actual hitch assembly. They would be quickly disappointed.
  4. Nov 30, 2022 at 6:17 PM
    I see the center swivel pin that’s built in. The clip pins just allow the swivel to be locked into place. Got it.
    ehcropydoc[OP] likes this.
  5. Nov 30, 2022 at 6:45 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Couldn't you put a pipe over the end of the lock and bend till it snapped or back and fourth until it snapped?
  6. Nov 30, 2022 at 7:48 PM
    ehcropydoc
    Definitely. This isn’t impenetrable by any means. The area is tight though so it wouldn’t be simple.
  7. Nov 30, 2022 at 8:41 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  8. Dec 1, 2022 at 2:53 AM
    ehcropydoc
    Eddie, this one looks like it does not have a safety pin. If this is correct then it is very dangerous to use. After I bought my 2023, I went down a rabbit while regarding hitches and locks. I learned about how these locking units can fail and fall off during driving/towing. Meaning if the slider pin works its way out out and chains aren’t properly installed, this results in a disaster.
    Or if one uses a lock with a safety pin, this eliminates this possibility as even if the locking head came off, the PIN would secure the hitch all by itself.
    See below. The pin is installed but it’s hard to see.
    eddiefromcali[QUOTED] likes this.
  9. Dec 1, 2022 at 3:03 AM
    wing-2
    wing-2 New Member
    That's a very nice hitch. I personally don't have my hitch installed on the truck unless I am towing. I am coming from an F-350 to a Tundra. I sold my 16' dump trailer. So now the primary double axle trailer that I will be towing is an enclosed 14' aluminum snowmobile trailer. He likes a 4" drop to be level and have his four feet evenly on the ground. I bought a fixed four inch drop ball mount. The link to that BW shows 3" drop, however they do show a part number for a five inch drop in the questions and answers. The lock system is nice on that BW. I had (Still have, it's for sale) a GEN Y hitch for my F-350. To truly lock it while on a snowmobile trip, I would need three dog bone locks. I am liking the fixed 4" drop for the Tundra. It stows easily under the seat in a bag. The fixed hitch also keeps the ball a little closer to the truck.
  10. Dec 1, 2022 at 4:25 AM
    Pretty sad if someone wants to steal a hitch. But again, they steal spare tires.
    Borador, GODZILLA and ehcropydoc[OP] like this.
  11. Dec 1, 2022 at 5:07 AM
    pursuit2550
    pursuit2550 New Member
    I have had a B&W hitch for yearssss. No issues and has all three balls. I will say that while I have never had a hitch pin lock come undone in 30 years, it’s still a possibility. I use a master lock SS lock pin. I guess I could drill and install a cotter pin.
  12. Dec 1, 2022 at 5:15 AM
    18" TRD Off Road Wheels
    And tailgates, and catalytic converters, and anything else that isn't secured like Fort Knox. Shitty people are everywhere.
    Tundra234[QUOTED] likes this.
  13. Dec 1, 2022 at 11:58 AM
    eddiefromcali
    Eddie
    100% Stock
    The orings keep it in place, they're on there tight and keep the pin from rattling. I could see the safety pin being a good safety feature.
  14. Dec 1, 2022 at 3:21 PM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    Do you have a link to the hitch itself?
