is there a way to display what gear the transmission is in out of the 10?
Discussion in '3rd Gen Tundras (2022+)' started by Fxclm5, Nov 28, 2022.
  1. Nov 28, 2022 at 10:52 PM
    Fxclm5
    Fxclm5 [OP] New Member
    In my ram, I would always manually upshift to the highest gear 8, this opened a numeric field on on the screen showing which gear it would currently be in and kept it activated there.
    This is extremely useful for me, it helped me build a understanding how and where the engine/transmission gears change for load/inclines and cruising mph.
    I see the tundras have a shifter with +/-, so I imagine there has to be some kind of display to show the driver which gear its in, or so 1 would think.
    Anybody have any pics or is there no such a thing? Also never seen sport shift +/- on a truck before, that is interesting as well.
    FI460 and Taikowaza like this.
  2. Nov 29, 2022 at 6:08 AM
    burnurass
    burnurass New Member
    Jeff
    2022 Lunar Rock Tundra Limited with TRD Off-Road
    shift the gear lever to sport
    swede78 and Fxclm5[OP] like this.
  3. Nov 29, 2022 at 6:13 AM
    devron11
    devron11 New Member
    Ron
    Denver
    I have only used that mode when towing so limited experience. But...Not on my SR5 with the 4.5 inch display- the displayed number shows only the top gear that will be available for use. It will not change while driving. Nor have I ever seen a 10 when I downshift manually when going into Sport mode at highway speeds. My experience and the OM sorta says it too, the Sport mode usually sets the maximum gear that will be automatically shifted up to and conversely can also set the lowest gear(s) to be used from a dead stop or while in motion depending on your speed. Of course you can downshift using Sport mode to use the engine for deceleration. Downshifting will show the number change you are manually making. Sport mode is a misnomer IMHO.
    Confused? Now read the OM on the Toyota website....lol.
    FI460 and Fxclm5[OP] like this.
  4. Nov 29, 2022 at 6:36 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Im also curious about the same thing. In ECO mode my truck doesn’t downshift to lowest gears unless I come to complete stop. When I push shift lever over, the lowest gear that shows is 4th gear. I wish Toyota would change the gear mapping so it would drop down to lower gears sooner. Seems odd to accelerate from under 10 mph in 4th gear. Rpms go up but torque converter is doing all the work. I wish there was a way to see what gear I am in while driving. Anyone else know if there is a way to change gear display from D to the gear you are in?
  5. Nov 29, 2022 at 11:13 AM
    Fxclm5
    I just saw a report of some guy that can see the gearing, he kept complaining the dash never read 10 and truck always cruised in 9th gear (as displayed) and he's like only seen it read 10 like twice since owning the truck, or maybe I misread that article for something else
  6. Nov 29, 2022 at 11:26 AM
    mass-hole
    mass-hole New Member
    I mean, its a .61:1 10th gear with a 3.31 axle ratio. The thing isnt even turning 1500 rpm at 70 mph with that much gear. I could see it not needing 10th much unless you are absolutely flying.
    9th gear is .66:1 so still pretty tall.
    By comparison, the 6th gear in my 2014 F150 is .691:1 and I have a 3.73 axle. My driving around in 6th gear is like a Tundra in 8th.
    At the same time though, it makes you wonder why they chose such a tall axle ratio if its not using all the gears.
    FI460 and Fxclm5[QUOTED][OP] like this.
  7. Nov 29, 2022 at 11:51 AM
    Unrelated sort of, but my daughters Jeep Cherokee with the 9 speed auto never goes into 9th gear. It’s programmed to shift to ninth over 85mph only. Must be for the European market or something…..
    Fxclm5[OP] likes this.
  8. Nov 29, 2022 at 12:05 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I’m not sure if it’s different in the non-digital cluster but when I pop mine into sport via the shifter my digital display shows the gear where it would normally show “D”. On the highway it always goes right to 8 and I can toggle up or down. Yes it is hard to get it into 10th unless you’re really moving. I’m surprised the non digital display doesn’t show the same thing.
  9. Nov 29, 2022 at 12:06 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    Here’s it when I click shifter over and toggle through gears
    =JSG= and Fxclm5[OP] like this.
  10. Nov 29, 2022 at 12:37 PM
    Fxclm5
    Interesting looks like us non hybrid peasants got the shaft.
    Thanks for finally posting pics as well
    Spamcan likes this.
  11. Nov 29, 2022 at 1:00 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    Ha, I’m a non hybrid peasant too. The digital dash was ONE of the reasons I went with the Platinum over a Limited
  12. Nov 29, 2022 at 2:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    10th gear is for the guvmunt. Frankly, so is 9th. And prolly 8th.
    On my 2017 6th gear is for the guvmunt.
    PKFan likes this.
  13. Nov 29, 2022 at 3:00 PM
    mass-hole
    10th would be fine if they put a decent gear ratio in the axle like everyone else. Ram has 3.92's, Ford has 3.73's and Chevy has 3.73's and all of them have similar transmission ratios as the Tundra.
  14. Nov 29, 2022 at 3:05 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    I’m just happy that even when I’m doing 90+ I’m still hovering around 2000 rpm’s
    DexterL likes this.
  15. Nov 29, 2022 at 4:57 PM
    Fxclm5
    Oh didn't think you could get dash unless it was hybrid, interesting, will keep a lookout to swap in the dash then from the upper value trims, reprogram your mileage in and hopefully plug and play, it was this way for the 4th gen ram
  16. Nov 29, 2022 at 6:13 PM
    xc_tc
    xc_tc New Member
    A lot of wrong info in this thread.
    The S on the shifter is not “Sport”. Toyota calls it S mode for “sequential”.
    The select top gear is S mode is shown on both the digital display and the standard instrument cluster.
    Whatever gear you select will remain until you change it. However, the transmission still shifts through all the gears normally up to the selected top gear. So if you choose S4, it will shift 1-2-3-4-3-2-1 normally just like if you were in D but won’t go into 5th.
    There’s no way to display the current gear. You have to count or memorize what RPM at what speed is what gear.
    The diff ratio thing is interesting but need to consider 1st gear ratio too
    F150 (I almost always see either the 3.31 or 3.55, never see 3.73 on a sales lot)
    • 1st: 4.696 x 3.55 = 16.67
    • 10th: 0.636 x 3.55 = 2.258
    RAM
    • 1st: 4.71 x 3.92 = 18.46
    • 8th: 0.67 x 3.92 = 2.626
    Tundra
    • 1st: 4.92 x 3.31 = 16.28
    • 10th: 0.61 x 3.31 = 2.019
    Tundra’s total ratio is not that far off from the F150’s but RAM is way ahead. 3.92 is hard to beat.
    NimbusDog, burnurass and NickB_01TRD like this.
  17. Nov 29, 2022 at 6:47 PM
    mass-hole
    so what information was wrong? They competition have shorter overall ratios in their top gears due to both transmission and axle ratios. Fords is >10% shorter. That might not sound like much but its 150-200 rpm
    If you are looking at the 3.5 Ecoboost then 3.73 is more rare. It comes on the Tremor and HDPayload package. max tow trucks are 3.55.
    Powerboost F150’s come standard with 3.73’s.
    2.7 and 5.0 are able to option 3.73’s without any special packages
  18. Nov 29, 2022 at 7:33 PM
    xc_tc
    xc_tc New Member
    No, what you mentioned was interesting but not wrong. Definitely, the total gearing is important though.
    Also I forgot to mention, I could notice my Tundra uses 10th at like 80 mph. The couple of F150s I’ve driven typically go into 10th around 55 mph as reference.
  19. Nov 30, 2022 at 5:43 PM
    Fxclm5
    Any tuners doing transmission reflashes yet?
    My last truck had a engine and tranny tune, doing so improved mpg like 25%.
    Imagine these gen3 going into 10th at 55 instead of 80. Mpg would have some improvements one would think
    shorenetworks likes this.
