Wire crimpers....what do you use?
Discussion in 'Electrical' started by Tundra234, Nov 8, 2022.
  1. Nov 9, 2022 at 7:26 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
  2. Nov 14, 2022 at 1:55 PM
    WV_Warrior
    WV_Warrior New Member
    Cody
    West Virginia
    2021 CM TRD Sport
    I’ll echo the Klein tools. All day every day.
  3. Nov 14, 2022 at 2:29 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I used one of these to crimp 2/0 in a bench vice with no problem. In retrospect I wish I got a hydraulic crimper instead, but it does the job.
    Sunnier and SC4333[QUOTED] like this.
  4. Nov 28, 2022 at 4:56 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I'm a bit of a crimper whore.
    I have probably 2-3 of these of assorted brands, and hate all of them. I am 99% sure that these tools are the reason for my utter disdain for "standard" red/blue/yellow crimp connectors.
    I've got one of these for RJ-11 and RJ-45
    For Coax, I've got one of these
    and one of these
    I've got a kit from Digi-Key for doing the tiny coax cable (like used in radio and wifi antennas), but I don't remember the details on it any more.
    Picked up one of these recently for doing bigger battery sized cables
    IWISS Cable Lug Crimping Tool for Heavy Duty Wire Lugs,Battery Terminal,Copper Lugs AWG 8-1/0 - - Amazon.com
    For the Toyota SEALED connectors, this one has been flawless for me for over 10 years. I also use it for most of the larger size unsealed connectors (1.0 and larger).
    Hozan P-706 Open Barrel Crimper - - Amazon.com
    I recently picked one of these up that I use for the WIRE ONLY part of the Toyota 0.64 unsealed connectors (the rest I still do in the Hozan)
    Amazon.com: Precision Universal Crimping Tool with Inter-Changeable die Plates (Size S) Handy Crimp Tool. Made in Japan. ENGINEER pad-11 : Everything Else
    And also recently picked this kit up and have, for the first time in my life, actually been able to feel confident in the crimp I get on the "standard" and heat shrink connectors
    Wirefy Crimping Tool Set 11 PCS - High Leverage Wire Crimper 9" - Heat Shrink, Nylon, Insulated Flag, Non-Insulated Connectors - - Amazon.com
    danz75 and des2mtn like this.
  5. Nov 28, 2022 at 4:56 PM
    You are a crimp whore!!!
    des2mtn likes this.
  6. Nov 28, 2022 at 4:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I'm sure I've got more if I looked. I'm actually sure of it.
  7. Nov 28, 2022 at 5:00 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I’ll just leave this here for you…..
    https://www.sargenttools.com
  8. Nov 28, 2022 at 5:32 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Lol
    If we’re adding plumbing and wire rope into the mix…
    Mater, FrenchToasty and ATV25 like this.
  9. Nov 28, 2022 at 6:11 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    The o5330130.jpg nly way to get a good crimp....
  10. Nov 28, 2022 at 6:12 PM
    Roborob70
    Robert
    Need to work on my posting skills.....Lol
  11. Nov 29, 2022 at 7:04 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, I was thinking the same.
    Roborob70[QUOTED] likes this.
  12. Nov 29, 2022 at 6:02 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Does no one use their teeth anymore?
    Mater and Tripleconpanna like this.
  13. Nov 29, 2022 at 8:32 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Yes. But I go back to a crimper once the drugs wear off.
  14. Nov 29, 2022 at 10:03 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Here’s the micro coax set I have for satellite and antenna wiring. It’s from L-Com
    Randy Morton and BTBAKER like this.
