  1. Nov 28, 2022 at 5:19 PM
    Taco-Spike
    Two Trucks
    That’s hot
    Neo258 and LevelUp[QUOTED] like this.
  2. Nov 28, 2022 at 5:32 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I try to use the handle but bad habits are hard to break. Hopefully these will retrain me.
    cartage1 and BiggHertz[QUOTED] like this.
  3. Nov 28, 2022 at 5:34 PM
    Rangergillikin
    Alabama
    That looks great.
    LevelUp[QUOTED] likes this.
  4. Nov 28, 2022 at 6:16 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Veery nice job! It all looks factory.
    Tundrastruck91 likes this.
  5. Nov 28, 2022 at 6:17 PM
    LevelUp
    LevelUp New Member
    2016 DCLB SR5 w/ TRD OR in MGM
    OEM LED headlights, interior ambient lighting, running boards, Firestone airbags, misc led swaps, started blacking out phase and chrome delete, Diamondback HD w/ Yakima Overhaul HD (on the way)
    Thank you guys! Haven’t quite seen it in daylight but even if it’s off a bit, I still like it better than the chrome.
  6. Nov 28, 2022 at 6:18 PM
    Velocity72
    Upstate SC
    2021 Platinum
    23 months, and 40K miles
  7. Nov 28, 2022 at 6:29 PM
    Dave,
    Where did you get the door bowls from?
    ssmokedz and RustyShackle323 like this.
  8. Nov 28, 2022 at 6:35 PM
    Taco-Spike
    Two Trucks
    Ktjo
    I posted a few months back
  9. Nov 28, 2022 at 6:35 PM
    :thumbsup:
    Taco-Spike[QUOTED] likes this.
  10. Nov 29, 2022 at 6:19 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Got the rear cat shield installed, which completes the Valhalla set. I went with 3/16 steel. I'd waited on the rear plate until Tyler engineered the door for fluid changes (so I don't have to take the plate off to change diff fluid), so it's a weight off that I'm finally fully covered. They're very solid - I'm comfortable calling them skid plates, not just cat protection.
    ATV25 and NewImprovedRon like this.
  11. Nov 29, 2022 at 6:31 AM
    coTony
    Tony
    Montrose, CO
    Had mine on for over 2 years and sticks very well. Very good at keeping the dust to a minimum
  12. Nov 29, 2022 at 6:33 AM
    coTony
    Tony
    Montrose, CO
    You have to push harder at first then it figures out where it needs to be and flattens out better
  13. Nov 29, 2022 at 6:46 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    And, from the inside, the door handle is pretty handy.
    BiggHertz[QUOTED] likes this.
  14. Nov 29, 2022 at 6:46 AM
    Rangergillikin
    Alabama
    Yup. It’s already getting better.
  15. Nov 29, 2022 at 7:24 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    kos221, SMTundra, DBamaC and 3 others like this.
  16. Nov 29, 2022 at 7:48 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
  17. Nov 29, 2022 at 7:54 AM
    joey2018
    joey2018 New Member
    How difficult was the door bowl install?
  18. Nov 29, 2022 at 7:54 AM
    Taco-Spike
    Two Trucks
  19. Nov 29, 2022 at 7:57 AM
    Taco-Spike
    Two Trucks
    It’s pretty easy. 10-15 minutes for all doors and don’t need to remove the panel. You can guide the wire down to the controls. Have them in the tundra and Tacoma
    The tundra doesn’t have the same functions. The driver side is always on and you can turn off all the others with the window lock since that’s where it gets power. Also cannot dim / bright them with the cluster dial like I can the Tacoma.
    cartage1 likes this.
  20. Nov 29, 2022 at 7:58 AM
    Pretty easy to install but they will be on any time the ignition is on, not just with the headlights or parking lights.
    Taco-Spike likes this.
  21. Nov 29, 2022 at 8:01 AM
    joey2018
    joey2018 New Member
    Thanks for the response. I will go ahead and order them.
  22. Nov 29, 2022 at 8:01 AM
    Now if there were illuminated window switches (other than the cartrimhome) and an illuminated mirror switch......
  23. Nov 29, 2022 at 8:05 AM
    joey2018
    joey2018 New Member
    I have the cartrimhome ones and have had no issues with them so far.
  24. Nov 29, 2022 at 8:11 AM
    Taco-Spike
    Two Trucks
    I’ve seen some threads on Tacomaworld for the second gen Tacoma use some for the mirror switch
    https://www.tacomaworld.com/threads/mirror-control-switch-question.382370/
    Seems there are a few versions though. It’s in the back of my mind but haven’t gone too far down the hole to try it since I never move mine, but will probably get to it one day
  25. Nov 29, 2022 at 8:14 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    Real easy. Took all of 30 minutes.
  26. Nov 29, 2022 at 8:23 AM
    GravityGear
    Aurora, CO
    Ah, the company that, in the late 2000s/early 2010s, bought a legit Volk TE37, pressed it into some mold material and started producing blatant FAKES. Too bad VTX uses this shithole of a company for manufacturing.
    Major and Ace96 like this.
  27. Nov 29, 2022 at 2:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    haven't been following since I put mine on - what is this fluid change door?
    AggiePhil and 1794TX[QUOTED] like this.
  28. Nov 29, 2022 at 2:24 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    Looks like it's this [​IMG]
    The pic's from Tyler's site. By the way, anyone else read his URL (https://valhallasshields.com) and not see Val Hall Ass Shields?
    Major, bulldog93 and 1794TX like this.
  29. Nov 29, 2022 at 2:28 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I guess we need to drop ours to do the diff!
    AggiePhil, RainMan_PNW and 1794TX like this.
  30. Nov 29, 2022 at 2:34 PM
    PKFan
    At the rate I'm putting miles on mine, it'll be years yet.
    RusPro21[QUOTED] and RobertD like this.
