Recommended roadside air compressors?
Discussion in 'General Tundra Discussion' started by Cougareb, Nov 28, 2022.
  1. Nov 28, 2022 at 2:50 PM
    Cougareb
    Cougareb [OP] New Member
    2014 Tundra Limited Magnetic Gray
    My truck is a daily driver, and I had a flat tire last week. As I was just one mile from a Discount Tire location, I realized the importance of having a tire patch kit and a portable air compressor in the truck.
    I'm wondering what portable air compressors you all recommend for keeping in your truck for emergencies (or for filling up MTB tires, sports balls, etc).
    I've leaned toward a Ryobi 18V digital compressor I've read about in some threads, but how do you keep your battery fully charged and always available in the truck? Is there an adaptor that would allow you to charge your 18V battery from the truck, if needed?
    I've also seen others like this GSPSCN Portable Compressor (connects to lighter or car battery).
    What options for a roadside / in-car compressor have you found to be effective?
  2. Nov 28, 2022 at 3:02 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I have one of those Ryobi digital compressors. It's perfect for filling up the airbags in the back of my truck. It is really poor for truck tires. First, you need to pull the trigger so you have to hold it, second it's slow and gets hot. I honestly don't think it could fill a Tundra tire without overheating.
    The GSPCN compressor you have there is a clone of the Masterflow MV-50. Going back 10 years ago, that was the little cheap portable compressor everyone would buy. I still have one and it still works well. It's perfect to keep in your truck to pump tires or occasional use. Not great if you are regularly off-roading and air down/up tires - on board air compressors like an ARB are much faster.
    Based on your use case, I would get an MV-50 on sale and keep in in the truck at all times. The bag even has room for the patch kit in a ziploc.
  3. Nov 28, 2022 at 3:06 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
  4. Nov 28, 2022 at 7:12 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have an ARB but for tires use my DeWalt that can be set to the PSI needed & left to run.
    Coal Dragger likes this.
  5. Nov 28, 2022 at 7:18 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
  6. Nov 28, 2022 at 7:24 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    AZBoatHauler likes this.
  7. Nov 28, 2022 at 7:44 PM
    Single or married? That will determine how I answer.
    Sunnier, reywcms and AZTundra like this.
  8. Nov 28, 2022 at 8:05 PM
    AZTundra
    Paul
    Phoenix, AZ
    Just hide it under the hood from the wife. That's where I stash a few things. :anonymous:
    baraynavab, junior, Mater and 3 others like this.
  9. Nov 28, 2022 at 8:38 PM
    Toyotaloop
    Toyotaloop New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    +1. For bigger size truck tires, a passenger car tire pump takes a long time to fill the volume needed to get to nec psi.
  10. Nov 28, 2022 at 8:47 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    ARB FTW I’ve got mine mounted under the driver seat. Updated it power through my switch pro.
    trj, AZTundra and clarkritchie like this.
  11. Nov 28, 2022 at 8:58 PM
    Well I was going to say the person sitting next to him may be full of hot air…..
    AZTundra[QUOTED] and reywcms like this.
  12. Nov 28, 2022 at 9:26 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I have the exact same unit. I don’t go on a road trip or hunting trip without it.
    My mom is currently out on a road trip and I insisted she take it with her.
  13. Nov 28, 2022 at 10:22 PM
    Cougareb
    Thanks for the suggestions. -- I'm married, and getting the wife to support something like an ARB (I like the idea of mounting below the driver seat; curious to learn more about how you power that) might take a while. -- I think I'll go with the Dewalt 20V battery / 12V car lighter unit for now; it's mobile and could be moved to another vehicle in the future.
  14. Nov 28, 2022 at 11:23 PM
    Coal Dragger
    Kung Fu Dick
    The DeWalt handles the tires on the Tundra just fine. You’ll like it.
    It can also run the DeWalt 60V 5AH batteries too. Probably enough juice in one of those to air up several truck tires, I’ve topped off all 4 of mine with it and it didn’t phase the 60V battery at all.
    clarkritchie likes this.
  15. Nov 29, 2022 at 5:48 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I want this compressor and a couple months ago I searched all over for it. I called around to a few Napa stores and convinced one of them to call corporate, turns out it was a limited run for some reason. They are not making any more.
  16. Nov 29, 2022 at 6:05 AM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    This thread has me researching the Dewalt DCC020IB portable inflator referenced above. I love the feature that lets you set your desired pressure and the machine gets there and stops.
    Are there limitations with tire size? I’m reviewing the specs and I’m not quite sure how to tell where the limitations come in, but I see a few comments in this thread and others that say X/Y/Z compressor is only capable of up to a certain size tire. The referenced Dewalt says it can fill up to 160 psi. I’m guessing it’s a matter of total flow rate that’s the limiting factor? I’m only going up to 45-50 psi on my 35” tires, but maybe it will take forever?
    idk, much like OP I’m not sure what to do for my tire inflating needs. I have a viair for emergencies but I dread airing down when off-roading because it’s gonna take me 20 minutes to re inflate. On my last trip I just spent a few days getting jostled around because there was going to be a lot of switching between on and offroad and I didn’t want to spend hours messing with my tires. Also I’ve had this viair 5+ years now and I wouldn’t be surprised if it gives up the ghost the next time I ask it to fill up my 35s.
    i thought I had settled with building my own version of a power tank / co2 tank. But theeeen I see people talking about the inconvenience of keeping it filled, etc. Of course that’s not so different than the risk of mechanical failure of an air pump. Arb stuff seems pretty bulletproof but GD I can’t justify that cost right now.
  17. Nov 29, 2022 at 6:07 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I keep a cheap Masterflow compressor and off-road tire repair kit onboard at all times. Just used it a couple months ago on the side of the road when I drove over something the size of a railroad spike on I65. It’s nice repairing and re-inflating a tire without needing to remove it.
    It works really well, and for $60, I have zero complaints. It isn’t too slow with my 285/75s. If I didn’t already have one, I’d probably be looking at the DeWalt.
    Mike59, texasrho83 and ColoradoTJ like this.
  18. Nov 29, 2022 at 6:11 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I use Air Armor M240. compact, easy to store and carry, plenty of power for big LT tires -https://specialopstools.com/
    Cougareb[OP] likes this.
  19. Nov 29, 2022 at 6:35 AM
    Coal Dragger
    Kung Fu Dick
    Here you go:
    https://youtu.be/TkxpuzYggd4
    Cliff notes: the DeWalt and Milwaukee get things done.
  20. Nov 29, 2022 at 6:46 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  21. Nov 29, 2022 at 6:55 AM
    Sunnier
    Sunny
    San Diego, CA
    For 35’s it will take forever, and the small portable compressors get damned hot. Gotta stop and let them cool off, so filling 4 large tires could be a pain (say, if you aired way down to drive on sand).
    A bit more costly, but Ironman sells a great portable compressor that can fill big tires, fills quickly, has a long cycle (fill all 4 before having to stop), and cools quickly, then store it in its own bag.
    Edit: this one’s be best for large tires: https://ironman4x4america.com/air-champ-pro-5-65cfm-12v-heavy-duty-portable-air-compressor/
    There’s a smaller version as well. Lower price. Looks like the Cyber Monday sale may still be active.
    Mater, des2mtn, reywcms and 1 other person like this.
  22. Nov 29, 2022 at 7:25 AM
    W3agle
    W3agle New Member
    San Diego, CA
    You should get a commission! Just ordered one. Thanks for pointing me in that direction.
    Mater, des2mtn, ColoradoTJ and 2 others like this.
  23. Nov 29, 2022 at 7:35 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, I’d make a lot of money from a lot of vendors!
  24. Nov 29, 2022 at 7:47 AM
    mass-hole
    mass-hole New Member
    Hahahahah. The guy had one flat tire and everyone is recommending a $600 ARB mounted under the hood.
    I really like my Ridgid 18V compressor. It fills my 35's no problem. I even used it to air up all 4 of my 37"x12.5" Geolandars on my 4Runner through an inflator system. It took a minute but did it no problem. Funny thing is I used it on the 4Runner when my ARB stopped working.
    I didn't buy it just to leave in a vehicle, it gets used for all sorts of stuff, but when I am not using it I leave it in one of my vehicles and I take it as a backup when wheeling in my 4Runner.
    The Ridgid comes with a cord to plug into the 12V in the truck in case your battery is not charged.
    Leo's first likes this.
  25. Nov 29, 2022 at 8:10 AM
    I don't carry one. That's what spare tires are for...and then let Discount Tire deal with it.
    Mike59 likes this.
  26. Nov 29, 2022 at 8:15 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I ordered one from their recommendation as well and it came a few days ago, nice little compressor at a decent price with their sale. Only thing I noticed is the quick release for the air hose isn't a "M type" but a "Q type" instead, but you can change it out.
  27. Nov 29, 2022 at 8:54 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Exact same compressor. On sale for BF
    https://morrflate.com/product-category/air-sources/
  28. Nov 29, 2022 at 9:48 AM
    coTony
    Tony
    Montrose, CO
    ExtremeAire Magnum
    AZTundra and Mater like this.
  29. Dec 1, 2022 at 12:00 PM
    TundraMidwesterner
    Northern Illinois
    I wish I would have seen this. I just ordered the ironman4x4 AIR CHAMP PRO 5.65CFM last night. They have a 25% off sale and free shipping. oh well, Ill see how this one works first.
    Mater[QUOTED] likes this.
  30. Dec 1, 2022 at 12:04 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    That looks like a really really solid compressor. Plus the benefit of it over the MORRFlate is that you could probably pretty easily mount it on its side under the hood.
