Help Transmission shifter assembly wiring was cut
Discussion in '2nd Gen Tundras (2007-2013)' started by Kayden808, Nov 25, 2022.
  1. Nov 25, 2022 at 7:51 PM
    Kayden808
    Kayden808 [OP] New Member
    Hey guys so I just got this truck (2008 tundra) and looks like someone before me had cut and spliced the wires for the transmission shifter assembly and I believe it’s the reason I’m getting code p0705 and my reverse lights and turn signals won’t work and I cannot see what gear I’m in on the screen here’s a picture of the wires
  2. Nov 25, 2022 at 9:02 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    2008 you say?
    https://www.tundras.com/forums/2nd-gen-tundras-2007-2013.26/
    @ColoradoTJ can you move to 2nd gen?
  3. Nov 25, 2022 at 9:33 PM
    2mchfun
    Go to forums button, scroll down to garage heading, scroll to electrical subheading. Click it. Wire diagrams is right there at the top. Find your version and get to work.:thumbsup:
  4. Nov 26, 2022 at 8:56 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    If you post a picture of the connector all the wires go to, I can give you a pinout so you know what each wire does. I think I know which connector it is but I dont want to guess.
    My advice would be to pull all the added in crap out. Clean up the wire ends, solder and heat shrink any broken connections back together and then finally go through the fuse box to replace and bad fuses.
    If it is all on that one lead it should be as simple as matching the colors back together when splicing.
    I would also take a second to see where the other end of the splices are going. Trying to figure out why they were added and what they do. I personally don't want any of that kind of crap in my truck. Take your time and diligently make it back to the way it came from the factory. I personally am not a fan of butt connectors or wiring nuts. Make the fix clean and right.
    Most people do not like doing automotive wiring, it is even more frustrating when you have to come in behind someone and clean up a mess that was created. Do it once and do it right, you will never have any problems down the line.
  5. Nov 26, 2022 at 9:05 AM
    2mchfun
    It may have been some sort of anti theft method to lock the shifter in park. There are easier ways though.:spy:
  6. Nov 26, 2022 at 11:51 AM
    Kayden808
    Jeff_5_7 it goes into the shifter assembly here is a better picture of the wires and where they go and come fromupload_2022-11-26_11-48-20.jpg
    Jeff_5_7 likes this.
  7. Nov 26, 2022 at 11:55 AM
    Kayden808
    Forgot this pic which is the wires going from the harness to the sensor
  8. Nov 29, 2022 at 5:17 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    8 pin connector going into the rear of the shifter assembly?
    Do you need a pinout for this or did you get it fixed.
    As I mentioned cutting all the added in wiring out and splicing/matching the colors back up would be my first step
    Kayden808[OP] likes this.
  9. Nov 29, 2022 at 6:09 PM
    Kayden808
    Yeah the shifter assembly connector I got it basically wired now I just have to figure out how to figure out how to tell the difference between the 2 blue wires
