2022 How would racks attach?
Discussion in '3rd Gen Tundras (2022+)' started by kingspeedy1, Jul 23, 2022.
  1. Jul 23, 2022 at 10:00 PM
    kingspeedy1
    kingspeedy1 [OP] New Member
    Neil
    looking to Purchase 2021 or 2022
    I was looking for a headache rack prior to the delivery of my truck next month..Typed with Skepticism. With limited success. I did look at a truck at the dealer ship tonight after it closed and was wondering how one would anchor a rack . You dont have access to to the underside of the bed rail or stake pocket like my current GM. Unless I cut some access holes in the plastic ..Pardon me .composite box liner .and then make covers for the access holes. The only other way I see without a bunch of fiddle farting around is to use the rails the tie downs go in .Is this the usual way to mount racks on previous Tundras? How are people mounting racks beside some unreliable self tapping screws
  2. Jul 27, 2022 at 8:23 AM
    Phxdra
    Phxdra New Member
    ARIZONA
    2022 Tundra
    I’ve been using those T tracks for my rack with no problem.
  3. Jul 27, 2022 at 8:41 AM
    kingspeedy1
    Neil
    Thank you
  4. Nov 25, 2022 at 7:07 PM
    GRIBBON
    GRIBBON New Member
    Wondering if you found a headache rack to go with your 2022 Tundra? I have been looking with not much luck, would love to see a photo if you found something. Thanks in advance.
  5. Nov 25, 2022 at 7:19 PM
    2mchfun
    My 2021 headache rack is mounted to 3"x3"x1/4" angle bed rails. The whole assembly is mounted to expandable rubber stake pocket anchors, same as the old school eye bolt type from 1980's. However, I first threaded the stainless 3/8" bolts through the plates at the bottom and epoxied a stainless nut to the bottom of each plate. That way I could apply substantial torque to the bolts without stripping the plate threads that aren't accessible in the pockets. Then I added an easily removable crossbar over the tailgate to rest heavy items on for transport.
  6. Nov 25, 2022 at 8:04 PM
    kingspeedy1
    Neil
    My truck finally arrived and I decided not to accept it. To many quality issues.
    I was also underwhelmed with the power .Felt exactly what it is .A big truck with a small engine. In fairness it only had 17 kilometres on it so i wasnt about to push it,but it should have been somewhat exciting..Total disappointments after a year of many postponements..
  7. Nov 25, 2022 at 8:21 PM
    2mchfun
    Grab a 21 while you can. There is a real nice 2016 with 65k in Choctaw OK red crewmax with topper and bedrug clean truck for $35000. Saw it on FB marketplace an hour ago.
  8. Nov 25, 2022 at 8:24 PM
    kingspeedy1
    Neil
    There is lots of 2021 for sale up by me in british columbia .Gas was as high as $2.39 a litre so $9.50 Can a gallon and we know how thirsty they are
    2mchfun[QUOTED] likes this.
